Reply 20 of 28, by Roland User
swaaye
I dont know as create new topics. I wanted create compact and easy with all include version
But , this yet will be SoundCanvas VA thread. Idea about VST MIDI Driver adaptive for SoundCanvas VA did error. Decision there was a so easy as only can.
Reply 21 of 28, by kode54
I just updated the VST MIDI Driver. It should be significantly more robust, and should definitely not stay in memory on shutdown.
Reply 22 of 28, by PhilsComputerLab
Thank you for your efforts, greatly appreciated!
Reply 23 of 28, by Roland User
kode54
How add delay for correct playback with SoundCanvas VA ?
And how set as SC-55 mode ? This not work.
Reply 24 of 28, by Roland User
Fixed Error
Reply 25 of 28, by Roland User
kode54
Is it possible loadable VST Plugin when start PC ?
I would like to have this mode was in your VST MIDI DRV for Windows.
Because this comfortable and plugins loaded without other windows and not need everytime loaded SAVI host or other VST host )
Now your VST MIDI DRV preloading VST Synth everytime as we play MIDI file. This discomfort , because in MIDI files partialy lost and playback not correct.
Reply 26 of 28, by kode54
Short answer: No.
Long answer: I am not delving into developing this as a system service, or as an always-resident player application. There are existing products that already service this need. You just need a MIDI loopback driver and to set an application that accepts MIDI input as the receiver and loader of the VST.
It was never designed to be used as a standalone MIDI player anyway. I already designed foo_midi for that purpose.
Reply 27 of 28, by Roland User
kode54
Two question.
1) as question by your answer
Have problem.
You offer use user-loaded VST Host , this can as load SAVIhost , and as load any other VST host include special sequancer or VST plugin for Player.
Me need other method. If currently , I loaded Windows and next load SAVIHost. I want preload VST plugins in process windows load without other windows or any other popup. This possible ? In my plans use LoopMIDI or any other MIDI port for this VST loader.
Your driver comfortably the whats not popup window.. But your MIDI driver have delay for preload VST plugins and this discomfort.
2) on my Windows 7 x64 if portabled SC-VA from install to VM and portable with specified activate module (without warez in activator module) and not install to current working OS , then any your VST MIDI DRV not work wint SC-VA if VST MIDI DRV on date newer than 02/09/2012.. why is that ?
Thank.
Reply 28 of 28, by Roland User
Fixed bug , if open MIDI File befor open WMPlayer and WMPlayer loop option enabled.
Argumentative MIDIi file no played.
kode54
Please , add delay in your VST Driver ) need delay 1-2 sec and all ) output will be correctly )
