Reply 20 of 36, by ChaosFish
- Member
Both demos work. This is stupid, the demos works but the full version does not. 😠
Hi,
I just tried your "guide" to install LBA2 (original CD french)
But it didn't works 😮(
All install is OK until I launch LBA2, then I've got the little "mup mup" and this message "Veuillez inserez le CD-ROM de LBA2 : Twinsen's Odyssey"
(In english "Please insert LBA2 CDROM....")
So he seam not to reconize my genuine LBA2 CDROM...
What can I do...?
Thanks you for you reply.
Are you using Windows? Did you do all stages exactly as I wrote them?
Yes, I followed your stages as written.
But, no need now, I tried the LBA2 patch. and ....
It works !, so no need of dosbox.
Anyway thanks you.
Hispace
Guide updated for DOSBox 0.62 😀
one small bug in your guide:
the mount line -t cdrom -label addasf -ioctl
should have a -usecd 0 as well
where 0 must be replaced by yourcdrom number if you do mount -cd
(else it won't work if you have more than 1 cdrom player (and not using the first))
Water flows down the stream
Are you sure? 😕
I use Drive "V:" which is number '1' (while "D:" is number '0'), never used -usecd and it always worked.
well if it has always worked then ioctl isn't needed .
if you omit -usecd it defaults to -usecd 0
It doesn't work without -ioctl.
i take your word for it. but it doesn't make sense.
try if it runs better/still runs if you specify that -usecd #
I tried "-usecd 0" (drive D, not the LBA 1 cd) and I tried "-usecd 1" (drive V, is the LBA1 cd).
They both resulted in not recognizing the CD.
how about combined ?
-usecd 1 -ioctl -t cdrom
-usecd 0 -ioctl -t cdrom => -ioctl -t cdrom (as far as I know)
Just tried all possible combinations (with/without ioctl, with/without usecd, with usecd 0/1).
The only way it works is "mount d V:\ -t cdrom -label ADELINE -ioctl"
Hey im trying to get LBA 1 to load on my PC. I used Win XP and have 1GB of mem. I can mount the CD no prob but when i change to drive D and type install is says the command is illegal, and thats as far as i can get! 🙁
Can someone help plez!
Thanx in advance 😀
How did you mount your C and D drives?
What type for file is that INSTALL ? Try a DIR INSTALL.* and let us know.
_________________
LBA1 cd always has an install.exe file on the root directory.
Are you sure you followed the guide I made? (which is a little outdated now..)
