Reply 20 of 58, by Cloudschatze
DracoNihil wrote:
Why is that missing the snare drums in the beginning?
I'll have to look at the MIDI file, but it could be something as simple as a disconnect between the MIDI note for the snare drum, and the key mapping defined for the Rsnare sample in the SoundFont bank (subsequently resulting in silence).
I began looking into the discrepancies between the PSX and AWE versions a few years back, intending to fix some of the issues, but lack of time/desire stymied the effort. If you can be specific regarding examples of where "the MIDI music barely matches the original PSX version," I can start there.
Reply 21 of 58, by DracoNihil
I'd love to help out tracking down these discrepancies I noticed a long time ago but I don't have the SF2's nor the AWE .MID files to take a look at again... But in particular with OWA the "percussive smash" or whatever it's called should be pitch bending upward fast and high whenever it's played yet it just plays a flat base note of it everytime. Also instead of a timpani drum in the beginning, it appears to be playing a taiko drum...
I also think the horn and string stabs need to be of a different octave, I'm just going off of how this sounds though.
I do remember going through the SF2 files back when I still had them and noticing the instrument mappings were really weird and appeared to have missing instruments altogether... I often thought the missing instruments were in the other SF2 files and they had to be somehow sideloaded properly.
― Κυνικός Δράκων
Reply 22 of 58, by dnewhous
I wish I could upload screen captures.
The main midi file for FF7 PC is FF7.sf2 which is 3575 kb. You can examine the contents using Awave Studio.
FF7 configuration:
There are 2 drop down menus on the MIDI tab. One is MIDI Driver - and the default option is the Microsoft GS Wavetable synth that comes with Windows.
The other is MIDI Data, which defaults to General MIDI. The other options are Soundfont MIDI and Yamaha XG MIDI. If you are using the Microsoft GS Wavetable synth and you use Soundfont or XG MIDI, the instruments should sound strange.
I am pasting a description of FF7.sf2. It looks neither GM nor XG.
Size: 3.49 MB (3660750 bytes)
size on disk: 3.49 MB (3661824 bytes)
instrument 000: Acoustic Grand Piano
instrument 001: Bright Acoustic Piano
instrument 002: Dulcimer21
instrument 003: Piano2
instrument 004: Epiano
instrument 005:
instrument 006:
instrument 007:
instrument 008: Celesta
instrument 009:
instrument 010:
instrument 011:
instrument 012:
instrument 013:
instrument 014: Tubular Bell
instrument 015: Dulcimer
instrument 016: Hammond Organ
instrument 017: B3
instrument 018:
instrument 019:
instrument 020:
instrument 021:
instrument 022:
instrument 023:
instrument 024: Acoustic Guitar-nylon
instrument 025: Acoustic Guitar-steel
instrument 026:
instrument 027: Electric Guitar-clean
instrument 028: Muted Guitar
instrument 029:
instrument 030: Distortion Guitar
instrument 031:
instrument 032: Kbass
instrument 033: Electric Bass -finge
instrument 034:
instrument 035:
instrument 036:
instrument 037:
instrument 038:
instrument 039: Synth Bass 2
instrument 040:
instrument 041:
instrument 042:
instrument 043:
instrument 044:
instrument 045: Pizzicato Strings
instrument 046: Orchestral Harp
instrument 047: Timpani
instrument 048: Strings
instrument 049: Strings2
instrument 050: Hstr1 - SynthStrings
instrument 051: Laments
instrument 052: Choir
instrument 053:
instrument 054: Gstr2 - Voice
instrument 055: Orchestra Hit
instrument 056: Trumpet
instrument 057: Trombone
instrument 058: Tuba
instrument 059:
instrument 060: French Horn
instrument 061:
instrument 062: Prophet1
instrument 063:
instrument 064: Acoustic Grand Piano
instrument 065:
instrument 066:
instrument 067:
instrument 068: Oboe
instrument 069:
instrument 070: Basson
instrument 071: Clarinet
instrument 072:
instrument 073:
instrument 074:
instrument 075:
instrument 076:
instrument 077:
instrument 078: Whistle
instrument 079: Ocarina
instrument 080: Pulse5
instrument 081: Lead2 (sawtooth)
instrument 082:
instrument 083:
instrument 084: Lead5 (Charang)
instrument 085: MoveDuty10
instrument 086:
instrument 087:
instrument 088:
instrument 089:
instrument 090: Pad 3 (polysynth)
instrument 091: Source5
instrument 092:
instrument 093:
instrument 094:
instrument 095:
instrument 096:
instrument 097:
instrument 098:
instrument 099:
instrument 100: Flat Piano
instrument 101:
instrument 102:
instrument 103:
instrument 104:
instrument 105: Banjo
instrument 106:
instrument 107:
instrument 108:
instrument 109:
instrument 110: Fiddle
instrument 111:
instrument 112:
instrument 113:
instrument 114:
instrument 115: Woodblock
instrument 116: Mdaiko
instrument 117:
instrument 118:
instrument 119: Reverse Cymbal
instrument 120: Guitar Frewt Noise
drumkit 000: FF7
drumkit 001: Battle
drumkit 002: Cinco
drumkit 003: Costa
drumkit 004: Fiddle
drumkit 005: Ketc
drumkit 006: LD
drumkit 007: OA
drumkit 008: Rhythym
drumkit 009: Roll
drumkit 010: Sid2
drumkit 011: Utai
drumkit 012: Dokubo
Daniel L Newhouse
Reply 23 of 58, by dnewhous
The instructions say that the soundfont is for AWE cards, but it is clear from the release date and the file extension that it was meant for the Soundblaster Live! Alright, AWE cards (all variants) used sbk soundfonts so the instructions for FF7 are kind of not right.
Daniel L Newhouse
Reply 24 of 58, by leileilol
dnewhous wrote on 2020-07-16, 22:59:
Well...the Live! didn't exist when FF7PC came out (June '98 vs. Aug '98), and again AWE can use sf2 as mentioned before in one of the many ignored posts, and SF2 doesn't imply SBLive at all (the format predates it by several years, at least to 1995)
long live PCem
Debian's fucked
Reply 25 of 58, by Wanderer
FFVII soundfounts have SF2 format, but may not be fully compatible with Live! and later sound blasters, because the sample pool includes some ROM samples.
For a "definitive MIDI thread" I think there is lack of files posted, so here are some links.
Final Fantasy VII SF2 (from the original CD): https://1drv.ms/u/s!App_YLHfwVtdgjoj9ITde4UrKQgk?e=z9PFTe
Final Fantasy VIII SF2 (fan-made/converted): https://1drv.ms/u/s!App_YLHfwVtdgj8OfGld9KBw3aWW?e=V801Gx
Final Fantasy VII MIDI renders (XG version) on Yamaha PSR-640: https://1drv.ms/u/s!App_YLHfwVtdgVfGYZllv4fZQNl1?e=G28fhd
MIDI files:
FF VII: http://mirsoft.info/gmb/music_info.php?id_ele=MTc0MQ==
FF VIII: http://mirsoft.info/gmb/music_info.php?id_ele=MTc0Mw==
Reply 26 of 58, by dnewhous
K, Final Fantasy 8 does have a DLS file, FF8.dls and not a soundfont. The game does not have a MIDI output mode. It does have "DirectMusic port." This is where the MIDI output device is selected and is very much like the Windows MIDI control panel that is no longer with us. The default is "Microsoft Synthesizer." This is the same thing as the "Microsoft GS Wavetable SW Synth" described on the wikipedia.
The contents of the DLS file (Awave changed versions on me, so I don't feel like copying text representation) are XG, comparing to GM.dls. Comparing to the Soniqbear soundfont which is XG, it appears that the drum kits are really custom. So, it is a custom XG soundfont. One of the custom drum kits is chococredit percussion. It was meant to be used with a Turtle Beach Santa Cruz because that is the only soundcard that ever used DLS. Currently, the outboard Roland Integra 7 uses DLS but that is an awful lot of money for a game that is now remastered on Steam. Now I will investigate whether the reverb works with the Microsoft synthesizer.
That didn't work, the game did not launch on my Windows 10 machine. One of the checkboxes for hardware support, 8 bit textures, is not checked which means my video card isn't good enough.
There is a checkbox for reverb. AFAIK reverb will not work with the Microsoft Synthesizer and did work with the Santa Cruz synth.
Daniel L Newhouse
Reply 27 of 58, by dnewhous
Text description by Awave Studio v11.3, Copyright 1993, 2020 FMJ-Software
Source file: C:\Program Files (x86)\Square Soft, Inc\FINAL FANTASY VIII\Data\Music\dmusic\FF8.dls
Source type: DownLoadable Sounds level 1
Item - collection: FF8 Instruments
Copyright: Copyright 1998 Yamaha Corp.
Instrument list:
d-127-000-048 Symphony Kit
d-127-000-000 Standard Kit
d-001-001-110 **p114-Chococredit Percussion
d-001-001-085 **p085-Esta Percussion
d-001-001-080 **p080-Spy Percussion
d-001-001-077 **p077-lasdun
d-001-001-076 **p076-Bossbat2 Percussion
d-001-001-036 **p036-Majo Percussion
d-001-001-023 **p023-Parade Percussion
d-001-001-017 **p017-Joriku Percussion
d-000-000-000 *Standard_GS
m-024-000-004 *60sEl.P
m-001-002-053 **110-chord
m-001-001-115 **Tap
m-001-001-105 **070-Jew_Harp
m-001-001-092 **091-film2
m-001-001-091 **091-Filmreel
m-001-001-053 **081-Ohhs
m-001-001-052 **110-Ahhh
m-001-001-047 **017-Timpani
m-001-001-034 **080-Bass Guitar
m-001-001-030 **076-DGuitar
m-001-001-029 **076-OGuitar
m-001-001-028 **076-MuteGuitar
m-001-001-026 **080-eguitar
m-001-001-012 **110-Karazi
m-001-001-008 **036-Femal Choir
m-001-001-000 **Low Piano
m-001-000-031 **Guitar Harmonics
m-000-065-016 70sDrOr2
m-000-064-010 Orgel
m-000-041-049 Kingdom
m-000-035-019 +ChurOrg2
m-000-032-004 Chor.EP1
m-000-006-039 MelloSB1
m-000-003-048 S.Strngs
m-000-001-008 **023-Choir
m-000-001-003 *RevCymbl
m-000-001-002 *Syn.Drum
m-000-001-001 BritPnoK
m-000-001-000 *MelodTom
m-000-000-127 Sfx_Gunshot
m-000-000-126 Sfx_Applause
m-000-000-125 Sfx_Helicptr
m-000-000-124 Telphone
m-000-000-123 *WoodBlok
m-000-000-122 Sfx_Seashore
m-000-000-121 BrthNoiz
m-000-000-120 Sfx_FretNoiz
m-000-000-119 RevCymbl
m-000-000-118 Syn.Drum
…Show last 1078 lines
m-000-000-117	MelodTom
m-000-000-116 +TaikoDrm
m-000-000-115 +WoodBlok
m-000-000-114 +SteelDrm
m-000-000-113 Agogo
m-000-000-112 TnklBell
m-000-000-111 Shanai
m-000-000-110 Fiddle
m-000-000-109 Bagpipe
m-000-000-108 Kalimba
m-000-000-107 Koto
m-000-000-106 Shamisen
m-000-000-105 Banjo
m-000-000-104 +Sitar
m-000-000-103 Sci-Fi
m-000-000-102 Echoes
m-000-000-101 Goblins
m-000-000-100 Bright
m-000-000-099 Atmosphr
m-000-000-098 Crystal
m-000-000-097 SoundTrk
m-000-000-096 Rain
m-000-000-095 SweepPad
m-000-000-094 Halo Pad
m-000-000-093 MetalPad
m-000-000-092 BowedPad
m-000-000-091 ChoirPad
m-000-000-090 PolySyPd
m-000-000-089 Warm Pad
m-000-000-088 +NewAgePd.New
m-000-000-087 Bass &Ld
m-000-000-086 Fifth Ld
m-000-000-085 Voice Ld
m-000-000-084 CharanLd
m-000-000-083 Chiff Ld
m-000-000-082 CaliopLd
m-000-000-081 +Saw.Lead
m-000-000-080 +SquareLd
m-000-000-079 +Ocarina
m-000-000-078 Whistle
m-000-000-077 Shakhchi
m-000-000-076 Bottle
m-000-000-075 +PanFlute
m-000-000-074 Recorder
m-000-000-073 +Flute
m-000-000-072 +Piccolo
m-000-000-071 +Clarinet
m-000-000-070 +Bassoon
m-000-000-069 Eng.Horn
m-000-000-068 +Oboe
m-000-000-067 Bari.Sax
m-000-000-066 TenorSax
m-000-000-065 Alto Sax
m-000-000-064 SprnoSax
m-000-000-063 SynBras2
m-000-000-062 SynBras1
m-000-000-061 BrasSect
m-000-000-060 +Fr.Horn
m-000-000-059 Mute.Trp
m-000-000-058 +Tuba
m-000-000-057 +Trombone
m-000-000-056 +Trumpet
m-000-000-055 +Orch.Hit
m-000-000-054 SynVoice
m-000-000-053 +VoiceOoh
m-000-000-052 +ChoirAah
m-000-000-051 Syn.Str2
m-000-000-050 +Syn.Str1
m-000-000-049 Strings2
m-000-000-048 +Strings1
m-000-000-047 +Timpani
m-000-000-046 +Harp
m-000-000-045 +Pizz.Str
m-000-000-044 Trem.Str
m-000-000-043 +Contrabs
m-000-000-042 +Cello
m-000-000-041 +Viola
m-000-000-040 +Violin
m-000-000-039 +SynBass2
m-000-000-038 +SynBass1
m-000-000-037 SlapBas2
m-000-000-036 SlapBas1
m-000-000-035 +Fretless
m-000-000-034 PickBass
m-000-000-033 FngrBass
m-000-000-032 +Aco.Bass
m-000-000-031 GtrHarmo
m-000-000-030 +Dist.Gtr
m-000-000-029 Ovrdrive
m-000-000-028 Mute.Gtr
m-000-000-027 +CleanGtr
m-000-000-026 Jazz Gtr
m-000-000-025 SteelGtr
m-000-000-024 NylonGtr
m-000-000-023 TangoAcd
m-000-000-022 Harmnica
m-000-000-021 +Acordion
m-000-000-020 ReedOrgn
m-000-000-019 ChrchOrg
m-000-000-018 +RockOrgn
m-000-000-017 +PercOrgn
m-000-000-016 +DrawOrgn
m-000-000-015 +Dulcimer
m-000-000-014 +TubulBel
m-000-000-013 Xylophon
m-000-000-012 +Marimba
m-000-000-011 Vibes
m-000-000-010 +MusicBox
m-000-000-009 +Glocken
m-000-000-008 +Celesta
m-000-000-007 +Clavi.
