Post your 486 Winamp benchmarks
Reply 20 of 22, by gdjacobs
Anything using the MAD library is integer based.
Reply 21 of 22, by noshutdown
update: i swapped the diamond ess1968 with sb16, and cpu usage remained exactly the same.
so, i guess that directsound only helps with win2000/xp.
and, which players are based on the mad library?
Reply 22 of 22, by gdjacobs
The two big projects are VLC and ScummVM.
