Reply 20 of 23, by -Maverick-
- Newbie
Thanks SmokeMonster, this will come in handy when I do my own 98 build later this Summer.
Zee wrote on 2021-02-22, 23:39:I realize I'm half a decade late to this thread, but windows 98 is more than two decades old, yet we still talk about it. I got […]
PhilsComputerLab wrote on 2015-05-22, 12:14:BX300A, could you please attach the BIOS and driver that you used to one of your messages?
Thank you.
I got it working and thought I should share the files and exact steps here.
Maybe it helps you or whoever else is looking for this.My model is from Delock, so I downloaded the bios and bios updater tool from here : https://www.delock.de/produkt/70154/merkmale.html
The bios file I used is b5403.bin because that is the one that doesn't contain RAID instructions
I copied the bios file and UPDFLASH.EXE to the windows 98 machine, opened msdos and traveled to the directory where the exe is
The command I used isupdflash b5403.bin -a -d -v -ID3114 -r script.txt log.txt -uPress enter a few times when it asks, and after a bit the bios should be updated
Restart windows 98 and it'll ask for new drivers on start, just install the one that works out of the bunch that exist online, for me it was I think the one on delock site, it auto installed since I had previously tried a bunch of them 😁
At that point device manager should see the hard drives connected to the card, and the applet that it installs in control panel should also be working nowI'm running tests now, I see it has DMA. Might come back to post results if people ask
I Tried this method on my card but whole process stops on "loading bios..." what seems to be a problem?
The card has a AM28F010 memory chip, is it a problem?
Please help.
Anyone...
MIDI. I like MIDI... A lot! (Also stuck in 8bit PC era)
MaLLy_R wrote on 2023-07-03, 14:46:I Tried this method on my card but whole process stops on "loading bios..." what seems to be a problem? The card has a AM28F010 […]
The card has a AM28F010 memory chip, is it a problem?Please help.
Anyone...
The utility streams the BIOS file into the Flash Chip while it shows "loading BIOS". It will take some time (around a minute, if I remember correctly). It might be a bad idea to load the BIOS from a drive attached to that controller, if in doubt, use a floppy.
Hey everyone,
same problem here. Got a SIL3114 card which can't be flashed due to AM28F010 memory chip. Is there a way this RAID sata card can be used in a one-sata-drive or multiple-sata-drive system under DOS/Win9x?
Thanks