m-000-000-006 +Harpsi.
m-000-000-005 E.Piano2
m-000-000-004 +E.Piano1
m-000-000-003 HnkyTonk
m-000-000-002 E.Grand
m-000-000-001 BritePno
m-000-000-000 +GrandPno
Instrument details:
Location Name Layer Key range Vel range Root key Waveform Samplerate Length Save as
d-127-000-048 Symphony Kit 0 C#0..C#0 0..127 C0 PC_SUR_HT_X_086_D_5_M_3_SX1M.L0 22050 8588 PCM 8-bit
D0..D0 0..127 A#0 PC_SUR_HT_X_086_D_5_M_3_SX1M.L0 22050 8588 PCM 8-bit
D#0..D#0 0..127 A#0 HIGH_Q_S.086.L08 22050 1074 PCM 8-bit
E0..E0 0..127 F1 PC_WHP_SL_S_028_E_0_M_C_0_DB8x. 22050 2100 PCM 8-bit
F0..F0 0..127 E0 PC_SCR_SE_L_028_E_0_M_0_0.L08 22050 4812 PCM 8-bit
F#0..F#0 0..127 A#0 PC_SCR_SE_L_028_E_0_M_0_0.L08 22050 4812 PCM 8-bit
G0..G0 0..127 C#0 PC_FSN_FN_Y_060_C_3_M_0_LZ.L08 22050 1164 PCM 8-bit
G#0..G#0 0..127 C-1 SY_P50_PO_T_026_D_0_M_0_TG.L08 22050 1362 PCM 8-bit
A0..A0 0..127 D1 PC_MTR_GS_X_060_C_3_M_0_TG.L08 22050 1284 PCM 8-bit
A#0..A#0 0..127 B0 PC_MTB_GS_X_060_C_3_M_0_SX2M.L0 22050 4766 PCM 8-bit
B0..B0 0..127 A0 SY_P50_PO_T_033_A_0_M_0+5.L08 22050 16 PCM 8-bit
C1..C1 0..127 F#0 SY_P50_PO_T_033_A_0_M_0+5.L08 22050 16 PCM 8-bit
C#1..C#1 0..127 C2 BRUSH041.041S.L08 22050 2806 PCM 8-bit
D1..D1 0..127 C#2 DR_SBS_NA_T_060_C_3_M_0_LZ.L08 22050 7288 PCM 8-bit
D#1..D#1 0..127 C2 BRUSH334.334S.L08 22050 2346 PCM 8-bit
E1..E1 0..127 D#2 DR_SBS_NA_T_060_C_3_M_0_LZ.L08 22050 7288 PCM 8-bit
F1..F1 0..127 C#2 DR_SD1_RO_T_060_C_3_M_0_LZ.L08 22050 9590 PCM 8-bit
F#1..F#1 0..127 A#1 CASTANET.363.L08 22050 1110 PCM 8-bit
G1..G1 0..127 D#2 SNARE_T0.341.L08 22050 4636 PCM 8-bit
G#1..G#1 0..127 D#2 STICK_SQ.339S.L08 22050 1414 PCM 8-bit
A1..A1 0..127 F2 BASSD043.043S.L08 22050 2544 PCM 8-bit
A#1..A#1 0..127 F#2 RIM_OPE_.338S.L08 22050 3592 PCM 8-bit
B1..B1 0..127 G2 DR_BDO_NA_T_060_C_3_M_0_LZ.L08 22050 9260 PCM 8-bit
C2..C2 0..127 A#2 DR_BDO_NA_T_060_C_3_M_0_LZ.L08 22050 9260 PCM 8-bit
C#2..C#2 0..127 G#2 RIM_JR__.311S.L08 22050 1510 PCM 8-bit
D2..D2 0..127 G2 SNARE_T0.341.L08 22050 4636 PCM 8-bit
D#2..D#2 0..127 C#3 HANDC156.156S.L08 22050 1760 PCM 8-bit
E2..E2 0..127 A2 SNARE_T0.341.L08 22050 4636 PCM 8-bit
F2..F2 0..127 F4 DR_TMJ_NA_T_060_C_3_M_0_LZ.L08 22050 1836 PCM 8-bit
F#2..F#2 0..127 E2 HH_CLOS0.304S.L08 22050 2526 PCM 8-bit
G2..G2 0..127 D#4 DR_TMJ_NA_T_060_C_3_M_0_LZ.L08 22050 1836 PCM 8-bit
G#2..G#2 0..127 G#2 HH_FOOT_.305S.L08 22050 1512 PCM 8-bit
A2..A2 0..127 D4 DR_TMJ_NA_T_060_C_3_M_0_LZ.L08 22050 1836 PCM 8-bit
A#2..A#2 0..127 C3 HH_OP085.085S.L08 22050 11506 PCM 8-bit
B2..B2 0..127 C4 DR_TMJ_NA_T_060_C_3_M_0_LZ.L08 22050 1836 PCM 8-bit
C3..C3 0..127 A#3 DR_TMJ_NA_T_060_C_3_M_0_LZ.L08 22050 1836 PCM 8-bit
C#3..C#3 0..127 F3 MARCH089.089S.L08 22050 10008 PCM 8-bit
D3..D3 0..127 G3 DR_TMJ_NA_T_060_C_3_M_0_LZ.L08 22050 1836 PCM 8-bit
D#3..D#3 0..127 G3 MARCH089.089S.L08 22050 10008 PCM 8-bit
E3..E3 0..127 C#4 CHINA081.081S.L08 22050 10180 PCM 8-bit
F3..F3 0..127 E3 RIDE_362.DB8x.L08 22050 10480 PCM 8-bit
F#3..F#3 0..127 E3 TAMBO093.093S.L08 22050 5004 PCM 8-bit
G3..G3 0..127 F3 DR_CCR_NA_T_069_A_3_M_0_LZ.L08 22050 13134 PCM 8-bit
G#3..G#3 0..127 C#4 COWBELL_.300S.L08 22050 1572 PCM 8-bit
A3..A3 0..127 A#3 MARCH089.089S.L08 22050 10008 PCM 8-bit
A#3..A#3 0..127 E4 PC_VIB_NA_T_060_C_3_M_0_LZ.L08 22050 5508 PCM 8-bit
B3..B3 0..127 C4 MARCH089.089S.L08 22050 10008 PCM 8-bit
C4..C4 0..127 B4 BONGO294.294S.L08 22050 1220 PCM 8-bit
C#4..C#4 0..127 C5 BONGO295.295S.L08 22050 1900 PCM 8-bit
D4..D4 0..127 A#4 CONGA_M_.299.L08 22050 408 PCM 8-bit
D#4..D#4 0..127 C5 CONGA_L_.298S.L08 22050 2270 PCM 8-bit
E4..E4 0..127 F#5 CONGA_L_.298S.L08 22050 2270 PCM 8-bit
F4..F4 0..127 D#5 TIMBALE0.314S.L08 22050 4838 PCM 8-bit
F#4..F#4 0..127 C6 TIMBALE0.314S.L08 22050 4838 PCM 8-bit
G4..G4 0..127 B4 AGOGO_SQ.285S.L08 22050 3648 PCM 8-bit
G#4..G#4 0..127 F5 AGOGO_SQ.285S.L08 22050 3648 PCM 8-bit
A4..A4 0..127 G#4 CABASA_S.296S.L08 22050 1158 PCM 8-bit
A#4..A#4 0..127 F#3 MARAC307.307S.L08 22050 1814 PCM 8-bit
B4..B4 0..127 G5 WHISTLE_.346.L08 22050 850 PCM 8-bit
C5..C5 0..127 A#5 WHISTLE_.346.L08 22050 850 PCM 8-bit
C#5..C#5 0..127 D4 GUIRO_SH.032S.L08 22050 1538 PCM 8-bit
D5..D5 0..127 G#5 GUILO_SQ.309S.L08 22050 3392 PCM 8-bit
D#5..D#5 0..127 D#5 CLAVES_S.297.L08 22050 954 PCM 8-bit
E5..E5 0..127 F#5 WOODBLOC.284.L08 22050 682 PCM 8-bit
F5..F5 0..127 C#6 WOODBLOC.284.L08 22050 682 PCM 8-bit
F#5..F#5 0..127 A5 CUICA_T_.302S.L08 22050 1336 PCM 8-bit
G5..G5 0..127 E7 CUICA_T_.302S.L08 22050 1336 PCM 8-bit
G#5..G#5 0..127 A4 TRI_OPEN.345S.L08 22050 11368 PCM 8-bit
A5..A5 0..127 A4 TRI_OPEN.345S.L08 22050 11368 PCM 8-bit
A#5..A#5 0..127 F#5 CABAS270.270S.L08 22050 1192 PCM 8-bit
B5..B5 0..127 C#6 BELL(342.342S.L08 22050 5730 PCM 8-bit
C6..C6 0..127 D#6 PC_BEL_NA_T_060_C_3_M_0_LZ.L08 22050 11878 PCM 8-bit
d-127-000-000 Standard Kit 0 C#0..C#0 0..127 C0 PC_SUR_HT_X_086_D_5_M_3_SX1M.L0 22050 8588 PCM 8-bit
G1..G1 0..127 A#1 SNARE_DW.049S.L08 22050 4328 PCM 8-bit
A1..A1 0..127 E2 BASSD043.043S.L08 22050 2544 PCM 8-bit
B1..B1 0..127 E2 BDM2D493.493S.L08 22050 2336 PCM 8-bit
C2..C2 0..127 B1 DR_BD1_DR_V_036_C_1_M_0_0.L08 22050 4612 PCM 8-bit
D2..D2 0..127 A1 DR_SD3_DR_S_038_D_1_M_0_0_ya2.L 22050 11804 PCM 8-bit
E2..E2 0..127 A#2 SNARE051.051S.L08 22050 4046 PCM 8-bit
F2..F2 0..127 E3 DR_TMS_01_T_060_C_3_M_0_LZ.L08 22050 5084 PCM 8-bit
G2..G2 0..127 D#3 DR_TMS_01_T_060_C_3_M_0_LZ.L08 22050 5084 PCM 8-bit
A2..A2 0..127 C3 DR_TMS_01_T_060_C_3_M_0_LZ.L08 22050 5084 PCM 8-bit
B2..B2 0..127 A#3 TOM_JR40.215T.DB8x.L08 22050 3374 PCM 8-bit
C3..C3 0..127 G3 TOM_JR40.215T.DB8x.L08 22050 3374 PCM 8-bit
C#3..C#3 0..127 D#3 DR_CCR_NA_T_069_A_3_M_0_LZ.L08 22050 13134 PCM 8-bit
D3..D3 0..127 F3 TOM_JR40.215T.DB8x.L08 22050 3374 PCM 8-bit
D#3..D#3 0..127 E3 RIDE_310.DB8x.L08 22050 10796 PCM 8-bit
A3..A3 0..127 B3 DR_CCR_NA_T_069_A_3_M_0_LZ.L08 22050 13134 PCM 8-bit
B3..B3 0..127 B3 RIDE_310.DB8x.L08 22050 10796 PCM 8-bit
d-001-001-110 **p114-Chococredit Percussion 0 C2..C2 0..0 C2 000114_bass_drum 22050 6976 PCM 16-bit
D2..D2 0..0 D2 000114_snare 22050 3574 PCM 16-bit
D#2..D#2 0..0 D#2 000114_snap 22050 1651 PCM 16-bit
E2..E2 0..0 E2 000114_snare 22050 3574 PCM 16-bit
F#2..F#2 0..0 F#2 000114_hihat 22050 6114 PCM 16-bit
A#2..A#2 0..0 A#2 000114_snare 22050 3574 PCM 16-bit
d-001-001-085 **p085-Esta Percussion 0 E4..E4 0..0 E4 000085_low_conga 44100 11587 PCM 16-bit
G#4..G#4 0..0 G#4 000085_per2 44100 7683 PCM 16-bit
A4..A4 0..0 A4 000085_per3 44100 10275 PCM 16-bit
A#4..A#4 0..0 A#4 000085_per4 44100 5165 PCM 16-bit
G#5..G#5 0..0 G#5 000036_Trianglem (ETHNIC) 44100 2187 PCM 16-bit
A5..A5 0..0 A5 000036_triangle 44100 69490 PCM 16-bit
d-001-001-080 **p080-Spy Percussion 0 F#2..F#2 0..0 F#2 000080_chh 44100 4863 PCM 16-bit
A#2..A#2 0..0 A#2 000080_hihat_o 44100 19202 PCM 16-bit
d-001-001-077 **p077-lasdun 0 F2..F2 0..0 F2 000077_Tdrum 44100 31079 PCM 16-bit
F#4..F#4 0..0 G#3 000077_cowbell 44100 7251 PCM 16-bit
G4..G4 0..0 G#3 000077_cowbell 44100 7251 PCM 16-bit
A#4..A#4 0..0 G#3 000077_cowbell 44100 7251 PCM 16-bit
D#5..D#5 0..0 D#5 000077_Kan 44100 21541 PCM 16-bit
F#5..F#5 0..0 F#6 000077_Doon 44100 46664 PCM 16-bit
d-001-001-076 **p076-Bossbat2 Percussion 0 C2..C2 0..0 C2 000076_Kick2 22050 7365 PCM 16-bit
E2..E2 0..0 E2 000076_Snare1 22050 8948 PCM 16-bit
F2..F2 0..0 F2 000076_Tom 22050 13948 PCM 16-bit
A2..A2 0..0 E2 000076_Tom 22050 13948 PCM 16-bit
C5..C5 0..0 C5 000076_Smalltaiko2 22050 13344 PCM 16-bit
C#5..C#5 0..0 C#5 000076_asiaPer3 22050 3680 PCM 16-bit
D5..D5 0..0 D5 000076_Hh2 22050 5925 PCM 16-bit
D#5..D#5 0..0 D#5 000076_Cymbal3 22050 18433 PCM 16-bit
E5..E5 0..0 E5 000076_Timbale 22050 4871 PCM 16-bit
F5..F5 0..0 F5 000076_Hyoshigi2 22050 4736 PCM 16-bit
