Reply 20 of 42, by obobskivich
- l33t
wrote:Funny thing you should say that, I just started installing Windows 2000 as I want to get the system to dual boot WinME and Win2k , thing is according to the ATI/AMD webstite the latest driver for it is 6.10 for windows 2000 , If I try and install the latest version 10.3 I get a incompatibility warning stating that I do not have a 64bit version of windows, and if I look at the executable its clearly for both 32bit and 65bit?
Any ideas? Or should I just go with the Omeaga drivers?
10.3 is too new. Legacy 10.2 is the final build for R300 even in Vista - make sure you're downloading the proper variant though (go through their little "driver finder" thing and it'll steer you right). 9x is limited to 6.something which means fog is likely broken (it was officially fixed in 7.10).
