Need some help with IDE controller
Reply 20 of 38, by alexanrs
Did you disable the onboard floppy controller through jumpers? This could be two controllers trying to hook the same ports/IRQs
Reply 21 of 38, by ahendricks18
Yep, I put it to secondary, put both jumpers on the card to primary. Also the hdd controller on the motherboard is on secondary too.
Main: AMD FX 6300 six core 3.5ghz (OC 4ghz)
16gb DDR3, Nvidia Geforce GT740 4gb Gfx card, running Win7 Ultimate x64
Linux: AMD Athlon 64 4000+, 1.5GB DDR, Nvidia Quadro FX1700 running Debian Jessie 8.4.0
Reply 22 of 38, by alexanrs
Try disabling it entirely. I think removing the jumper would do the trick. If the onboard FDD controller is working, try setting it to primary, then removing the jumper on the Maxtor.
Reply 23 of 38, by ahendricks18
Nada. keeps booting to packard bell same old start up. I'll keep messing with jumpers.
Reply 24 of 38, by ahendricks18
If I wait a few minutes on the start up screen, it will beep and say fixed disk controller failure press f1 to continue f2 for setup. f1 says no boot device available, f2 enters start up. Should I put HDD 1 to not installed?
Reply 25 of 38, by ahendricks18
Put it to not installed. No dice. I'll upload some pics of the ISA card and show you the jumpers:15cbpmp.jpgixxi6w.jpg
Reply 26 of 38, by ahendricks18
Any ideas?
Reply 27 of 38, by Robin4
Maybe that machine is too proprietary and other controllers wouldnt be accepted by the pakard bell bios.. So i would trying to solder an new IDE IDC part on the motherboard.. Or look for someone with very high solder skills.
Reply 28 of 38, by ahendricks18
Yeah, good idea. I'll ask around about people good at soldering. Maybe the shop/cad teacher.
Reply 29 of 38, by ahendricks18
Could it be that the card is 8 bit and I have to boot from a diskette or something?
Reply 30 of 38, by ahendricks18
I feel I've made a discovery: The maxtor card seems to be awfully similar to the "acculogic" card for sale on VCM by minnesotatv. I'll do some more research later about these cards.
Reply 31 of 38, by ahendricks18
Here is a ms support article:http://support.microsoft.com/kb/108016/en-us Also here is some info on the card:[url]ptm2.cc.utu.fi/ftp/devices/hd-cd-fd/max ... og.txt[url]. Perhaps the problem is the ISA card has no onboard bios?
Reply 32 of 38, by soviet conscript
maybe. can you load DOS from a disk and get access to the hard drive that way? if so maybe its just not a bootable type card.
I've had odd experiences, especially with Packard Bells. sometimes even though everything SHOULD work it just doesn't. I've had hard drive controllers that work fine on other systems but for reasons beyond explanation refuse to work on a packard bell. have you tried a different hard drive by chance?
again, if all else fails with IDE you can always try SCSI. The controller cards are a dime a dozen but the SCSI hdd can be more expensive and harder to find then IDE.
Reply 33 of 38, by ahendricks18
I will try a diff. hdd. I have one I can pull from a broken original xbox.
Reply 34 of 38, by ahendricks18
Also I will try to load DOS however it says diskette drive 0 failure, diskette drive 1 failure. I will try messing with it some more.
Reply 35 of 38, by smeezekitty
I am concerned. I think XBox may used locked to the device hard drives.
Reply 36 of 38, by ahendricks18
Wel the hdd says seagate and looks like any other ide drive from a regular pc. The only problem is that its 8 or 10 gb and I don't know how that would work out in an older bios.
Reply 37 of 38, by soviet conscript
I've used 10+gb drives in 486's before. They worked but were detected as 500ish Mb drives. Your results may vary. So your floppy controller is dead to or you trying to use the one on the IDE controller?
Reply 38 of 38, by ahendricks18
Nah, I think i plugged the fdd cable in wrong. The light is always on.
