Reply 20 of 20, by AlphaWing
- Oldbie
wrote:wrote:Theres 1 Small cap on the Powerside, and 1 Big cap Missing. The Big Cap has some of the left part of its solder pad knocked off […]
Theres 1 Small cap on the Powerside, and 1 Big cap Missing. The Big Cap has some of the left part of its solder pad knocked off too.
The other one missing Is a small one above the left memory chips gpu\vpu\whatever.I'm all thumbs when it comes to soldering why I keep putting it off.
Don't know the ratings for them either.All of the small ones are 10uF (anything 16V and above will work for the voltage tolerance). The 'big one' that was knocked off is 100uF / 16V. The big one was a polymer (oscon), so something like rubycon ZLH would be an appropriate substitute, or another sanyo oscon.
Thanks I'm gonna get to eventually fixing it.
The heatsinks on it are from the previous owner and are epoxied on quite strongly. Much taller then they look in the picture.
Pretty sure the left one is an oem Pentium 1 sink of some sort, and the right one was probably took off the northbridge of a mobo 🤣 .
