Reply 20 of 21, by Mau1wurf1977
Mau1wurf1977
Offline
- l33t++
A tiny bit can be gained by lowering FILES and BUFFERS but I don't see the need. You should not have any memory issues with these start-up files. Even Ultima VII works fine with menu option 3.
Now if you're using MS-DOS 7.1 (The DOS that comes with Windows 98) then you will have less memory. It's just the nature of MS-DOS 7.1.
