Problem with SB0220 card
Reply 20 of 40, by Piecho
Link for Sound-Blaster-Live-Value-Installation-CD-1713330760.zip is dead, you know what CD I should use for this instructions from KT7AGuy link?
Sorry, I found - http://www.vogonsdrivers.com/getfile.php?fileid=659
I see in my country cheap AWE64 but it is still PCI card, not ISA. Could you please link me list of popular ISA sound card which I may cheap buy today?
Reply 21 of 40, by KT7AGuy
AWE64 PCI cards are rare. Are you sure it is an AWE64 PCI card?
I don't know what country you're in or where you shop. However, you should look for these:
AWE64 Value models: CT4500, CT4501, CT4502, CT4520
SB16 models: CT2230 or CT2290
Reply 22 of 40, by Piecho
Yeah, I was wrong - its ISA AWE64.
I try to follow instruction:
Choose to install Sound Blaster Live, choose custom install when asked, and clear all the checkboxes when asked what options to install (don't choose dos drivers, launcher, etc). Setup proceeds as normal and it will try installing the VXD drivers but just ignore it. Windows should keep the WDM drivers installed after rebooting, but usually it'll replace the gameport with the multimedia device driver which you'll have to upgrade to the WDM gameport driver again.
When I run autostart from this CD I get:
I tried to checkout every each box but then I only get registrations opton for my card. Do I do again something wrong? Link seems to be fine.
Reply 23 of 40, by Tetrium
Piecho wrote:
I used this card becouse I get IBM without any audio card. I found this SB in my house and just put in PC. I asumed everything should work fine.
Ok, I will carfully read inforations fro your link KT7AGuy.
This is perfectly understandable and many of us try to make due with what they have laying around 😉
And the ISA AWE64 would make a great addition and should suit your needs very well, you should go get it! 😁
My retro rigs (old topic)
Report spammers here!
Reply 24 of 40, by KT7AGuy
<snip>
Like I was saying before: I think you're going to get a bunch of headaches with that SB0220.
Get the AWE64. It is much easier to get it working for DOS games. I think you will be much happier with it.
Reply 25 of 40, by gdjacobs
I'm not recommending the AWE64, but I am recommending an ISA card. Your best option will depend on your requirements for MIDI, OPL3, and sound quality.
Reply 26 of 40, by Sammy
just start windows 98, open the command prompt and type
SET
is there a BLASTER= .............. Line?
I think on my system there is in device Manager a creative legacy or something similar Device where i can set irq and Dma for Soundblaster Emulation.
Reply 27 of 40, by Tetrium
I'm not judging your knowledge of old sound cards (my knowledge is basically kinda limited to 'as long as I can hear something'), but just wanting to point out that my main reason for recommending this AWE64 is that Piecho doesn't have any ISA sound cards whatsoever and this one will simply work and is cheap too. Cheap is important, right? 😁
Reply 28 of 40, by KT7AGuy
gdjacobs:
KT7AGuy wrote:
Get a cheap AWE64 Value and don't look back: CT4500, CT4501, CT4502, CT4520. This is your cheapest solution.
KT7AGuy wrote:
However, your easiest & best solution is a real SB16 CT2230 or CT2290, but it's gonna cost a bit more.
I think the guy just wants to play some DOS games with sound. I could be wrong about that.
Of course, the truly cheapest solution would be to just use DOSBox. It's probably the easiest solution too.
Reply 29 of 40, by gdjacobs
He has options. YMF71x cards. Crystal based cards. ESS based cards. Aztech cards. Creative cards. All these chipsets have been incorporated in inexpensive and available cards. All have pluses and minuses.
With some examples of games and software which needs to run, I can likely narrow down the choices some more.
Reply 30 of 40, by Piecho
Thanks guys, no new card will be needed : )
Its working as SBLive after installing driver from this pack - How to get Sound Blaster Emulation in Win9X/ME via live!5.1 with newer-current mobo's (no nmi-ddma) "CT4780.ZIP"
I checked "SET" as Sammy wrote and for secure I added "SET BLASTER=A220 I5 D1 T4 P330" in Autoexec.
Now everything is working - I checked for JazzJack Rabbit and Heroes I.
Yeah, I just want sound in DOS games, nothing more. It doesnt have to be higher quality.
Reply 31 of 40, by Gamecollector
Have tested SB0220 for DOS. No, the standard SBLive!/Audigy DOS drivers can't initialize the card.
And the standard SBLive! win drivers can't see this card too by the way... I have found the card CD but after heavy Internet searching.
*Censored* Dell.
*reading the post above...
Interesting...
Reply 32 of 40, by Jorpho
Note that there are at least two different DOS drivers: SBINIT.COM and SBEINIT.COM. No idea what exactly the difference is between them. (It could just be the name.)
Reply 33 of 40, by Sammy
i habve a backup of the DOSDRV Folder which is working on one Pc.
But the same files and the same card on another pc can't initialize the Card.
It depends on Mainboard Chipset if SB-Emulation works in Dos.
Reply 34 of 40, by KT7AGuy
Gamecollector wrote:
Have tested SB0220 for DOS. No, the standard SBLive!/Audigy DOS drivers can't initialize the card. And the standard SBLive! win […]
*Censored* Dell.
Interesting...
