Reply 20 of 23, by Putas
- Oldbie
I see, how about Final Reality. That is easy to use 3d benchmark.
https://www.scene.org/file.php?file=%2Fdemos% … 01.exe&fileinfo
Here they be on Pentium 133 MHz:
Database Entry <Diamond Monster 3D + S3 Virge GX 2MB>Benchmark results:Radial blur, 5N, 7.41, rips, 1.025, RmarkChaos zoomer, 5N, 20.11, rips, 0.977, Rmark25 Pixel, 5N, 56.69, kpps, 1.812, RmarkRobots, 5N, 11.24, rips, 2.912, RmarkFillrate, 5N, 18.51, MPps, 4.007, RmarkCity scene, 5N, 15.08, rips, 3.743, RmarkVideo card bus transfer, 5N, 34.49, MBps, 1.098, RmarkDirect3D bus transfer, 5N, 15.80, MBps, 1.350, Rmark-----------------------------------------------------------------------------Visual appearance, 100.00, percent-----------------------------------------------------------------------------Overall 3D, 2.055, RmarkOverall 2D, 1.001, RmarkOverall bus rate, 1.174, Rmark-----------------------------------------------------------------------------OVERALL SCORE, 1.607, Rmark-----------------------------------------------------------------------------Database Entry <Hercules Stingray 128/3D>Benchmark results:Radial blur, 5N, 7.48, rips, 1.035, RmarkChaos zoomer, 5N, 20.00, rips, 0.972, Rmark25 Pixel, 5N, 56.82, kpps, 1.816, RmarkRobots, 5N, 10.42, rips, 2.698, RmarkFillrate, 5N, 25.98, MPps, 5.624, RmarkCity scene, 5N, 14.21, rips, 3.525, RmarkVideo card bus transfer, 5N, 35.04, MBps, 1.116, RmarkDirect3D bus transfer, 5N, 7.05, MBps, 0.602, Rmark-----------------------------------------------------------------------------Visual appearance, 96.30, percent-----------------------------------------------------------------------------Overall 3D, 2.045, RmarkOverall 2D, 1.003, RmarkOverall bus rate, 0.962, Rmark-----------------------------------------------------------------------------OVERALL SCORE, 1.570, Rmark-----------------------------------------------------------------------------
If we are to compare overall score:
Diamond Monster 3D = 100%
Hercules Stingray 128 = 97.7%
Diamond Monster 3D + S3 Vige GX 2MB displayed 100% of all scenery, while Hercules Stingray 128/3D displayed only 96.3%.
Also, Fillrate and Direct3D bus transfer differ by a larger percent:
Diamond Monster 3D : Fillrate = 100% / Direct3D bus transfer = 100% (In RMarks)
Hercules Stingray 128 : Fillrate = 140% / Direct3D bus transfer = 82% (In RMarks)
I don't know how much impact to overall performance does Direct3D bus transfer impact, but Fillrate is noticeable greater on the Hercules Stingray 128/3D.
But scenery completion is not 100%.
Strange, both have same feature set that should do 100%. Regarding fillrate make sure they are set for same refresh rate. I have no other idea how could Rush win.
