stamasd wrote:No, I have two actual 9500s. They do have the dinky little floppy power connector, but still don't get too hot. Maybe I'm just l […]
No, I have two actual 9500s. They do have the dinky little floppy power connector, but still don't get too hot. Maybe I'm just lucky. 😀
(I never overclocked either of them)
This is not my picture, but they are exactly this card: http://www.ixbt.com/video2/images/r9500/r9500-scan-front.jpg
(with missing RAM chips because they're 64MB only)
this is the exact model I had in 2003, but with the vantec cooler I linked earlier, it gave me a great time with OC and the pipeline mod, after removing the shim, using a good thermal paste and using the vantec linked earlier + a case fan under it I could run the core all day long at 370MHz+ with the 8 pipelines running, the only downside was 64MB memory, but it was really fast on most games from 2003 and earlier.
386SX wrote:
Lately I've seen a 9500 heatsink basically not connected to the R300 core for old thermal paste. Maybe the heatsink is cold and the back of the pcb is not. The R300 is definetely a big core for its time (even today maybe?).
I think this is possible, the shim on the R300 + custom coolers might have worked poorly (the contact) I remember it being fairly common with the OC crowd to remove the shim, which is what I did and gained over 30MHz of OC, but, at the same time I replaced the thermal paste and reinstalled the cooler, so who knows exactly what the shim removal itself gave me.
maybe I should remove the shim on my current 9500PRO to test it, but I really don't feel like damaging it! and I'm quite happy with keeping it at 330MHz only nowadays.
edit: for what is worth I compared the 9500PRO with my EVGA 8400GS G98 PCI:
Pentium 4 Northwood 2.4GHz @ FSB166 (3GHz)
768MB(3x256) DDR @ 333 CL2.5
Asus P4PE (845PE)
Samsung Hard Drive
DVD drive
Radeon 95 […]
Asus P4PE (845PE)
Samsung Hard Drive
DVD drive
Radeon 9500PRO 128MB Catalyst 10.5 @AGP4x stock
Radeon 9500PRO 128MB Catalyst 10.5 @AGP4x OC (330/305)
Geforce 8400GS 512MB G98 PCI 33MHz Forceware 257.21 (567/500)
Windows XP SP2
Bios screen
9500PRO - 112W
8400GS - 104W
Windows idle
9500PRO - 84W
9500PRO OC - 88W
8400GS - 70W
rthdribl
9500PRO - 157W (32FPS)
9500PRO OC - 160W (37FPS)
8400GS - 141W (39FPS)
Crysis Demo Benchmark GPU (800x600 low)
9500PRO - 148W (31.7FPS)
9500PRO OC - 152W (34.8FPS)
8400GS - 128W (19.1PS)
Aida CPU test (CPU+FPU+Cache)
9500PRO - 141W
8400GS - 126W
Crysis is not very representative due to the low performance, idle (and CPU test) is perhaps unfair because of the idle power optimizations newer cards had, but if you look at rthdribl they have close enough perf and the 9500 makes the system use at least another 16W; so 18W total for a 9500PRO at least would be very unrealistic, I would guess the 8400GS is using at least 10-20W, which makes me think as high as near 30-40W draw is realistic for a 9500PRO, the 9500NP with half the pipelines will use less I think, but as low as a 9600PRO?