F#5..F#5 0..0 F#5 000076_Shimedaiko2 22050 23098 PCM 16-bit
G5..G5 0..0 G5 000076_Wadaiko2 22050 11893 PCM 16-bit
G#5..G#5 0..0 G#5 000076_Hooya 22050 8718 PCM 16-bit
A5..A5 0..0 A5 000076_Hooya 22050 8718 PCM 16-bit
d-001-001-036 **p036-Majo Percussion 0 F4..F4 0..0 F4 000036_bass_drum 44100 21160 PCM 16-bit
d-001-001-023 **p023-Parade Percussion 0 D2..D2 0..0 D2 Sn1ff 44100 16425 PCM 16-bit
F2..F2 0..0 A2 Tom 44100 42018 PCM 16-bit
A2..A2 0..0 A2 Tom 44100 42018 PCM 16-bit
C3..C3 0..0 C2 Tom 44100 42018 PCM 16-bit
E3..E3 0..0 E3 Gong 44100 129606 PCM 16-bit
F#3..F#3 0..0 F#3 tamb 44100 15223 PCM 16-bit
D#4..D#4 0..0 D#4 CongaT 44100 8556 PCM 16-bit
E4..E4 0..0 E4 CongaO 44100 7746 PCM 16-bit
A4..A4 0..0 A4 Castanet 44100 4560 PCM 16-bit
d-001-001-017 **p017-Joriku Percussion 0 B1..B1 0..0 B1 000017_heartbeat 44100 18576 PCM 16-bit
C2..C2 0..0 A3 000017_gran_casa 44100 15692 PCM 16-bit
D2..D2 0..0 D2 000017_snare 44100 15550 PCM 16-bit
A3..A3 0..0 A4 000017_ocym 44100 31670 PCM 16-bit
d-000-000-000 *Standard_GS 0 D#1..D#1 0..127 C2 HIGH_Q_S.086.L08 22050 1074 PCM 8-bit
E1..E1 0..127 D#2 PC_WHP_SL_S_028_E_0_M_C_0_DB8x. 22050 2100 PCM 8-bit
F1..F1 0..127 E1 PC_SCR_SE_L_028_E_0_M_0_0.L08 22050 4812 PCM 8-bit
F#1..F#1 0..127 A#1 PC_SCR_SE_L_028_E_0_M_0_0.L08 22050 4812 PCM 8-bit
G1..G1 0..127 D2 STICK_SQ.339S.L08 22050 1414 PCM 8-bit
G#1..G#1 0..127 C-1 SY_P50_PO_T_026_D_0_M_0_TG.L08 22050 1362 PCM 8-bit
A1..A1 0..127 D2 PC_MTR_GS_X_060_C_3_M_0_TG.L08 22050 1284 PCM 8-bit
A#1..A#1 0..127 B1 PC_MTB_GS_X_060_C_3_M_0_SX2M.L0 22050 4766 PCM 8-bit
D2..D2 0..127 A#1 DR_SD3_DR_S_038_D_1_M_0_0_ya2.L 22050 11804 PCM 8-bit
E2..E2 0..127 A2 SNARE051.051S.L08 22050 4046 PCM 8-bit
B4..B4 0..127 G5 PC_SWH_HI_T_060_C_3_M_H_DLS.L08 22050 850 PCM 8-bit
C5..C5 0..127 A#5 PC_SWH_LO_T_060_C_3_M_H_DLS.L08 22050 4234 PCM 8-bit
C#6..C#6 0..127 F#6 CASTANET.363.L08 22050 1110 PCM 8-bit
D6..D6 0..127 C6 PC_SUR_HT_X_086_D_5_M_3_SX1M.L0 22050 8588 PCM 8-bit
D#6..D#6 0..127 B6 PC_SUR_HT_X_086_D_5_M_3_SX1M.L0 22050 8588 PCM 8-bit
m-024-000-004 *60sEl.P 0 C-1..F6 1..127 D4 VLNSG#50_F2_DL.L08 22050 80 PCM 8-bit
F#6..B6 1..127 D#3 EP_DX282.282.L08 22050 148 PCM 8-bit
C7..C8 1..127 F5 SY_P10_NA_M_114_F#7_M_O_MUII.L0 22050 36 PCM 8-bit
C#8..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-001-002-053 **110-chord 0 C-1..G9 0..0 C4 000114_chord 22050 4468 PCM 16-bit
m-001-001-115 **Tap 0 C-1..G9 0..0 A3 tap 22050 4477 PCM 16-bit
m-001-001-105 **070-Jew_Harp 0 C-1..D4 0..0 F3 000070_Jew_harp_4F 44100 32896 PCM 16-bit
D#4..D#7 0..0 F5 000070_Jew_harp_5F 44100 17088 PCM 16-bit
m-001-001-092 **091-film2 0 C-1..G9 0..0 C2 filmreel2 22050 39169 PCM 16-bit
m-001-001-091 **091-Filmreel 0 C-1..G9 0..0 C2 filmreel 22050 111617 PCM 16-bit
m-001-001-053 **081-Ohhs 0 C4..C4 0..0 C4 000081_chorus 44100 249544 PCM 16-bit
m-001-001-052 **110-Ahhh 0 C-1..F#4 0..0 C4 000114_ahhh_5C 22050 30850 PCM 16-bit
G4..G9 0..0 C5 000114_ahhh_6C 22050 25072 PCM 16-bit
m-001-001-047 **017-Timpani 0 C-1..G9 0..0 E2 000017_Timpani 44100 94976 PCM 16-bit
m-001-001-034 **080-Bass Guitar 0 C-1..B6 0..0 E1 000080_bass 44100 23816 PCM 16-bit
m-001-001-030 **076-DGuitar 0 C-1..G9 0..0 F2 000076_DGuitar 22050 32127 PCM 16-bit
m-001-001-029 **076-OGuitar 0 C-1..D6 0..0 F2 000076_OGuitar 22050 18603 PCM 16-bit
m-001-001-028 **076-MuteGuitar 0 C-1..G9 0..0 C3 000076_MuteGuitar 22050 3456 PCM 16-bit
m-001-001-026 **080-eguitar 0 C4..C4 0..0 C4 000080_guitar4 44100 125279 PCM 16-bit
D4..D4 0..0 D4 000080_guitar2 44100 117856 PCM 16-bit
E4..E4 0..0 E4 000080_guitar3 44100 48984 PCM 16-bit
F4..F4 0..0 F4 000080_guitar1 44100 25433 PCM 16-bit
m-001-001-012 **110-Karazi 0 C-1..D4 0..0 D4 000114_kazari1_5D 22050 7042 PCM 16-bit
D#4..G9 0..0 F#4 000114_kazari2_5Fs 22050 5333 PCM 16-bit
m-001-001-008 **036-Femal Choir 0 C4..C4 0..0 C4 000036_fchorus1 44100 57180 PCM 16-bit
D4..D4 0..0 D4 000036_fchorus2 44100 51201 PCM 16-bit
E4..E4 0..0 E4 000036_fchorus3 44100 53425 PCM 16-bit
G4..G4 0..0 G4 000036_fchorus4 44100 51731 PCM 16-bit
m-001-001-000 **Low Piano 0 C-1..G9 0..0 A2 000036_low_piano 44100 104039 PCM 16-bit
m-001-000-031 **Guitar Harmonics 0 C-1..F#5 0..0 C5 harm_C6 44100 62576 PCM 16-bit
G5..G9 0..0 C6 harm_C7 44100 47616 PCM 16-bit
m-000-065-016 70sDrOr2 0 C-1..D#6 1..127 C4 065/01770sDrOr2.3_C.HC.L08 22050 174 PCM 8-bit
E6..D7 1..127 C4 065/01770sDrOr2.3_C.HC.L08 22050 174 PCM 8-bit
D#7..C8 1..127 C4 037/018PercOr2.3_C.L08 22050 2734 PCM 8-bit
C#8..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_1 22050 445 PCM 16-bit
m-000-064-010 Orgel 0 C-1..C#4 1..127 C4 011MusicBox.3_C.L08 22050 1428 PCM 8-bit
D4..F#6 1..127 C5 011MusicBox.4_C.L08 22050 1198 PCM 8-bit
G6..A#6 1..127 C#7 011MusicBox.6_C.L08 22050 1044 PCM 8-bit
B6..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-041-049 Kingdom 0 C-1..G#6 1..127 A3 ST_STE_02_T_059_B_2_M_0_LZ.L08 22050 18312 PCM 8-bit
A6..C#7 1..127 C#6 TRM_STR_.214.L08 22050 9554 PCM 8-bit
D7..G9 1..127 G#4 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-035-019 +ChurOrg2 0 C-1..A6 1..127 G#4 PIPE_ORG.079.L08 22050 4858 PCM 8-bit
A#6..G7 1..127 E7 KY_ACC_NA_T_072_C_4_M_0_LZ.L08 22050 6326 PCM 8-bit
G#7..F9 1..127 E7 ACCOR230.230.L08 22050 4708 PCM 8-bit
F#9..G9 1..127 G#6 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-032-004 Chor.EP1 0 C-1..A2 1..127 C#3 EP_RHO_NA_T_045_A_1_M_0_LZ.L08 22050 318 PCM 8-bit
A#2..C#3 1..127 D#3 EP_RHO_NA_T_048_C_2_M_0_LZ.L08 22050 286 PCM 8-bit
D3..F3 1..127 G3 RHODE266.266.L08 22050 180 PCM 8-bit
F#3..A3 1..127 A#3 EP_RHO_NA_T_055_G_2_M_0_LZ.L08 22050 370 PCM 8-bit
A#3..C4 1..127 D4 EP_RHO_NA_T_059_B_2_M_0_LZ.L08 22050 128 PCM 8-bit
C#4..E4 1..127 F4 RHODE267.267.L08 22050 68 PCM 8-bit
F4..C5 1..127 B4 EP_RHO_NA_T_069_A_3_M_0_LZ.L08 22050 144 PCM 8-bit
C#5..A#5 1..127 F5 RHODE104.104.L08 22050 114 PCM 8-bit
B5..G7 1..127 A#5 EP_RHO_NA_T_086_D_5_M_0_LZ.L08 22050 84 PCM 8-bit
G#7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-006-039 MelloSB1 0 C-1..B5 1..127 C2 006/040MelloSBa.1_C 22050 6149 PCM 16-bit
C6..A6 1..127 G3 SAW_5F#0.169.L08 22050 116 PCM 8-bit
A#6..F#7 1..127 C#4 SAW_6C_0.170.L08 22050 84 PCM 8-bit
G7..G9 1..127 C#5 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-003-048 S.Strngs 0 C-1..E6 1..127 F4 ST_STE_01_T_060_C_3_M_0_LZ.L08 22050 16906 PCM 8-bit
F6..C#7 1..127 C#6 TRM_STR_.214.L08 22050 9554 PCM 8-bit
m-000-001-008 **023-Choir 0 C4..C4 0..0 C4 Cho1 44100 47227 PCM 16-bit
C#4..C#4 0..0 C#4 Cho2 44100 40436 PCM 16-bit
D4..D4 0..0 D4 Cho3 44100 46297 PCM 16-bit
D#4..D#4 0..0 D#4 Cho4 44100 38474 PCM 16-bit
E4..E4 0..0 E4 Cho5 44100 48801 PCM 16-bit
F4..F4 0..0 F4 Cho6 44100 46180 PCM 16-bit
F#4..F#4 0..0 F#4 Cho7 44100 48464 PCM 16-bit
G4..G4 0..0 G4 Cho8 44100 40924 PCM 16-bit
G#4..G#4 0..0 G#4 Cho9 44100 46348 PCM 16-bit
A4..A4 0..0 A4 Cho10 44100 43529 PCM 16-bit
A#4..A#4 0..0 A#4 Cho11 44100 46405 PCM 16-bit
B4..B4 0..0 B4 Cho12 44100 42939 PCM 16-bit
m-000-001-003 *RevCymbl 0 C-1..G9 1..127 G4 DR_CCR_NA_T_069_A_3_M_0_LZ.L08 22050 13134 PCM 8-bit
m-000-001-002 *Syn.Drum 0 C-1..G9 1..127 A4 TOM_T292.292S.L08 22050 3756 PCM 8-bit
m-000-001-001 BritPnoK 0 C-1..D3 1..127 G2 AP_YAM_NA_T_044_G#1_M_0_LZ 22050 36040 PCM 16-bit
D#3..C4 1..127 B2 AP_YAM_NA_T_048_C_2_M_0_MA31W 22050 30846 PCM 16-bit
C#4..A#4 1..127 B3 AP_YAM_NA_T_060_C_3_M_0_LZ 22050 33604 PCM 16-bit
B4..E5 1..127 F#4 AP_YAM_NA_T_067_G_3_M_0_LZ 22050 33465 PCM 16-bit
F5..C6 1..127 B4 AP_YAM_NA_T_072_C_4_M_0_LZ 22050 28120 PCM 16-bit
C#6..E7 1..127 F5 AP_YAM_NA_T_078_F#4_M_0_LZ 22050 21238 PCM 16-bit
F7..E8 1..127 C#6 AP_YAM_NA_T_086_D_5_M_0_MA31W 22050 8874 PCM 16-bit
