Reply 20 of 48, by AlphaWing
- Oldbie
Not sure about 8-bit cards....
I think like the SB-PRO some ESS models can work in an 8-bit slot.
I'd assume its all the non-pnp ones that have manual jumpers.
I could be wrong on that tho, I don't own a XT\286\386 with 8-bit slots to test with.
Someone on these forums should know more.
I do know some ESS cards have beeper inputs, and there spaced correctly, so no hacked cable needed like for the SB. Can use a normal 4-pin CD audio cable.
