Which OS on a faster 486 system.
Reply 20 of 29, by tincup
Well there you go, chinny22 basically says it all as far as RA is concerned - so that's what you can to go on. Best just set up the system like you say, and let let fly....
Reply 21 of 29, by Mau1wurf1977
MS-DOS 6.22 installation
You might find this handy 😀
It is almost exactly for MS-DOS 7.1. Just a different boot disk and there are files on a RAM drive to be copied. My ZIP archive works just like with MS-DOS 6.22.
My YouTube channel
Reply 22 of 29, by Robin4
Can you also made an 7.10 tutorial?? When you have time available.
Reply 23 of 29, by Mau1wurf1977
It's next on my list 😀
EDIT: Turns out the 7.1 boot floppies are missing EMM386.EXE 🙁
My YouTube channel
Reply 24 of 29, by WolverineDK
Well, if you have an old Windows 95/98/SE CD. then perhaps you can get the file that way 😀
Reply 25 of 29, by Mau1wurf1977
Yes that works. The video I'm working on assumes that the user has access to an existing W98SE installation to get the files. There are others missing as well. Shouldn't be too hard to get.
One benefit of doing it via bootdisk is that the Creative installers will work and not complain about the version.
My YouTube channel
Reply 26 of 29, by Anonymous Coward
I run PC-DOS 2K which is a slightly updated version of v7.1. To the best of my knowledge it does not support FAT32. In fact, I do not believe it it is related to MS-DOS 7.x at all. MS-DOS seems a lot more advanced in the 7.x release.
Reply 27 of 29, by bjt
I think it's just the SB16/AWE installer that will complain with MSDOS > 6.22 - SB Pro works OK. I did get the SB16 installer working under Win98 but I can't remember whether it was via setver or a patch.
Reply 28 of 29, by idspispopd
Mau1wurf1977 wrote:
Yes you can create up to four 2GB partitions with FAT16.
Even more if you use logical partitions, 4 is the limit for primary partitions.
IIRC with logical partitions you only have to stop when drive letters run out. (LASTDRIVE is relevant, of course.)