F8..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-001-000 *MelodTom 0 C-1..G9 1..127 A4 TOM_JR40.215T.DB8x.L08 22050 3374 PCM 8-bit
m-000-000-127 Sfx_Gunshot 0 C-1..G9 1..127 F#5 GUNSHOT_.507S.L08 22050 3576 PCM 8-bit
m-000-000-126 Sfx_Applause 0 C-1..G9 1..127 D5 APPLAU_T.483S.L08 22050 4984 PCM 8-bit
m-000-000-125 Sfx_Helicptr 0 C-1..G9 1..127 C5 HELI_TG.485S.L08 22050 3764 PCM 8-bit
m-000-000-124 Telphone 0 C-1..G9 1..127 E4 TELEPHO0.359S.L08 22050 4990 PCM 8-bit
m-000-000-123 *WoodBlok 0 C-1..G9 1..127 D5 WOODBLOC.284.L08 22050 682 PCM 8-bit
m-000-000-122 Sfx_Seashore 0 C-1..G9 1..127 D#5 SE_SEA_NA_T_060_C_3_M_0_LZ.L08 22050 10636 PCM 8-bit
m-000-000-121 BrthNoiz 0 C-1..G9 1..127 G#4 SE_BTH_NA_T_060_C_3_M_0_LZ.L08 22050 8490 PCM 8-bit
m-000-000-120 Sfx_FretNoiz 0 C-1..G9 1..127 B4 FRET_NO0.506S.L08 22050 2726 PCM 8-bit
m-000-000-119 RevCymbl 0 C-1..G9 1..127 D4 DR_CCR_NA_T_069_A_3_M_0_LZ.L08 22050 13134 PCM 8-bit
m-000-000-118 Syn.Drum 0 C-1..G9 1..127 G4 TOM_T292.292S.L08 22050 3756 PCM 8-bit
m-000-000-117 MelodTom 0 C-1..G9 1..127 C#4 TOM_JR40.215T.DB8x.L08 22050 3374 PCM 8-bit
m-000-000-116 +TaikoDrm 0 C-1..G9 1..127 F#6 TAIKO_3_.002S.L08 22050 2912 PCM 8-bit
m-000-000-115 +WoodBlok 0 C-1..G9 1..127 C#5 WOODBLOC.284.L08 22050 682 PCM 8-bit
m-000-000-114 +SteelDrm 0 C-1..C8 1..127 G4 TP_SDR_NA_T_078_F#4_M_0_LZ.L08 22050 1306 PCM 8-bit
m-000-000-113 Agogo 0 C-1..G#1 1..127 G#4 VIBE_244.244S.L08 22050 2004 PCM 8-bit
A1..G9 1..127 A5 AGOGO_SQ.285S.L08 22050 3648 PCM 8-bit
m-000-000-112 TnklBell 0 C-1..C2 1..127 C4 115Tinkle.3_C1.L08 22050 2746 PCM 8-bit
C#2..D#6 1..127 B5 115Tinkle.5_C.L08 22050 3980 PCM 8-bit
E6..A#6 1..127 C#8 115Tinkle.7_C.1.L08 22050 662 PCM 8-bit
B6..E7 1..127 C#4 SAW_6C_0.170.L08 22050 84 PCM 8-bit
F7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-111 Shanai 0 C-1..F5 1..127 F2 SHANAI_2.265.L08 22050 258 PCM 8-bit
F#5..F6 1..127 F2 SHANAI_0.409.L08 22050 258 PCM 8-bit
F#6..D7 1..127 A#3 VIOLA467.467.L08 22050 100 PCM 8-bit
D#7..G9 1..127 C#5 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-000-110 Fiddle 0 C-1..A3 1..127 E3 ST_VAS_NA_T_052_E_2_M_0_LZ.L08 22050 1414 PCM 8-bit
A#3..D#4 1..127 B3 ST_VAS_NA_T_058_A#2_M_0_LZ.L08 22050 1504 PCM 8-bit
E4..A4 1..127 F4 VIOLA223.223.L08 22050 1122 PCM 8-bit
A#4..D5 1..127 C#5 VIOLA226.226.L08 22050 1462 PCM 8-bit
D#5..G5 1..127 E5 VIOLA228.228.L08 22050 1424 PCM 8-bit
G#5..C#6 1..127 A#5 ST_VAS_NA_T_081_A_4_M_0_LZ.L08 22050 1268 PCM 8-bit
D6..F6 1..127 A#5 VIOLA358.358.L08 22050 1270 PCM 8-bit
F#6..A6 1..127 A#3 VIOLA401.401.L08 22050 100 PCM 8-bit
A#6..D7 1..127 A#3 VIOLA467.467.L08 22050 100 PCM 8-bit
D#7..G#7 1..127 A#3 VIOLA470.470.L08 22050 100 PCM 8-bit
A7..G9 1..127 C#5 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-000-109 Bagpipe 0 C-1..A3 1..127 C2 FI_BAG_DO_S_070_A#3_M_0_225.L08 22050 684 PCM 8-bit
A#3..D#5 1..127 G4 BAGPI274.DB8x.L08 22050 60 PCM 8-bit
E5..C6 1..127 G2 BAGPIPE0.407.L08 22050 228 PCM 8-bit
C#6..F6 1..127 G2 BAGPIPE0.408.L08 22050 228 PCM 8-bit
F#6..F7 1..127 C#4 SAW_6C_0.170.L08 22050 84 PCM 8-bit
F#7..G9 1..127 C#5 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-000-108 Kalimba 0 C-1..A0 1..127 G3 MARIM000.000S.L08 22050 1782 PCM 8-bit
A#0..A7 1..127 G4 FI_KAL_NA_T_067_G_3_M_0_LZ.L08 22050 2758 PCM 8-bit
A#7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-107 Koto 0 C-1..B4 1..127 G4 KOTO_3_G.256.L08 22050 3336 PCM 8-bit
C5..D6 1..127 D5 KOTO_4_D.257.L08 22050 3454 PCM 8-bit
D#6..G#7 1..127 C6 KOTO_5_C.258.L08 22050 2542 PCM 8-bit
A7..G9 1..127 G4 FI_KAL_NA_T_067_G_3_M_0_LZ.L08 22050 2758 PCM 8-bit
m-000-000-106 Shamisen 0 C-1..E1 1..127 B2 GIBSO233.233S.L08 22050 2882 PCM 8-bit
F1..A#6 1..127 F5 SHAMISEN.268.L08 22050 1070 PCM 8-bit
B6..G9 1..127 G4 FI_KAL_NA_T_067_G_3_M_0_LZ.L08 22050 2758 PCM 8-bit
m-000-000-105 Banjo 0 C-1..E3 1..127 F3 FI_BNJ_NA_T_050_D_2_M_0_LZ.L08 22050 1330 PCM 8-bit
F3..A3 1..127 A#3 BNJO_276.276.L08 22050 628 PCM 8-bit
A#3..C4 1..127 D4 FI_BNJ_NA_T_059_B_2_M_0_LZ.L08 22050 900 PCM 8-bit
C#4..G#4 1..127 A4 FI_BNJ_NA_T_065_F_3_M_0_LZ.L08 22050 844 PCM 8-bit
A4..E5 1..127 F5 BNJO_471.471.L08 22050 574 PCM 8-bit
F5..F7 1..127 C#6 FI_BNJ_NA_T_081_A_4_M_0_LZ.L08 22050 670 PCM 8-bit
m-000-000-104 +Sitar 0 C-1..C#1 1..127 D4 GT_EOD_NA_T_057_A_2_M_0_LZ.L08 22050 2792 PCM 8-bit
D1..E5 1..127 C#5 FI_SIT_NA_T_063_D#3_M_0_LZ.L08 22050 3390 PCM 8-bit
F5..B5 1..127 D#3 FI_DUL_02_T_062_D_3_M_0_LZ.L08 22050 3552 PCM 8-bit
C6..C#7 1..127 D3 SY_PAD_NA_T_072_C_4_M_O_LZ.L08 22050 156 PCM 8-bit
D7..F7 1..127 C#4 SAW_6C_0.170.L08 22050 84 PCM 8-bit
m-000-000-103 Sci-Fi 0 C-1..B6 1..127 C4 100Atomos.3_C.L08 22050 4182 PCM 8-bit
C7..G7 1..127 B5 100Atomos.5_C.L08 22050 1740 PCM 8-bit
m-000-000-102 Echoes 0 C-1..A#5 1..127 A4 SY_GS2_NA_T_068_G#3_M_0_LZ.L08 22050 13072 PCM 8-bit
B5..G9 1..127 G#4 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-000-101 Goblins 0 C-1..A6 1..127 C4 102Goblins.3_C.L08 22050 6488 PCM 8-bit
A#6..G8 1..127 C6 102Goblins.5_C.L08 22050 3252 PCM 8-bit
G#8..G9 1..127 G#4 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-000-100 Bright 0 C-1..G6 1..127 C4 101Bright.3_C.L08 22050 9534 PCM 8-bit
G#6..D7 1..127 B5 089NewAge.5_C.L08 22050 1942 PCM 8-bit
D#7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-099 Atmosphr 0 C-1..B6 1..127 C4 100Atomos.3_C.L08 22050 4182 PCM 8-bit
m-000-000-098 Crystal 0 C-1..A#5 1..127 C4 099Crystal.3_C.L08 22050 5568 PCM 8-bit
B5..A6 1..127 B5 099Crystal.5_C.L08 22050 3098 PCM 8-bit
A#6..C8 1..127 B5 099Crystal.5_C.HC.L08 22050 3098 PCM 8-bit
m-000-000-097 SoundTrk 0 C-1..C6 1..127 C4 098SoundTrack.3_C.L08 22050 13470 PCM 8-bit
C#6..C#7 1..127 B5 098SoundTrack.5_C.L08 22050 3822 PCM 8-bit
m-000-000-096 Rain 0 C-1..C#6 1..127 D4 RAIN_3_C.153.L08 22050 3534 PCM 8-bit
D6..B7 1..127 D6 SE_RAI_NA_T_072_C_5_M_0_DLS.L08 22050 886 PCM 8-bit
C8..G9 1..127 G#4 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-000-095 SweepPad 0 C-1..D#2 1..127 C#1 SAW_B_1_.175.DB8x.L08 22050 642 PCM 8-bit
E2..A2 1..127 G1 SAW_B_1_.176.DB8x.L08 22050 458 PCM 8-bit
A#2..D#3 1..127 C#2 SAW_B_2_.177.DB8x.L08 22050 324 PCM 8-bit
E3..A3 1..127 G2 SAW_B_2_.178.DB8x.L08 22050 230 PCM 8-bit
A#3..D#4 1..127 C#3 SAW_B_3_.179.DB8x.L08 22050 166 PCM 8-bit
E4..A4 1..127 G3 SAW_B_3_.180.DB8x.L08 22050 118 PCM 8-bit
A#4..D#5 1..127 C#4 SAW_B_4_.181.DB8x..L08 22050 84 PCM 8-bit
E5..G#5 1..127 G4 SAW_B_4_.182.DB8x.L08 22050 62 PCM 8-bit
A5..C#6 1..127 C4 SAW_B_50.183.L08 22050 86 PCM 8-bit
D6..F#6 1..127 G3 SAW_B_50.184.L08 22050 116 PCM 8-bit
G6..C7 1..127 C#4 SAW_B_60.185.L08 22050 84 PCM 8-bit
C#7..A7 1..127 C#4 SAW_B_70.186.L08 22050 84 PCM 8-bit
A#7..G9 1..127 C#5 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-000-094 Halo Pad 0 C-1..A#5 1..127 A4 SY_GS2_NA_T_068_G#3_M_0_LZ.L08 22050 13072 PCM 8-bit
B5..C#7 1..127 C#6 TRM_STR_.214.L08 22050 9554 PCM 8-bit
m-000-000-093 MetalPad 0 C-1..C#3 1..127 F3 SYN_A148.148.L08 22050 1590 PCM 8-bit
D3..G#3 1..127 F#3 SY_PAD_NA_T_052_E_2_M_0_LZ.L08 22050 2080 PCM 8-bit
A3..B4 1..127 D4 SY_PAD_NA_T_060_C_3_M_0_LZ.L08 22050 1662 PCM 8-bit
C5..A#5 1..127 D5 SY_PAD_NA_T_072_C_4_M_0_LZ.L08 22050 612 PCM 8-bit
B5..C#6 1..127 D3 SYN_A383.383.L08 22050 156 PCM 8-bit
D6..C#7 1..127 D3 SY_PAD_NA_T_072_C_4_M_O_LZ.L08 22050 156 PCM 8-bit
F#7..C8 1..127 C#5 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-000-092 BowedPad 0 C-1..G6 1..127 G#4 VIBE_244.244S.L08 22050 2004 PCM 8-bit
G#6..F#7 1..127 G4 GLOCK388.388.L08 22050 60 PCM 8-bit
G7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-091 ChoirPad 0 C-1..A#5 1..127 A4 SY_GS2_NA_T_068_G#3_M_0_LZ.L08 22050 13072 PCM 8-bit
