Best VGA Card for 386
Reply 21 of 60, by weldum
We'll see, because I have an AMD 5x86 who needs VGA.
It will perform better if I put 256kb of cache on the 386? Now it has 128kb.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 22 of 60, by 386SX
In my Am386DX-40 the 256Kbyte helped a bit the general performance but I thought better. I would like to put a Mach64 ISA on it but they costs too much.
Reply 23 of 60, by kixs
You'll get around 3-5% performance increase with 256KB cache. Also take a look at BIOS optimizations - cache read/write wait states, dram refresh, ISA dividers...
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 24 of 60, by dirkmirk
kixs wrote:
- S3 801, 924...
I have the 924, slow as a dog in dos, got 11fps for 3Dbench with a DX40.
Reply 26 of 60, by vlask
dirkmirk wrote:
kixs wrote:
- S3 801, 924...
All vision S3 cards 8xx, 9xx are GUI accelerators and DOS speed wasnt priority. These might be good for Win+higher resolutions, but not for DOS. They all sucks in DOS. Trio chips got DOS speed improvements, but i think theres only VL-Bus versions of Trio.
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 27 of 60, by kixs
S3 801 is just fine in DOS. Pretty sure it's somewhere around the ET4000. I agree on 9XX.
Reply 28 of 60, by vetz
What are you talking about? The ISA versions? The VL-bus versions of Vision864 and 868 (DRAM) are just as quick as ET4000/W32p in DOS. It's one of the best allround cards you can get in a 486.
Reply 29 of 60, by weldum
how do I know when a cache chip is real or fake?
the chips that I want to put in the 386 come from a pcchips 486 motherboard. they were in sockets and looks like real ones.
Reply 30 of 60, by kixs
Fake were soldered on the motherboard. If you have socketed ones, they should be OK.
Reply 31 of 60, by weldum
and what is TagRAM chip? how do I know if I have to change it? The 486 mb has 9 chips, and the 386 has 4 + tagram (8 cache sockets).
it'll be a problem if I use one of the standard cache chip as tagram?
The tagram is 8x64, the cache chips are 8x256
Reply 33 of 60, by vlask
Good luck finding 386 motheboard with VL-Bus. Early ISA S3 cards are slow in DOS compared to Cirrus or WD.....He needs ISA card, not VLB.
Reply 34 of 60, by weldum
How does the trident 9680 pci comes against the trident 8900d and the cirrus logic 5420? Is better? Is for a 586
Reply 35 of 60, by kixs
For PCI use some S3, Matrox or Tseng.
Trident 9680 PCI is of course much better than 8900D or CL-5420.
Reply 36 of 60, by vlask
Why im doin that benchmarks, when noone watching them? 😒
Try this - http://www.vgamuseum.info/index.php/benchmarks/quake-320 All 3 cards are there...
8900D - 13,7
5420 - 36,2
9680 - 67,2
PCI is always better except few very early cards....(Matrox Impression, Ultima, Weitek...)
Reply 37 of 60, by 386_junkie
Not always... I've come across some fake socket cache.
Best way to check is run CACHECHK with the socket cache installed. This program will help to determine, if the cache can be seen it is real... if it can't be seen and the system seems not to have cache when it is plugged in... it's likely to be fake.
Reply 38 of 60, by weldum
well, the 586 has fake cache with slot for asynchronous sram. the mb is a pcchips m919.
now, I'll be testing every card I have with the BENCH.zip from Phil's Ultimate VGA Benchmark Database Project.
maybe later I post the results here,
Reply 39 of 60, by matze79
kixs wrote:
soviet conscript wrote:
kixs wrote:
. Usually 8900D are slow.
I seem to recall a member here performing benchmarks and the 8900D coming out very near the top which is surprising from a card from Trident. the D revision has something to do with the memory where its quite a fast DOS card.
Like I said... some are slow, some are fast. I have both. Fast are almost as fast as ET4000.
But you can get the 8900D-R with 32bit RAM, it's fast like a ET4000.
A 386 is CPU limited. You will see no difference, even if you run a DRx2 33/66Mhz
