Reply 20 of 24, by lee292
Okay, I clicked on the little wineglass after starting wine, and found the configuration menu. After inserting the disc, I got it to recognize the DVD drive as drive D:, and even got so far as using the menu to access the installer and install the game. Now, the bad news. When I try to run the game, it prompts me to insert the disc again, even though it's still in the drive. I navigated to the DOS prompt in Wine and typed PATH and noticed D: was not in the PATH statement. Could this be causing the problem? I looked here https://www.winehq.org/docs/wineusr-guide/env … nment-variables on how to edit Wine's PATH and it told me to use wine's regedit to change environment variables. I did, and in the Current User section, PATH wasn't there, only TEMP and TMP. What now?