m-000-000-090 PolySyPd 0 C-1..D#2 1..127 C#1 SY_P50_01_T_036_C_1_M_0_LZ.L08 22050 646 PCM 8-bit
E2..A2 1..127 G1 SY_P50_01_T_042_F#1_M_0_LZ.L08 22050 458 PCM 8-bit
A#2..D#3 1..127 C#2 SY_P50_01_T_048_C_2_M_0_LZ.L08 22050 324 PCM 8-bit
E3..A3 1..127 G2 SY_P50_01_T_054_F#2_M_0_LZ.L08 22050 232 PCM 8-bit
A#3..D#4 1..127 C#3 SY_P50_01_T_060_C_3_M_0_LZ.L08 22050 166 PCM 8-bit
E4..A4 1..127 G3 SY_P50_01_T_066_F#3_M_0_LZ.L08 22050 118 PCM 8-bit
A#4..D#5 1..127 C#4 SY_P50_01_T_072_C_4_M_0_LZ.L08 22050 86 PCM 8-bit
E5..A5 1..127 G4 SY_P50_01_T_078_F#4_M_0_LZ.L08 22050 62 PCM 8-bit
A#5..D#6 1..127 C5 SY_P50_01_T_084_C_5_M_0_LZ.L08 22050 46 PCM 8-bit
E6..A6 1..127 G3 SAW_5F#0.169.L08 22050 116 PCM 8-bit
A#6..F7 1..127 C#4 SAW_6C_0.170.L08 22050 84 PCM 8-bit
m-000-000-089 Warm Pad 0 C-1..A#6 1..127 A#4 WHISTLE_.500.DB8x.L08 22050 50 PCM 8-bit
m-000-000-088 +NewAgePd.New 0 C-1..D6 1..127 C4 042/099ChorBell.3_C.L08 22050 16220 PCM 8-bit
D#6..A#6 1..127 C6 042/099ChorBell.5_C.L08 22050 4552 PCM 8-bit
B6..G7 1..127 G4 GLOCK388.388.L08 22050 60 PCM 8-bit
m-000-000-087 Bass &Ld 0 C-1..A#5 1..127 C4 088BassLd.3_C.L08 22050 3444 PCM 8-bit
B5..E7 1..127 B5 088BassLd.5_C1.L08 22050 2164 PCM 8-bit
F7..G9 1..127 C#5 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-000-086 Fifth Ld 0 C-1..G#6 1..127 C4 087FifthLd.3_C.L08 22050 3458 PCM 8-bit
A6..F7 1..127 B5 087FifthLd.5_C.L08 22050 180 PCM 8-bit
m-000-000-085 Voice Ld 0 C-1..G6 1..127 C4 086Voice.3_C.L08 22050 11260 PCM 8-bit
G#6..E7 1..127 C6 086Voice.5_C.L08 22050 4380 PCM 8-bit
F7..G9 1..127 G#4 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-000-084 CharanLd 0 C-1..E6 1..127 C4 085Charang.3_C.L08 22050 5138 PCM 8-bit
F6..C#7 1..127 B5 085Charang.5_C.L08 22050 1742 PCM 8-bit
D7..F7 1..127 A#3 VIOLA470.470.L08 22050 100 PCM 8-bit
m-000-000-083 Chiff Ld 0 C-1..C1 1..127 C2 084Chiff.1_C.L08 22050 6564 PCM 8-bit
C#1..B5 1..127 B4 084Chiff.4_C.L08 22050 4958 PCM 8-bit
C6..C#7 1..127 B4 084Chiff.4_C.1.L08 22050 4958 PCM 8-bit
m-000-000-082 CaliopLd 0 C-1..A7 1..127 C4 083Calliope.3_C.L08 22050 6112 PCM 8-bit
m-000-000-081 +Saw.Lead 0 C-1..B3 1..127 F#3 082SawLd.2_F#.H.L08 22050 17734 PCM 8-bit
C4..B4 1..127 F#4 082SawLd.3_F#.H.L08 22050 8990 PCM 8-bit
C5..A#5 1..127 F#5 082SawLd.4_F#.H.L08 22050 4320 PCM 8-bit
B5..G6 1..127 F#6 082SawLd.5_F#.H.L08 22050 2236 PCM 8-bit
G#6..C7 1..127 F#6 082Saw.5_F#.L08 22050 2176 PCM 8-bit
C#7..F#7 1..127 C#4 SAW_6C_0.170.L08 22050 84 PCM 8-bit
m-000-000-080 +SquareLd 0 C-1..B3 1..127 F#3 081Square.2_F#.L08 22050 18208 PCM 8-bit
C4..B4 1..127 F#4 081Square.3_F#.L08 22050 11378 PCM 8-bit
C5..B5 1..127 F#5 081Square.4_F#.L08 22050 5302 PCM 8-bit
C6..C7 1..127 F#6 081Square.5_F#.L08 22050 2712 PCM 8-bit
C#7..C8 1..127 G4 SQR_6F#0.036.L08 22050 60 PCM 8-bit
C#8..G9 1..127 C#5 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-000-079 +Ocarina 0 C-1..B0 1..127 A#4 WHISTLE_.500.DB8x.L08 22050 50 PCM 8-bit
C1..C#7 1..127 G#4 OCARI440.DB8x.L08 22050 56 PCM 8-bit
D7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-078 Whistle 0 C-1..A#6 1..127 A#4 WHISTLE_.500.DB8x.L08 22050 50 PCM 8-bit
m-000-000-077 Shakhchi 0 C-1..B6 1..127 A#4 SHAKUHAC.286S.L08 22050 8634 PCM 8-bit
C7..F7 1..127 C#4 SAW_6C_0.170.L08 22050 84 PCM 8-bit
F#7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-076 Bottle 0 C-1..C7 1..127 A4 FI_PAN_NA_T_055_G_2_M_0_LZ.L08 22050 5158 PCM 8-bit
C#7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-075 +PanFlute 0 C-1..C7 1..127 A4 FI_PAN_NA_T_055_G_2_M_0_LZ.L08 22050 5158 PCM 8-bit
m-000-000-074 Recorder 0 C-1..G#4 1..127 G#4 WW_RES_NA_T_065_F_3_M_0_LZ.L08 22050 1280 PCM 8-bit
A4..D5 1..127 D5 WW_RES_NA_T_071_B_3_M_0_LZ.L08 22050 942 PCM 8-bit
D#5..G#5 1..127 G#5 WW_RES_NA_T_077_F_4_M_0_LZ.L08 22050 596 PCM 8-bit
A5..C6 1..127 D6 RECOR452.452.L08 22050 306 PCM 8-bit
C#6..G#6 1..127 F4 RECOR453.453.L08 22050 68 PCM 8-bit
A6..G7 1..127 A#4 RECOR454.454.L08 22050 52 PCM 8-bit
m-000-000-073 +Flute 0 C-1..A#0 1..127 G#4 WW_RES_NA_T_065_F_3_M_0_LZ.L08 22050 1280 PCM 8-bit
B0..C5 1..127 A#4 WW_FLU_NA_T_076_E_4_M_0_LZ.L08 22050 1532 PCM 8-bit
C#5..B6 1..127 A#5 WW_FLU_NA_T_081_A_4_M_0_LZ.L08 22050 1724 PCM 8-bit
C7..G7 1..127 C#6 WW_FLP_NA_T_096_C_6_M_0_LZ.L08 22050 1914 PCM 8-bit
m-000-000-072 +Piccolo 0 C-1..A#0 1..127 G#4 WW_RES_NA_T_065_F_3_M_0_LZ.L08 22050 1280 PCM 8-bit
B0..C6 1..127 A#4 WW_FLU_NA_T_076_E_4_M_0_LZ.L08 22050 1532 PCM 8-bit
C#6..B6 1..127 G#5 WW_FLP_NA_T_084_C_5_M_0_LZ.L08 22050 1404 PCM 8-bit
m-000-000-071 +Clarinet 0 C-1..B3 1..127 G3 WW_CLA_NA_T_055_G_2_M_0_LZ.L08 22050 1338 PCM 8-bit
C4..G4 1..127 C#4 WW_CLA_NA_T_062_D_3_M_0_LZ.L08 22050 1090 PCM 8-bit
G#4..A#4 1..127 G#4 WW_CLA_NA_T_069_A_3_M_0_LZ.L08 22050 1016 PCM 8-bit
B4..C#6 1..127 F#5 CLARINE0.327.L08 22050 1190 PCM 8-bit
D6..B6 1..127 B3 CLARINE0.372.L08 22050 94 PCM 8-bit
C7..G#7 1..127 A#3 VIOLA470.470.L08 22050 100 PCM 8-bit
m-000-000-070 +Bassoon 0 C-1..A2 1..127 A2 FAG_1_F#.475.L08 22050 1170 PCM 8-bit
A#2..D#3 1..127 D#3 FAG_2_C_.476.L08 22050 1108 PCM 8-bit
E3..A3 1..127 A3 FAG_2_F#.477.L08 22050 1150 PCM 8-bit
A#3..D#4 1..127 D#4 FAG_3_C_.478.L08 22050 592 PCM 8-bit
E4..A4 1..127 D#4 WW_BSN_NA_T_066_F#3_M_0_LZ.L08 22050 594 PCM 8-bit
A#4..C5 1..127 D#5 FAG_3A_0.261.L08 22050 688 PCM 8-bit
C#5..C#6 1..127 D#5 FAG_4_C_.480.L08 22050 688 PCM 8-bit
D6..D#6 1..127 G6 OBOE_434.434.L08 22050 618 PCM 8-bit
E6..C7 1..127 F4 OBOE_365.365.L08 22050 68 PCM 8-bit
C#7..G#7 1..127 A#3 VIOLA470.470.L08 22050 100 PCM 8-bit
m-000-000-069 Eng.Horn 0 C-1..G#3 1..127 G#3 WW_EHR_NA_T_053_F_2_M_0_LZ.L08 22050 1302 PCM 8-bit
A3..D4 1..127 D4 ENG_H015.015.L08 22050 890 PCM 8-bit
D#4..G#4 1..127 G#4 WW_EHR_NA_T_065_F_3_M_0_LZ.L08 22050 900 PCM 8-bit
A4..C#5 1..127 G#4 WW_EHR_NA_T_067_G_3_M_0_LZ.L08 22050 846 PCM 8-bit
D5..D#7 1..127 D5 ENGLI438.438.L08 22050 936 PCM 8-bit
E7..G#7 1..127 A#3 VIOLA470.470.L08 22050 100 PCM 8-bit
m-000-000-068 +Oboe 0 C-1..C4 1..127 C#4 OBOE_429.429.L08 22050 1576 PCM 8-bit
C#4..F#4 1..127 G4 WW_OBO_NA_T_064_E_3_M_0_LZ.L08 22050 680 PCM 8-bit
G4..D5 1..127 C#5 OBOE_431.431.L08 22050 450 PCM 8-bit
D#5..F#5 1..127 G5 OBOE_432.432.L08 22050 548 PCM 8-bit
G5..C#6 1..127 C#6 OBOE_433.433.L08 22050 828 PCM 8-bit
D6..F6 1..127 G6 OBOE_434.434.L08 22050 618 PCM 8-bit
F#6..E7 1..127 F4 OBOE_365.365.L08 22050 68 PCM 8-bit
F7..G#7 1..127 A#3 VIOLA470.470.L08 22050 100 PCM 8-bit
m-000-000-067 Bari.Sax 0 C-1..A2 1..127 G#2 SAXBA414.414.L08 22050 904 PCM 8-bit
A#2..E3 1..127 F3 WW_SXB_NA_T_051_D#2_M_0_LZ.L08 22050 996 PCM 8-bit
F3..A3 1..127 G#3 SAXBA347.347.L08 22050 906 PCM 8-bit
A#3..C#5 1..127 C#4 WW_SXB_NA_T_060_C_3_M_0_LZ.L08 22050 954 PCM 8-bit
D5..F6 1..127 C#4 SAXBA361.361.L08 22050 82 PCM 8-bit
F#6..B6 1..127 F4 TP_4C_5&.410.L08 22050 68 PCM 8-bit
m-000-000-066 TenorSax 0 C-1..E3 1..127 D#3 TENOR456.456.L08 22050 2926 PCM 8-bit
F3..A#3 1..127 A3 WW_SXT_NA_T_054_F#2_M_0_LZ.L08 22050 1280 PCM 8-bit
B3..E4 1..127 D#4 WW_SXT_NA_T_060_C_3_M_0_LZ.L08 22050 1036 PCM 8-bit
F4..A#4 1..127 A4 TENOR462.462.L08 22050 994 PCM 8-bit
B4..A5 1..127 D#5 TENOR464.464.L08 22050 772 PCM 8-bit
A#5..A#5 1..127 E5 WW_SXA_NA_T_077_F_4_M_0_LZ.L08 22050 522 PCM 8-bit
B5..B5 1..127 D#6 SOP_SAX_.353.L08 22050 246 PCM 8-bit
C6..C#7 1..127 G#3 SOP_SAX0.387.L08 22050 112 PCM 8-bit
D7..G#7 1..127 A#3 VIOLA470.470.L08 22050 100 PCM 8-bit
m-000-000-065 Alto Sax 0 C-1..G#3 1..127 G3 WW_SXA_NA_T_053_F_2_M_0_LZ.L08 22050 898 PCM 8-bit
A3..D4 1..127 B3 WW_SXA_NA_T_059_B_2_M_0_LZ.L08 22050 784 PCM 8-bit
D#4..G#4 1..127 F4 WW_SXA_NA_T_065_F_3_M_0_LZ.L08 22050 544 PCM 8-bit
A4..D5 1..127 A4 WW_SXA_NA_T_071_B_3_M_0_LZ.L08 22050 622 PCM 8-bit
D#5..G5 1..127 E5 WW_SXA_NA_T_077_F_4_M_0_LZ.L08 22050 522 PCM 8-bit
