sound stuttering
Reply 20 of 25, by Guest
Hoi Folks,
I use windows xp pro , on the game discworld 1 , my problem is i have no sound, not a beep.
It´s my first old game, so i´m a newbie on dosbox, please can you help me ?
Reply 21 of 25, by Freddo
Anonymous wrote:
Hoi Folks,
If you got the CD version be sure to download the patch for it as it improves the sound compabilities very much.
There are probably a patch for the floppy version aswell, but since I have the CD version of it, I haven't been bothered to check it up.
Reply 22 of 25, by Pyro
Where i can get this patch ?
Reply 23 of 25, by Guest
@ Orginal Guest : have you tried to decrease the Sampling rate to 22050 khz ??? I had this problem when i was running the sample rate @ 44100, and maybe decrease the blocksize to 2048 (i have this settings, and never had stuttering in any game)
Reply 24 of 25, by nilsbyte
i solved the problem with the stuttering sound by increasing the block size to 8192 and the cpu cycles to 5000 at full emulation mode.
hope it works for you folks.
Reply 25 of 25, by Lydecker
Fixed mine with:
nosound=false
rate=44100
blocksize=4096
prebuffer=10
