Choose an ISA video card
Reply 20 of 31, by Matth79
How's the ISA bus speed?
With a DX2, if it's a DX2-66, then you can either have the ISA at 8.25MHz (/4) or push it to 11MHz (/3)
If it's a DX2-50, then the ISA is at 8.33MHz (/3) or heavily overclocked to 12.5MHz at /2.
Depends on the card if it will take it, or show much improvement
Reply 21 of 31, by darksheer
Would you really risk to damge or fry all you isa's cards just for a few fps gain that you can already have by tweaking your BIOS and using UNIVBE ? 😳 😵
Reply 22 of 31, by Stojke
Science! Push to the limit.
I overclocked my ISA bus to 20MHz once, reached 30MB/s disk transfer speed.
Reply 23 of 31, by darksheer
The true question is : by how many years did you reduced the life expectancy of your hardware by doing that ? 🤣
I'm pretty sure you would not test this again with a Gravis Ultrasound or Roland SCC-1 on the motherboard 😁
Reply 24 of 31, by Dunkill
this is the chipset integrated in my motherboard
someone can tell me how many ram on it ?
I have also a jumper and i don't know how useful it can be
please tell me
I checked my jumpers and i saw that the CPU was stuck to 50 Mhz 😒
I put it in the right position, i will try some games now to see if lags are present again
Reply 25 of 31, by Stojke
1MB of memory.
Reply 26 of 31, by Dunkill
ok I tested elite 2 with tseng ET4000 w32 and in high resolution graphics it's good.
But in higher resolution it's laggy
I am wondering who played this game in higher resolution in 1993 😵
I see in the graph western digital is équivalent to tseng ET4000
what's the best card with ISA connector ?
Mach 64 ?
I also need a solution for general midi, should i take roland SC55 or isa SCC-1 ?
Reply 27 of 31, by Stojke
You will find SC55 MKII for cheaper than SCC-1. But you will also need an MPU 401 interface.
Reply 28 of 31, by Dunkill
What the regular price for an SCC-1 ?
I'll need an MPU401 !? why ?
i thought i just need a gameport/midi cable to connect on soundblaster
Reply 29 of 31, by vetz
That is correct, UART MPU-401 is the interface used to connect to the external SC55 which is present on the Soundblaster.
Go for an SC55, it is more flexible as it can be used on both new and modern computers, it's cheaper and you get the LCD panel 😀
Reply 30 of 31, by Dunkill
Ok MPU401 is integrated on the most of sound cards
I have a SB AWE64 gold and i use this to conect my mt32
Work like a charm
So for whitch card the roland MPU 401 unit was designed for ?
Reply 31 of 31, by Matth79
PQFP selection?
Plastic Quad Flat Pack - if there is an onboard PQFP CPU, then that setting sounds like it wold be to disable it in favour of a socketed one.
The details also suggest that the onboard graphics is local bus - if that's true, then any ISA card would be unlikely to compete