G#5..B5 1..127 D#6 SOP_SAX_.353.L08 22050 246 PCM 8-bit
m-000-000-064 SprnoSax 0 C-1..D#4 1..127 D#4 WW_SXS_NA_T_060_C_3_M_0_LZ.L08 22050 470 PCM 8-bit
E4..A4 1..127 A4 WW_SXS_NA_T_066_F#3_M_0_LZ.L08 22050 432 PCM 8-bit
A#4..D#5 1..127 D#5 SOP_SAX_.351.L08 22050 484 PCM 8-bit
E5..A5 1..127 G#5 SOP_SAX_.352.L08 22050 318 PCM 8-bit
A#5..D#6 1..127 D#6 SOP_SAX_.353.L08 22050 246 PCM 8-bit
E6..C#7 1..127 G#3 SOP_SAX0.387.L08 22050 112 PCM 8-bit
m-000-000-063 SynBras2 0 C-1..F6 1..127 F#4 SYN_B046.046.L08 22050 3160 PCM 8-bit
m-000-000-062 SynBras1 0 C-1..A#0 1..127 F#4 SYN_B046.046.L08 22050 3160 PCM 8-bit
B0..E6 1..127 B4 SYN_BRA0.042S.L08 22050 2890 PCM 8-bit
F6..B6 1..127 F4 TP_4C_5&.410.L08 22050 68 PCM 8-bit
m-000-000-061 BrasSect 0 C-1..F#5 1..127 G#4 BR_TP336.336S.L08 22050 11226 PCM 8-bit
G5..G6 1..127 D5 BR_TPE_0.337S.L08 22050 11912 PCM 8-bit
G#6..C#7 1..127 C#6 TRM_STR_.214.L08 22050 9554 PCM 8-bit
m-000-000-060 +Fr.Horn 0 C-1..B2 1..127 A#3 HORN_2_G.115.L08 22050 4038 PCM 8-bit
C3..A#3 1..127 A#3 HORN_2_G.115.L08 22050 4038 PCM 8-bit
B3..E4 1..127 E4 HORN_3_C.116.L08 22050 3300 PCM 8-bit
F4..F7 1..127 A#4 HORN_3_G.117.L08 22050 3344 PCM 8-bit
m-000-000-059 Mute.Trp 0 C-1..E4 1..127 D#4 HARMON_3.017.L08 22050 956 PCM 8-bit
F4..G#4 1..127 A#4 BR_THM_NA_T_067_G_3_M_0_LZ.L08 22050 1004 PCM 8-bit
A4..C#5 1..127 C#5 HARMON_3.020.L08 22050 1136 PCM 8-bit
D5..E5 1..127 E4 BR_THM_NA_T_076_E_4_M_0_LZ.L08 22050 876 PCM 8-bit
F5..G5 1..127 G4 HARMON_4.023.L08 22050 1468 PCM 8-bit
G#5..A#5 1..127 A#4 HARMON_0.024.L08 22050 1650 PCM 8-bit
B5..B5 1..127 F4 TP_4C424.424.L08 22050 68 PCM 8-bit
C6..B6 1..127 F4 TP_4C_5&.410.L08 22050 68 PCM 8-bit
C7..D7 1..127 A#3 VIOLA467.467.L08 22050 100 PCM 8-bit
m-000-000-058 +Tuba 0 C-1..F5 1..127 B2 TUBA_1_C.132.L08 22050 1260 PCM 8-bit
F#5..E6 1..127 F3 TP_4C425.SX1M.L08 22050 4450 PCM 8-bit
F6..D7 1..127 A#3 VIOLA467.467.L08 22050 100 PCM 8-bit
m-000-000-057 +Trombone 0 C-1..G#2 1..127 B2 TROMBON0.135.L08 22050 3096 PCM 8-bit
A2..D#3 1..127 D#3 TROMBONE.136.L08 22050 1856 PCM 8-bit
E3..A3 1..127 A3 TROMBONE.137.L08 22050 1356 PCM 8-bit
A#3..F4 1..127 B3 BR_TBS_NA_T_060_C_3_M_0_LZ.L08 22050 1678 PCM 8-bit
F#4..F#5 1..127 D#5 TROMBONE.140.L08 22050 504 PCM 8-bit
G5..E6 1..127 F3 TP_4C425.SX1M.L08 22050 4450 PCM 8-bit
m-000-000-056 +Trumpet 0 C-1..C4 1..127 F4 TP_2C_5&.047S.L08 22050 1708 PCM 8-bit
C#4..E6 1..127 F3 TP_4C425.SX1M.L08 22050 4450 PCM 8-bit
m-000-000-055 +Orch.Hit 0 C-1..A#0 1..127 A4 SY_GS2_NA_T_068_G#3_M_0_LZ.L08 22050 13072 PCM 8-bit
B0..G9 1..127 B4 ORCH_131.131S.L08 22050 6696 PCM 8-bit
m-000-000-054 SynVoice 0 C-1..A#5 1..127 A4 SY_GS2_NA_T_068_G#3_M_0_LZ.L08 22050 13072 PCM 8-bit
m-000-000-053 +VoiceOoh 0 C-1..G9 1..127 G#4 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-000-052 +ChoirAah 0 C-1..C#3 1..127 E3 CH_AAH_NA_T_049_C#2_M_M.L08 22050 5132 PCM 8-bit
D3..G#3 1..127 G#3 CH_AAH_NA_T_052_E_2_M_0_LZ.L08 22050 5644 PCM 8-bit
A3..C#4 1..127 F4 CH_AAH_NA_T_061_C#3_M_0_LZ.L08 22050 5290 PCM 8-bit
D4..F4 1..127 G#4 CH_AAH_NA_T_064_E_3_M_0_LZ.L08 22050 5362 PCM 8-bit
F#4..A6 1..127 B4 CH_AAH_NA_T_068_G#3_M_M.L08 22050 5600 PCM 8-bit
A#6..G9 1..127 G#4 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-000-051 Syn.Str2 0 C-1..A#0 1..127 A3 ST_STE_02_T_059_B_2_M_0_LZ.L08 22050 18312 PCM 8-bit
B0..E6 1..127 A#4 SYN_P147.DB8x.L08 22050 4242 PCM 8-bit
m-000-000-050 +Syn.Str1 0 C-1..E6 1..127 F4 ST_STE_01_T_060_C_3_M_0_LZ.L08 22050 16906 PCM 8-bit
m-000-000-049 Strings2 0 C-1..G#6 1..127 A3 ST_STE_02_T_059_B_2_M_0_LZ.L08 22050 18312 PCM 8-bit
m-000-000-048 +Strings1 0 C-1..E6 1..127 F4 ST_STE_01_T_060_C_3_M_0_LZ.L08 22050 16906 PCM 8-bit
m-000-000-047 +Timpani 0 C-1..E7 1..127 F3 TP_TMP_NA_T_043_G_1_M_0_LZ.L08 22050 9474 PCM 8-bit
F7..G#7 1..127 F#5 XYLOP077.077S.L08 22050 1554 PCM 8-bit
A7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-046 +Harp 0 C-1..A#4 1..127 G#4 FI_HRP_NA_T_065_F_3_M_0_LZ.L08 22050 3470 PCM 8-bit
B4..A#7 1..127 G5 HARP_217.217.L08 22050 3792 PCM 8-bit
B7..G9 1..127 B4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-045 +Pizz.Str 0 C-1..C#3 1..127 C#4 PIZZ_141.141.L08 22050 4444 PCM 8-bit
D3..F4 1..127 C#4 PIZZ_141.141.L08 22050 4444 PCM 8-bit
F#4..A5 1..127 A#5 PIZZ_144.144.L08 22050 3560 PCM 8-bit
A#5..E6 1..127 G#6 PIZZ_145.145.L08 22050 2642 PCM 8-bit
F6..G9 1..127 G#6 PIZZ_145.145.L08 22050 2642 PCM 8-bit
m-000-000-044 Trem.Str 0 C-1..C4 1..127 A#3 TRM_STR_.212.L08 22050 9060 PCM 8-bit
C#4..B5 1..127 C5 TRM_STR_.213.L08 22050 9928 PCM 8-bit
C6..C#7 1..127 C#6 TRM_STR_.214.L08 22050 9554 PCM 8-bit
m-000-000-043 +Contrabs 0 C-1..G2 1..127 F#2 BOWBA061.061.L08 22050 1432 PCM 8-bit
G#2..G3 1..127 D#3 CELLO_21.107.L08 22050 1722 PCM 8-bit
G#3..G#4 1..127 D4 CELLO_3_.108.L08 22050 1306 PCM 8-bit
A4..E5 1..127 F4 CELLO_3_.109.L08 22050 1276 PCM 8-bit
F5..F#6 1..127 A#3 VIOLA401.401.L08 22050 100 PCM 8-bit
G6..C7 1..127 A#3 VIOLA467.467.L08 22050 100 PCM 8-bit
m-000-000-042 +Cello 0 C-1..A2 1..127 A2 CELLO_10.106.L08 22050 1756 PCM 8-bit
A#2..G3 1..127 D#3 CELLO_21.107.L08 22050 1722 PCM 8-bit
A4..G5 1..127 F4 CELLO_3_.109.L08 22050 1276 PCM 8-bit
G#5..A#6 1..127 A#3 VIOLA401.401.L08 22050 100 PCM 8-bit
B6..D7 1..127 A#3 VIOLA467.467.L08 22050 100 PCM 8-bit
m-000-000-041 +Viola 0 C-1..F#3 1..127 E3 ST_VAS_NA_T_052_E_2_M_0_LZ.L08 22050 1414 PCM 8-bit
G3..B3 1..127 B3 ST_VAS_NA_T_058_A#2_M_0_LZ.L08 22050 1504 PCM 8-bit
C4..F4 1..127 F4 VIOLA223.223.L08 22050 1122 PCM 8-bit
F#4..A#4 1..127 C#5 VIOLA226.226.L08 22050 1462 PCM 8-bit
B4..D#5 1..127 E5 VIOLA228.228.L08 22050 1424 PCM 8-bit
E5..A5 1..127 A#5 ST_VAS_NA_T_081_A_4_M_0_LZ.L08 22050 1268 PCM 8-bit
A#5..C#6 1..127 A#5 VIOLA358.358.L08 22050 1270 PCM 8-bit
D6..G6 1..127 A#3 VIOLA401.401.L08 22050 100 PCM 8-bit
G#6..C7 1..127 A#3 VIOLA467.467.L08 22050 100 PCM 8-bit
m-000-000-040 +Violin 0 C-1..A3 1..127 E3 ST_VAS_NA_T_052_E_2_M_0_LZ.L08 22050 1414 PCM 8-bit
m-000-000-039 +SynBass2 0 C-1..D#6 1..127 D#2 SY_BAS_02_V_042_F#1_M_0_LZ.L08 22050 2072 PCM 8-bit
E6..B6 1..127 F4 TP_4C_5&.410.L08 22050 68 PCM 8-bit
m-000-000-038 +SynBass1 0 C-1..D#6 1..127 D#2 SYN_B129.129S.L08 22050 3446 PCM 8-bit
m-000-000-037 SlapBas2 0 C-1..A#5 1..127 E2 EB_SL127.127T.L08 22050 3596 PCM 8-bit
B5..B6 1..127 F4 TP_4C_5&.410.L08 22050 68 PCM 8-bit
m-000-000-036 SlapBas1 0 C-1..B2 1..127 B2 BA_ELB_PU_T_038_D_1_M_0_DLS.L08 22050 1888 PCM 8-bit
C3..E5 1..127 B2 EB_SL126.126Tnrd.L08 22050 3518 PCM 8-bit
F5..B6 1..127 F4 TP_4C_5&.410.L08 22050 68 PCM 8-bit
m-000-000-035 +Fretless 0 C-1..A6 1..127 A2 EB_FR120.120.L08 22050 2640 PCM 8-bit
m-000-000-034 PickBass 0 C-1..F6 1..127 F2 BA_ELB_PK_T_038_D_1_M_0_LZ.L08 22050 1728 PCM 8-bit
C7..D#7 1..127 A#3 VIOLA467.467.L08 22050 100 PCM 8-bit
E7..G9 1..127 C#5 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-000-033 FngrBass 0 C-1..E6 1..127 G#2 BA_ELB_FI_T_033_A_0_M_0_LZ.L08 22050 2720 PCM 8-bit
m-000-000-032 +Aco.Bass 0 C-1..A5 1..127 A#1 BA_UPR_PZ_T1031_G_0_M_0_LZ.L08 22050 3068 PCM 8-bit
A#5..E6 1..127 G#2 BA_ELB_FI_T_033_A_0_M_0_LZ.L08 22050 2720 PCM 8-bit
m-000-000-031 GtrHarmo 0 C-1..C#1 1..127 A2 EB_FR120.120.L08 22050 2640 PCM 8-bit
D1..A6 1..127 C#5 GT_EHR_NA_T_079_G_4_M_0_LZ.L08 22050 962 PCM 8-bit
A#6..G9 1..127 B3 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-030 +Dist.Gtr 0 C-1..A2 1..127 F2 GT_EDS_NA_T_040_E_1_M_0_LZ.L08 22050 3088 PCM 8-bit
A#2..C#3 1..127 C3 GT_EDS_NA_T_046_A#1_M_0_LZ.L08 22050 2874 PCM 8-bit
D3..G3 1..127 F#3 EG_DIST_.403.L08 22050 2064 PCM 8-bit
G#3..E4 1..127 A#3 GT_EDS_NA_T_058_A#2_M_0_LZ.L08 22050 1734 PCM 8-bit
F4..C#5 1..127 G#4 GT_EDS_NA_T_070_A#3_M_0_LZ.L08 22050 3106 PCM 8-bit