Indeed, very interesting. I've always avoided the SB0220 for Win95/98 because of its supposedly-abysmal DOS support. It might be a better choice for WinME? Personally, I will still avoid this card for Win9x. 1st and 2nd generation SBLive cards are proven tech when it comes to Win9x and DOS capabilities. Why cause problems and headaches when they are easily avoided? CT4830 is about $5 on eBay and they work really well in Win9x.
When I got my SB0220 years ago, I purchased it specifically for WinXP so that I could connect it to a toslink spdif IO bracket. In the days before CL released the SBLive Win2K/XP driver pack, these cards were notorious for having buggy and impossible-to-find drivers. From what I remember, if you didn't have the original installation CDROM you were totally screwed. CL didn't even make drivers for it available until 2003 with "LiveDrvUni-Pack(ENG).exe". With that driver pack, the SB0220 is an excellent card to use under WinXP; reliable, stable, and very easy to setup. It may not have the features of the Audigy 2 ZS, but it's awfully nice to pop in the card, double click on "LiveDrvUni-Pack(ENG).exe", and be up and running in minutes with no hassles and a very lightweight driver/software package. If you do want to use the SB0220 in Win2K/XP, then check the CL website for additional updated drivers and software. There are several updates available, but I've never used them so I can't say if they're good or even necessary. Under WinXP, I've always just used "LiveDrvUni-Pack(ENG).exe" by itself with very good results.
When I purchased my SB0220, I made sure that the original driver disc was included. If you like, you can get it here:
http://www.vogonsdrivers.com/getfile.php?file … 809&menustate=0
Also, while Holering's instructions do work, I've developed my own solution that builds upon his. For the CT4830, use the original installation CDROM, which you can get here:
http://vogonsdrivers.com/getfile.php?fileid=804&menustate=0
1 - Install drivers and software from the CDROM, then reboot twice to make sure everything is working OK.
2 - Next, check hardware manager and make sure the gameport is enabled. If it's disabled, enable it. Windows will ask for the Creative Labs Sound Blaster Live! CDROM. When it does this, insert the disc and point to "d:\audio\english\wdmdrv".
3 - Reboot
4 - Update the sound & gameport drivers by running sblw9xup.exe.
5 - The system will ask if you want to keep existing files. click on "Yes To All".
6 - You will probably get some errors and maybe even a BSOD. Just continue on until it asks you to reboot. When prompted, reboot your system.
7 - Update the sound & gameport drivers again by running sblw9xup.exe again.
8 - The system will ask if you want to keep existing files. click on "Yes To All".
9 - This time around, you shouldn't get any errors or BSODs. When prompted, reboot your system.
10 - Reboot again
By doing this, I've been able to get full SB16 DOS emulation working with my CT4830 cards in Win9x.
Reply 35 of 40, by stamasd
You can easily change the firmware of any SB Live card to look to the drivers like any other SB Live if you have an EEPROM programmer and a bit of soldering skills.
http://ixbtlabs.com/articles/livetolive51/index.html
The same is possible for other families of Creative cards. I've done it with X-Fi.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 36 of 40, by gdjacobs
The SB0220 has a modified APU. Simply changing the firmware doesn't sound like a good idea to me.
I'm glad it's working in DOS! The main thing is that you're able to enjoy the titles you want to run. Part of the fun, though, is trying different things, finding what doesn't work, then finding a way to fix the problem.
Software and hardware are usually quite reasonable as long as you stay away from the rare items and boxed games. Especially in DOS sound devices, others have run into limitations with PCI cards. When you find one for a low price, an ISA sound card (or two) might be a handy thing to snap up.
Reply 37 of 40, by stamasd
You're actually not modifying anything in the firmware, only changing the device ID so you can install older or newer drivers. Worth a try, and easy to revert if it doesn't work.
I/O, I/O,
I/O, I/O
Reply 38 of 40, by Mrowa
I managed to make SB0220 working on my t5720 Win98 or DOS following way:
1) I have the fat t5720 with PCI riser. I had to do the -12V mod with MC34063A (GND from B3, +12V from A2 to VIN, VOUT (make it -12V) and connect to B1). Otherwise sound card is very silient in both DOS and Windows
2) I installed ONLY drivers from https://vogonsdrivers.com/getfile.php?fileid= … menustate=43,36 (ONLY Audio\Drivers\setup.exe) - then it works on Windows
3) I took https://www.philscomputerlab.com/sound-blaster-live.html (audigy_2_zs_drivers_for_sound_blaster_live_2.1.zip) and installed ONLY DOS Drivers from inside. It will allow DOS sound in Windows & in pure DOS (auto config, no manual changes0
4) For testing I thing Constructor (autodetect of soundcard settings under DOS) or Duke3D (for quick manual settings using trial and error method)
5) Additionally I connected internal mono speaker to SB0220 10pin connector (pin 1 & 2) Ultima Underworld 1 and Space Hulk
BTW, SB0100 is also very quiet without -12V mod 🙁
Reply 39 of 40, by Mrowa
Mrowa wrote on 2025-09-04, 20:16:
I managed to make SB0220 working on my t5720 Win98 or DOS following way: 1) I have the fat t5720 with PCI riser. I had to do the […]
For 10pin connector correct link is: SB Live 5.1 Digital Front Panel Connector
