Reply 20 of 121, by brostenen
Modems, non-RJ45 networks cards (token ring + bnc) and non-usb/parallel printers are on top of my list.
I do understand that sometimes there are someone that are in need of these parts.
Reply 21 of 121, by stamasd
Errius wrote:
Oh yes, anything related to pre-RJ45 networking.
Disagree. Back in the early 2000s I came across a large stack of old Microdyne Exos205 network cards. Some were 8bit, some 16 bit ISA but the hardware on both was about the same. They had an early Intel PHY controller, and a 80186 controller with its own dedicated memory and running its own embedded RTOS that was loaded by the driver at boot. They were pre-rj45 but still Ethernet (10base2) so they could be made to work in regular Ethernet networks (coaxial). I had a lot of fun with them for a while helping hack a Linux driver for them. A few years later I had to move, and they were all lost in the move. I still regret losing them. I recently saw one of those sell on eBay for close to $200.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 22 of 121, by konc
Proprietary cd-rom interfaces. The drives don't work any more, so there's nothing to connect them to.
Reply 23 of 121, by Errius
Are there still corporate networks running over BNC or other old hardware? The only justification for this I can think of is if the old cables run inside walls or other inaccessible places and its not economic to rip them out and replace them.
Is this too much voodoo?
Reply 24 of 121, by brostenen
They would be more than 20 years old by now, so I think they would be left inside the wall and new technology is in use.
Too expensive to keep old technology running versus replacing with new.
Reply 25 of 121, by FaSMaN
I wont shame network cards that quickly there still useful, besides one day I just might do a BNC based network just for the fun of it 😜
Reply 26 of 121, by Sedrosken
brassicGamer wrote:
Personally, any post-Tualatin Celeron is wholly pointless.
Actually, the post-NetBurst ones make a strong showing for themselves. But, being based on the Core architecture, it'd be odd if they didn't. For a non-gaming focused system, or one dedicated to playing older games, the Celerons are just fine.
I find modems and printers to be nigh-unusable 10 out of 9 times, much like everyone else it seems.
Shoushi: Dimension 9200, QX6700, 8GB D2-800CL5, K2200, SB0730, 1TB SSD, XP/7
Kara: K7S5A Pro, NX1750, 512MB DDR-286CL2, Ti4200, AU8830, 64GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428, CT2800, 16GB SD2IDE, 95CNOIE
Reply 27 of 121, by adalbert
non DVB TV Tunners
Actually I use a analog TV tuner in my main PC, so I can connect C64 or Amiga to it, and also I can display or capture S-Video signal from another computer, which allows me to see its desktop in a window.
Reply 28 of 121, by Errius
I have a Matrox Marvel G450 eTV which is still useful for capturing video from VHS tape. (That reminds me that I still need to digitise my family's old videos. With Blu-rays it's finally become feasible to archive hundreds of hours of MPEG-2 video in a reasonable number of disks.)
Reply 29 of 121, by candle_86
Wireless B network Cards, Ive got aobut 6 of them and they dont work with any modern secure network.
Reply 30 of 121, by archsan
brassicGamer wrote:
Personally, any post-Tualatin Celeron is wholly pointless. And a loud SCSI hard disk is better than none. Non DVB TV tuners are definitely pointless.
Tualatin Celeron = P6
Netburst Celerons/P4s/Xeons can go to hell
However Conroe-L Celeron 4x0 series are also P6 derivative (which you can put on a Win98/Me-ready motherboard e.g. ASRock ConRoe865PE, 775i65G or similar ASUS P5PE-VM and Gigabyte version).
Yes, that lowly 2.2GHz "Celeron 450" (even the name has a good retro-ish ring to it 😉) will beat any of your Tualatins! And 3.2/3.4 P4EE Gallatin too I'm quite sure, though I haven't see any benchmarked comparison. That'd be interesting to find out. It definitely WINS on power efficiency at just 35W though. I just want to annoy those who have P4 machines in their sig that's all. 😜
In any case you should also be able to put Core 2 X6800 (unlocked) on most of the above mentioned boards just for bragging rights. And that would be even more amusing ~3GHz Core vs 3+GHz P4. 😀 😀 😀
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 31 of 121, by hyoenmadan
archsan wrote:
Tualatin Celeron = P6 Netburst Celerons/P4s/Xeons can go to hell However Conroe-L Celeron 4x0 series are also P6 derivative (whi […]
brassicGamer wrote:
Personally, any post-Tualatin Celeron is wholly pointless...
Forgive him... The kid doesn't know what he's saying 😉.
Reply 32 of 121, by candle_86
or just OC the celeron most will hit over 3ghz
Reply 33 of 121, by archsan
Jeez guys, calm down with the nested quotes already. 😜
The problem is that the above boards (865PE/865G chipset) work best with 800MHz FSB, and the Celeron has locked multi, while the C2X doesn't. I haven't tested the C2X but I hope it can do 3GHz while lowering the FSB to 800, not sure if it's going to work flawlesly, I have to get the chip first. OK... let's save that for another thread. 😀
Back on-topic: most undesirable piece ... would be any card/board with badly rusted metal plates/connectors/parts ... That just turns me off 🙁
Reply 34 of 121, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
How about the serial 9-to-25-pin adapters?
1+1=10
Reply 35 of 121, by tincup
Zip drives.
Reply 36 of 121, by dogchainx
tincup wrote:
Zip drives.
I actually have a special place in my heart for those things, especially the SCSI versions, Iomega being a Utah company and I know a few people who used to work there. 😎
However, since I have 9 of them (7 are SCSI), the rest I donate to the local thrift store. The SCSI are handy with old Macintosh SE's.
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 37 of 121, by carlostex
tincup wrote:
Zip drives.
Actually ZIP drives can be quite useful to move data around between old machines, 8088, 286, 386, 486, specially if you don't have them networked and still use hard drives instead of Compact Flash or SD cards.
Reply 38 of 121, by Tetrium
carlostex wrote:
tincup wrote:
Zip drives.
Same. This is what I actually use my ZIP drives for. Of course they can die, but so can basically everything else.
My retro rigs (old topic)
Report spammers here!
Reply 39 of 121, by tincup
dogchainx wrote:
tincup wrote:
Zip drives.
There was some talk about them recently so I figured there might be a advocate or two out there 😀. But personally I found them horrible to use and uniquely unreliable and quirky. We used them as backup drives for a few years at work and they proved deficient in the role - I usually needed to have the same data stored on 2 or 3 of the damn cartridges in hopes that at least 1 would work if needed. Home use fared no better.
However I can see their use in ferrying more-than-floppy size data between retro rigs. - but for that I find an external USB dock easier and more reliable - then again I only run W95+ rigs.
I tossed all my ZIP gear about 7 or 8 years ago: 3 or 4 drives and 20 or so disks... did I make a regrettable "retro blunder"? God knows I've made them before.