D5..G5 1..127 F5 GT_EDS_NA_T_076_E_4_M_0_LZ.L08 22050 930 PCM 8-bit
G#5..D6 1..127 C6 GT_EDS_NA_T_081_A_4_M_0_LZ.L08 22050 630 PCM 8-bit
D#6..F#7 1..127 F#5 GT_EDS_NA_T_086_D_5_M_0_LZ.L08 22050 1162 PCM 8-bit
m-000-000-029 Ovrdrive 0 C-1..D3 1..127 G#2 GT_EOD_NA_T_040_E_1_M_0_LZ.L08 22050 2672 PCM 8-bit
D#3..C#4 1..127 D4 GT_EOD_NA_T_057_A_2_M_0_LZ.L08 22050 2792 PCM 8-bit
D4..G4 1..127 G4 EG_OD_31.378.L08 22050 1114 PCM 8-bit
G#4..C#5 1..127 C5 GT_EOD_NA_T_070_A#3_M_0_LZ.L08 22050 1450 PCM 8-bit
D5..G#5 1..127 D#5 GT_EOD_NA_T_100_E_6_M_0_LZ.L08 22050 510 PCM 8-bit
A5..C7 1..127 A#5 GT_EOD_NA_T_082_A#4_M_0_LZ.L08 22050 410 PCM 8-bit
C#7..F7 1..127 C#4 SAW_6C_0.170.L08 22050 84 PCM 8-bit
m-000-000-028 Mute.Gtr 0 C-1..D#6 1..127 D#3 GT_EMT_NA_T_050_D_2_M_0_LZ.L08 22050 942 PCM 8-bit
m-000-000-027 +CleanGtr 0 C-1..F5 1..127 C#3 EG_ST112.112CY.L08 22050 2056 PCM 8-bit
F#5..F#6 1..127 C#3 EG_ST405.405.L08 22050 620 PCM 8-bit
G6..F7 1..127 A#5 JAZZ_G_4.193.L08 22050 28 PCM 8-bit
m-000-000-026 Jazz Gtr 0 C-1..A#2 1..127 G#2 JAZZ_G_1.187.L08 22050 974 PCM 8-bit
B2..F3 1..127 F#3 JAZZ_G_2.188.L08 22050 448 PCM 8-bit
F#3..B3 1..127 B3 GT_EJZ_NA_T_056_G#2_M_0_LZ.L08 22050 850 PCM 8-bit
C4..F4 1..127 B3 GT_EJZ_NA_T_056_G#2_M_4_LZ.L08 22050 486 PCM 8-bit
F#4..B4 1..127 C5 JAZZ_G_3.191.L08 22050 788 PCM 8-bit
C5..E5 1..127 D#5 JAZZ_G_4.192.L08 22050 460 PCM 8-bit
F5..F7 1..127 A#5 JAZZ_G_4.193.L08 22050 28 PCM 8-bit
m-000-000-025 SteelGtr 0 C-1..E3 1..127 D3 MART248.248S.L08 22050 4676 PCM 8-bit
F3..D4 1..127 C4 MART250.250Snrd.L08 22050 2884 PCM 8-bit
D#4..C5 1..127 G4 MARTI252.252S.L08 22050 2368 PCM 8-bit
C#5..A6 1..127 D#5 MARTI254.254S.L08 22050 1632 PCM 8-bit
m-000-000-024 NylonGtr 0 C-1..A#2 1..127 B2 GIBSO233.233S.L08 22050 2882 PCM 8-bit
B2..G#3 1..127 A3 GIBSO235.235S.L08 22050 1750 PCM 8-bit
A3..F4 1..127 D#4 GIBSO237.237S.L08 22050 1812 PCM 8-bit
F#4..E5 1..127 D5 GIBSO240.240S.L08 22050 2188 PCM 8-bit
F5..E6 1..127 D5 GIBSO240.240S.L08 22050 2188 PCM 8-bit
m-000-000-023 TangoAcd 0 C-1..C4 1..127 C4 024tangAoord.3_C.L08 22050 174 PCM 8-bit
C#4..F5 1..127 C5 024tangAoord.4_C.L08 22050 90 PCM 8-bit
F#5..F6 1..127 A#3 READ_ORG.012.L08 22050 98 PCM 8-bit
m-000-000-022 Harmnica 0 C-1..A4 1..127 F4 FI_HAR_NA_T_062_D_3_M_0_LZ.L08 22050 1544 PCM 8-bit
A#4..F#5 1..127 B4 FI_HAR_NA_T_074_D_4_M_0_LZ.L08 22050 1254 PCM 8-bit
G5..F7 1..127 E4 HARMO422.422.L08 22050 1524 PCM 8-bit
m-000-000-021 +Acordion 0 C-1..G#4 1..127 E4 ACCOR075.075S.L08 22050 7676 PCM 8-bit
A4..G5 1..127 E5 KY_ACC_NA_T_072_C_4_M_0_LZ.L08 22050 6326 PCM 8-bit
G#5..F7 1..127 E5 ACCOR230.230.L08 22050 4708 PCM 8-bit
F#7..G9 1..127 G#4 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-000-020 ReedOrgn 0 C-1..A5 1..127 A#3 READ_ORG.097.L08 22050 1956 PCM 8-bit
A#5..F6 1..127 A#3 READ_ORG.012.L08 22050 98 PCM 8-bit
m-000-000-019 ChrchOrg 0 C-1..A5 1..127 G#3 PIPE_ORG.079.L08 22050 4858 PCM 8-bit
A#5..G6 1..127 E6 KY_ACC_NA_T_072_C_4_M_0_LZ.L08 22050 6326 PCM 8-bit
G#6..F8 1..127 E6 ACCOR230.230.L08 22050 4708 PCM 8-bit
F#8..G9 1..127 G#5 CH_AAH_NA_T_067_G_3_M_0_LZ.L08 22050 12248 PCM 8-bit
m-000-000-018 +RockOrgn 0 C-1..D3 1..127 A#2 ROCK_004.004.L08 22050 3960 PCM 8-bit
D#3..D4 1..127 A#3 ROCK_OR0.005.L08 22050 4854 PCM 8-bit
D#4..D5 1..127 A#4 ROCK_502.502.L08 22050 4286 PCM 8-bit
D#5..D6 1..127 A#5 ROCK_OR0.006.L08 22050 4898 PCM 8-bit
D#6..G9 1..127 A#6 ROCK_OR0.003.L08 22050 4244 PCM 8-bit
m-000-000-017 +PercOrgn 0 C-1..D8 1..127 D4 KY_OJZ_01_T_060_C_3_M_0_LZ.L08 22050 2858 PCM 8-bit
D#8..F8 1..127 C#5 SAW_6C_0.170.L08 22050 84 PCM 8-bit
F#8..G9 1..127 C#6 SAW_7C_0.171.L08 22050 44 PCM 8-bit
m-000-000-016 +DrawOrgn 0 C-1..E7 1..127 F3 KY_OJZ_02_T_048_C_2_M_0_LZ.L08 22050 1210 PCM 8-bit
F7..F7 1..127 F3 KY_OJZ_02_T_048_C_2_M_Y_LZ.L08 22050 250 PCM 8-bit
F#7..G9 1..127 C#5 SAW_6C_0.170.L08 22050 84 PCM 8-bit
m-000-000-015 +Dulcimer 0 C-1..A5 1..127 D#3 FI_DUL_02_T_062_D_3_M_0_LZ.L08 22050 3552 PCM 8-bit
A#5..C6 1..127 D3 SYN_A383.383.L08 22050 156 PCM 8-bit
C#6..C#7 1..127 D3 SY_PAD_NA_T_072_C_4_M_O_LZ.L08 22050 156 PCM 8-bit
m-000-000-014 +TubulBel 0 C-1..F#7 1..127 G4 TP_TUB_NA_T_068_G#3_M_0_LZ.L08 22050 7592 PCM 8-bit
G7..G9 1..127 G4 SY_SIN_NA_X_060_C_3_M_0_0 22050 445 PCM 16-bit
m-000-000-013 Xylophon 0 C-1..G#1 1..127 G3 MARIM000.000S.L08 22050 1782 PCM 8-bit
A1..A6 1..127 F#5 XYLOP077.077S.L08 22050 1554 PCM 8-bit
A#6..A7 1..127 G4 FI_KAL_NA_T_067_G_3_M_0_LZ.L08 22050 2758 PCM 8-bit
m-000-000-012 +Marimba 0 C-1..C7 1..127 G3 MARIM000.000S.L08 22050 1782 PCM 8-bit
C#7..A7 1..127 G4 FI_KAL_NA_T_067_G_3_M_0_LZ.L08 22050 2758 PCM 8-bit
m-000-000-011 Vibes 0 C-1..G6 1..127 G#4 VIBE_244.244S.L08 22050 2004 PCM 8-bit
m-000-000-010 +MusicBox 0 C-1..C#4 1..127 C4 011MusicBox.3_C.L08 22050 1428 PCM 8-bit
m-000-000-009 +Glocken 0 C-1..G2 1..127 G#4 VIBE_244.244S.L08 22050 2004 PCM 8-bit
G#2..A#5 1..127 G6 GLOKEN&.011S.L08 22050 2644 PCM 8-bit
B5..A#6 1..127 G6 GLOCK390.390.L08 22050 1712 PCM 8-bit
m-000-000-008 +Celesta 0 C-1..E3 1..127 G#4 VIBE_244.244S.L08 22050 2004 PCM 8-bit
F3..F7 1..127 D#5 CELES210.210S.L08 22050 3056 PCM 8-bit
m-000-000-007 +Clavi. 0 C-1..D#2 1..127 C2 CLAVI064.064.L08 22050 342 PCM 8-bit
E2..F#2 1..127 C2 KY_CLV_NA_T_039_D#1_M_0_LZ.L08 22050 342 PCM 8-bit
G2..B2 1..127 C3 KY_CLV_NA_T_045_A_1_M_0_LZ.L08 22050 170 PCM 8-bit
C3..D3 1..127 C3 CLAVI469.469.L08 22050 170 PCM 8-bit
D#3..F#3 1..127 C3 KY_CLV_NA_T_051_D#2_M_0_LZ.L08 22050 170 PCM 8-bit
G3..D4 1..127 C4 CLAVI063.063.L08 22050 90 PCM 8-bit
D#4..F#4 1..127 C4 KY_CLV_NA_T_063_D#3_M_0_LZ.L08 22050 90 PCM 8-bit
G4..G#5 1..127 E3 KY_CLV_NA_T_069_A_3_M_0_LZ.L08 22050 140 PCM 8-bit
A5..C#6 1..127 B3 KY_CLV_NA_T_069_A_3_M_C_LZ.L08 22050 94 PCM 8-bit
D6..A6 1..127 G3 SAW_5F#0.169.L08 22050 116 PCM 8-bit
m-000-000-006 +Harpsi. 0 C-1..D#2 1..127 D#2 KY_HSN_NA_T_036_C_1_M_0_LZ.L08 22050 1432 PCM 8-bit
E2..A2 1..127 A2 KY_HSN_NA_T_042_F#1_M_0_LZ.L08 22050 898 PCM 8-bit
A#2..D#3 1..127 D#3 HARPS057.057.L08 22050 1424 PCM 8-bit
E3..A3 1..127 A3 HARPS134.134.L08 22050 1162 PCM 8-bit
A#3..D#4 1..127 D4 KY_HSN_NA_T_060_C_3_M_0_LZ.L08 22050 444 PCM 8-bit
E4..G#4 1..127 A4 HARPS125.125.L08 22050 534 PCM 8-bit
A4..B4 1..127 A4 HARPS468.468.L08 22050 880 PCM 8-bit
C5..F#5 1..127 D#5 KY_HSN_NA_T_072_C_4_M_0_LZ.L08 22050 636 PCM 8-bit
G5..D#6 1..127 D6 HARPS152.152.L08 22050 432 PCM 8-bit
m-000-000-005 E.Piano2 0 C-1..F6 1..127 D#3 EP_DX_2 C_SQ.508.L08 22050 148 PCM 8-bit
F#6..D7 1..127 D#3 EP_DX282.282.L08 22050 148 PCM 8-bit
D#7..F7 1..127 C#4 SAW_6C_0.170.L08 22050 84 PCM 8-bit
m-000-000-004 +E.Piano1 0 C-1..A2 1..127 C#3 EP_RHO_NA_T_045_A_1_M_0_LZ.L08 22050 318 PCM 8-bit
m-000-000-003 HnkyTonk 0 C-1..G2 1..127 G2 AP_YAM_NA_T_044_G#1_M_0_LZ 22050 36040 PCM 16-bit
G#2..G3 1..127 B2 AP_YAM_NA_T_048_C_2_M_0_MA31W 22050 30846 PCM 16-bit
G#3..E4 1..127 B3 AP_YAM_NA_T_060_C_3_M_0_LZ 22050 33604 PCM 16-bit
F4..A4 1..127 F#4 AP_YAM_NA_T_067_G_3_M_0_LZ 22050 33465 PCM 16-bit
A#4..D5 1..127 B4 AP_YAM_NA_T_072_C_4_M_0_LZ 22050 28120 PCM 16-bit
D#5..C6 1..127 F5 AP_YAM_NA_T_078_F#4_M_0_LZ 22050 21238 PCM 16-bit
C#6..C8 1..127 C#6 AP_YAM_NA_T_086_D_5_M_0_MA31W 22050 8874 PCM 16-bit
m-000-000-002 E.Grand 0 C-1..G2 1..127 G2 AP_YAM_NA_T_044_G#1_M_0_LZ 22050 36040 PCM 16-bit
m-000-000-001 BritePno 0 C-1..D3 1..127 G2 AP_YAM_NA_T_044_G#1_M_0_LZ 22050 36040 PCM 16-bit
m-000-000-000 +GrandPno 0 C-1..G2 1..127 G2 AP_YAM_NA_T_044_G#1_M_0_LZ 22050 36040 PCM 16-bit
Total size: 7820 KB
Daniel L Newhouse
Reply 28 of 58, by dnewhous
I got the output by saving FF8.dls as a txt file with Awave Studio and then opening the file FF8.txt in Ultraedit. Then I copied and pasted it here.
