Subtle differences between Cyrix and IBM 6x86s
Reply 20 of 30, by lazibayer
bakemono wrote:
Like this Superpi 1M score!
Huh? Does it really take over an hour? Pentium MMX only takes 15 minutes.
I reckon Skyscraper benchmarked it at 33MHz.
Reply 21 of 30, by Carlos S. M.
I recently tried Windows 7 on a Cyrix MII-233GP and managed to get running, even with Aero working, but in the practice, it was too slow to be usable
The attachment mii w7.png is no longer available
Machine specs:
Cyrix MII-233GP (200 MHz)
EPoX EP-MVP3G2 Motherboard
384 MB RAM
Geforce 6200 AGP
Realtek RTL8139 LAN card
2x 80 GB HDD
Reply 22 of 30, by Carlos S. M.
As well, i tried some newer software on 6x86 P166+ using Windows 2000 w/ BWC extended kernel since XP won't boot on it, these tests were done without the CPUID hack
Machine specs:
384 MB RAM
Geforce 6200 AGP
Soundblaster Vibra 16S
2x 80 GB HDD
Known not working or begin broken:
Windows Media Player 9
Microsoft Office 2003
.net Framework 2.0
Firefox 10esr+
3DMark99/2000/2001SE/03 (99 MAX FPS counters are broken, 2000 complains CPU lacks MMX and closes istelf, 2001SE complains as well and starts anyway, but first test fails, 03 starts but not all tests can be done and sometimes triggers 0x1e BSOD)
Palemoon 27.9.6 XP Mod IA32 port
Seamonkey 2.40
FRAPS 3.4.7
Reply 23 of 30, by feipoa
Office 2003 and XP work just fine on my MII-433.
Reply 24 of 30, by rmay635703
I had a Cyrix 233mhz 75x2.5 for many years
At one point I upgraded to a Ss7 sys598 and ran the bus 2x95mhz gave a nice speed boost
Now I find out many motherboards had undocumented and stable 120mhz and 133mgz FSB settings
If the old Cyrix chips can do 1x would be interesting to run an old pr200 on a 133mhz fsb.
Reply 25 of 30, by feipoa
I was able to get the original Cyrix 6x86 chips to run with 1x, but which SS7 boards have a stable 133 MHz FSB setting?
Reply 26 of 30, by canthearu
In my testing of the original 6x86 processor, I have found them to be rather problematic, as they are missing some pentium features.
The 6x86MX/MII processor, on the other hand, showed excellent compatibility and I have not found any problems with them running software.
Reply 27 of 30, by Carlos S. M.
Gigabyte GA-5AX (rev 5.2) supports 135 and 140 mhz,but not 133. ASUS P5A only does up to 120 mhz. No idea if other boards have that setting though.
I can say FSB >100 MHz is really questionable on a Super 7 system because of the external cache and the PCI/AGP clocks not begin able to cooperate. at 133 mhz the cache wouldn't handle it and the AGP would be running at the astronomically high clocks of 89 mhz plus i don't think they have an 1/4 PCI divider like 440BX boards generally have
Reply 28 of 30, by meljor
BX has the pci divider but agp also runs at 89mhz when overclocked to 133fsb. It is not a problem for many many cards. But I do agree on the cache, overclocking with working cache is around 110mhz fsb on a p5a/p5a-b and benchmark stable you can try 115mhz fsb with working cache (and need luck).
Reply 29 of 30, by havli
My GA-5AX (5.2) worked with external cache enabled up to 125 MHz and without cache 135 MHz. 😈
Reply 30 of 30, by rmay635703
havli wrote on 2019-03-07, 19:59:
My m598 would run 133mhz FSB creatively using cpucool (with cache)
