Reply 21 of 23, by sergm
Hmm, SF is in trouble by now as I can see, posting here so you NewRisingSun can test it.
    smf2wav-1.0.4-20141207-win32.zip
    593.25 KiB
    90 downloads
    smf2wav for win32 with analog output emulation added
Reply 22 of 23, by NewRisingSun
Works great so far. Thank-you for doing this merely because I asked. 😀
Another question: the DOSBox patch no longer allows the maximum number of partials to be set (option mt32.partials). I readded it myself, and find it working nicely. Any particular reason why this was removed?
Reply 23 of 23, by sergm
Eek2. Thanks for pointing this out, I'll fix it. Probably it was lost after I mixed the release/svn patch code together 😒
EDIT:
Ah, you probably mean mt32.partials option found in Ykhwong's builds. I think it was never there in the patches I've dealt with.
