Remember that only the older revisions of the p5a run well with a k6-2+ or k6-3+ (if you want to run a + cpu on it). 1.05 and 1.06 will run them slow. No problems with the normal k6-3.
Can your fic board cache 256mb? Otherwise 128mb will be a better choice for max. performance (same on the p5a, but no issue when using k6-3) . Your board has ''one of them agp slots'' but a banshee should be fine. V3 will be to much.
For oldest dos glide games i would stick a voodoo1 in your dos system. It can have troubles with fast p3 systems but it will work fine on even the fastest k6.