I tried Windows 98 compatibility mode and it still stalls.
Daniel L Newhouse
Reply 29 of 58, by Joseph_Joestar
I've been playing around with this recently so I decided to write a quick guide for getting the highest quality music from Final Fantasy VII when using an AWE card.
Here's what you need:
  • Windows 98SE (not sure if this works on later Windows versions)
  • The retail CD version of Final Fantasy VII for the PC
  • Official patch 1.02 for the game
  • An AWE32 or an AWE64 sound card with at least 4 MB RAM on-board
  • Latest Win98 drivers for AWE cards from Creative's website (specifically, you need sbw9xup.exe)
And here's the setup process:
  1. Perform a clean install of Windows 98SE. Do not install any sound card drivers or utilities except those mentioned below
  2. Double click on sbw9xup.exe to unpack the archive, then run UPDDRV95.EXE to update the sound card drivers
  3. Browse to the FF7 Install CD and from there install the SoundFont Manager (D:\SFMan\setup.exe)
  4. Restart your computer
  5. Install Final Fantasy VII using the "maximum install" option
  6. Extract the contents of the official patch 1.02 to the folder where FF7 is installed and overwrite the relevant files when prompted
  7. Run the FF7 Configuration tool and on the MIDI tab select the options as shown on the screenshot below, then press the "Test" button:
file.php?id=98613&mode=view
If everything worked correctly, a message saying "Loading 4 MB soundfont" should briefly appear in the status window, followed by "playing MIDI". Click "Ok" to finish the setup process. With this, you get high quality music which is 90% the same as on the original PlayStation version, including the vocals during Sephiroth's theme which will play fine.
My retro stuff
Reply 30 of 58, by dnewhous
Here's a post of the header of FF7.txt from the current version of Awave Studio
Text description by Awave Studio v11.4
Source file: C:\Soundfont\Final Fantasy VII.txt
Source type: SoundFont v2 bank
Item - collection: Final Fantasy VII
Copyright: Copyright (c) Square Soft, Inc., 1998
Daniel L Newhouse
Reply 31 of 58, by Jorpho
dnewhous wrote on 2021-03-12, 17:17:
Here's a past of the header of FF7.txt from the current version of Awave Studio […]
I am completely baffled as to why you thought it would be useful to add this to this thread after three months.
But I do suddenly recall that someone did do some work on an FF8 soundfont – twenty years ago, and never completed.
https://ff8sf2.zophar.net/
Reply 32 of 58, by dnewhous
That information is generated by Awave Studio when creating a text file. It doesn't have a properties page to look at for a MIDI bank.
Daniel L Newhouse
Reply 33 of 58, by Cloudschatze
Cloudschatze wrote on 2016-12-29, 16:25:
DracoNihil wrote:
Cloudschatze wrote on 2016-12-29, 03:22:
Here's a digital, S/PDIF capture of the in-game playback of One-Winged Angel:
One-Winged Angel (in-game) - AWE64 Gold
Why is that missing the snare drums in the beginning?
I'll have to look at the MIDI file, but it could be something as simple as a disconnect between the MIDI note for the snare drum, and the key mapping defined for the Rsnare sample in the SoundFont bank (subsequently resulting in silence).
I did actually look into this, years ago, and was able to identify and resolve the issue of the missing snare drum. It's a subjective thing though, and I'd wanted to compare it against the PSX version, making any changes as necessary. I never got around to it.
So, with that disclaimer, here's a slightly-modified SF2 for One-Winged Angel that includes the missing snare drum. Feel free to use it (or not); it just needs to be dropped into the game's ..\data\midi\sf2\ directory, preferably after you've copied/renamed the original, and with the presumption that MIDI/SoundFont playback has been configured appropriately.
Reply 34 of 58, by YodasRaytracedRetro
(Old URL was removed, new one is below now)
Hi my name is Yoda. As I was building this guide I realized there was no way in my understanding anyway to install the Yamaha driver with the steam version, or the modern method of 7th heaven. Now the method im using might be compensating for the general MIDI being selected (I have no choice) by the person who made the drop in files, but I was wondering if people like in this forum who come across as if they know what they are talking about, if this is indeed identical, or in practice indistinguishable from the original game sound. Also im aware there is a 2mb, 4mb, and 8mb option tucked away somewhere and would very much like to know if it is maxed out or better in whatever wrapper 7th heaven is using. The ability to change this even if its nit picky is a serious consideration for me.
I also was very interested in it being fixed because its obvious to me it launched in an imperfect state, a sin that is honestly hard to understand considering its scores caliber beyond maybe deadlines rushing things along. I was also wanting to see if there was a more refined achieving the same vibe, modern processing version of this someone here might soon make available. There is a Yamaha remastered handful of videos on youtube, but as far as I can tell thats not playable with the game in real time, making them more or less useless to my ambitions.
Now the entire purpose of my goal is to make as much of the retro library functional, and as fully as possible in modern operating systems people actually run these days. I dont get the idea for example, raytracing is going to fly in a windows 98 virtual machine. Its also a tough sell suggesting Creatives path in this title since apart from some exceptions of nuance, its clear it didnt get the same amount of love as the Yamaha path. I also would love to see someone smoothly hybridize this Yamaha sound with the symphonics of remake which in parts each genuinely sound better than one another. I guess the trick is making them blend together without sounding off. Id love to use the last posters file for the last part of the game but its not a format I recognize.
I think what we need is some programmers, or a programmer thats committed to this game as a project so we can run pretty much whatever we want if necessary in emulation. That or rebuild the bridge to all the neglected files. That said there was some issues I faced using the original MIDI option in 7th heaven where it definitely sounded wrong, so its a complex topic we can hopefully figure out and make work for windows 10, and easily, in time.
Reply 35 of 58, by Jorpho
YodasRaytracedRetro wrote on 2021-04-13, 06:32:
Don't you think it would be a lot easier just to re-record the music as sampled audio that can be used with the existing Steam verison without any fancy programming? That is "in practice indistinguishable".
Reply 36 of 58, by YodasRaytracedRetro
Jorpho wrote on 2021-04-13, 19:50:
Can I assume thats what these downloads in my guide have already done? If thats the case I suspect the lack of the Yamaha driver selectability easily out of the steam and 7th heaven ecosystem is the culprit in why the lower end of the spectrum piano comes across as crowded out by the other competing sounds (Mako Reactor). Listening to several samples available on youtube, there is one thats about 13 years old im assuming probabilistically has a compatible set up, or at very minimum already doing what I did very specifically for this game. Adjustment of the equalizer. Unfortunately I couldnt find a viable, or it wasnt user friendly to a sound noob like me, third party generalized tool that was plug and play for whoever decided they wanted to run with my guides steps.
If you are volunteering to improve the experience lets do this.
Reply 37 of 58, by Jorpho
YodasRaytracedRetro wrote on 2021-04-15, 23:39:
I don't understand the question. Don't you know what's in your own guide..? Your Youtube link comes up as "removed by the uploader".
I'm saying all you need is something that can record the playback of synthesized audio. Pretty much any computer can do that.
Reply 38 of 58, by YodasRaytracedRetro
These are the fixed Yamaha files I found trying to force the correct sound without jank in 7th heaven. Or as close as possible to it anyway.
https://drive.google.com/u/0/uc?id=0B9wPT-tab … export=download
Im reuploading it because I needed to enhance the sound being at everything was at defaults in the soundcard whatnots, and I touched the equalizer to fix the smothered out layer I discovered doing some probing of the game online comparing it to what I gots.
https://www.youtube.com/watch?v=W5gpDRnB6Dk
I was hoping a wizard sound guy would swing in here and help fix some of the issues the basically retail maxed out sound had (It might have been rushed?). Perhaps enhance it without deviating much. Incrementalism. Polish.
Right now im trying to emulate what the yamaha driver AND MIDI options would sound like on pretty much any modern sound card. The FF7 7th heaven mod forces us to use their recommended sound thingamajig because the original MIDI option glitches. We cant easily select the driver option, since pretty much no one these days has a Yamaha or windows 98, or the old CD version installer. Hell I dont even have a disc drive. I tried the game converter and it just caused problems. Its just sound (which should be trivial by todays standards to produce), so im begging you divine lords of the internet audiophiles underworld if by simple obscurity to contribute. I have a fast dirty workaround, which in practice might be indistinguishable, but im not 100% objectively certain. I do know it sounds better than the microsoft general driver which im guessing the EQ they didnt even try.
I gots this xonar chip im guessing interpolating? -- at 32bit at max samples. I cant tell a difference between quality settings unless its like rain and thunder sounds where the higher quality option sounds more believable and less synthetic. Ironically im trying to make synthetic sounds more believable. Richer. Sexier.
Reply 39 of 58, by YodasRaytracedRetro
https://www.youtube.com/watch?v=CvG18wDv4uc
Something like this looked interesting. And fixing one winged angel. Same style of sound, just cleaner and more rad. Maybe more fine tuned even. See im not big into sound stuff but I want that sort of vibe to the way this composers work flows out of my speakers and not stray too far.
Someone should help this process since im not going to be able to do everything myself. Ive already adopted so many ancient problem children, and have some things to buy before I get the rest of those games on steam to enhance. Some will require I buy DRM laden discs and a drive and pray to the Gods im not buying worthless not worth returning collectables. My next goal was texture upscales where they havent been done yet. Please spare me this project, and im not the guy to do it anyway. I dont know what im doing at the ragged edge of nuance.
My intention is making this all a public resource. The more groundwork is laid, the more people are going to be encouraged to build on it in ways that are more esoteric and difficult to achieve. There are only so many good raytracable classics, and thats the niche I chose because its realistically doable unlike trying to keep up with the modern day joneses. Im sorry im not paying 60 bucks per new drop in the artsy marketplace. Thats super unreasonable. Old is cheap though.
