Reply 20 of 29, by Nic-93
hmm, then it could not find the voodoo card it sems.
Make sure Direct3D acceleration is checked in the 3dfx Voodoo Graphics control tab in the Display Properties dialog.
They all are on its giveing me a fail result stil.
See if the card even works.
Try DOS and Tomb Raider 3dfx demo. If that doesn't work, then you got some hardware issue.
I think its a hardware issue, i mean, i treid the fighting demo from the folders, that one ran fine, and i could not get the rest to work unfortanly..
does it need a specific pci slot?
You should try every PCI slot.
You should try a Glide DOS game in pure DOS, it should work. Also, sometimes Voodoo cards can be picky about slots
Maybe it would need slot 2 or 3?
wrote:I have recently got the card itself along with patch cable and im wondering if its possible to find the drivers?
Did you Google?
There are heaps of 3Dfx driver resources out there.
www.3dfxzone.it www.falconfly.de for starters.
Phil's site is good, and has a more "Guide to..." approach.
Also there's a certain drivers site... can't quite remember the name.... Vo-something? hmmmmm......... 😉
you mean the vogons driver side 😜
