Post your rendition of Passport.MID
Reply 20 of 69, by Ampera
nukeykt wrote:
My favorite ones
Not bad. Roland doesn't screw around, if I ever find a grand on the street, I'll pick up a MIDI controller and synth machine from them.
I can dream....
Reply 21 of 69, by James-F
The SC-55 is only like 100$ on ebay, it is a must have for any DOS retro gamer or MIDI lover as it is THE synth everyone composed on and tried to copy or steal its sounds.
Even Microsoft midi synth everyone familiar with is a low quality version of the SC-55 samples.
Reply 22 of 69, by keropi
If there is interest I can record the Yamaha SW-20PC, it has a 2mbyte OPL4 synth
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 23 of 69, by Stretch
Recorded under MS-DOS with the SuperSAPI OPL3 driver on the Audician 32 Plus (YMF718)
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
Reply 25 of 69, by Jade Falcon
Rank BANNED
BANNED
sound blaster audigy. server 2000
Not the best recording.
Reply 26 of 69, by Ampera
Sounds like I am being hit in the head by the drums.
Reply 27 of 69, by Jade Falcon
Rank BANNED
BANNED
Yeah the recording did not come out right. I'll try again.
Reply 28 of 69, by Stretch
Kamerat wrote:
How do you set up playback with the SuperSAPI driver loaded?
I downloaded the MS-DOS SuperSAPI OPL3 FM driver from the bottom of this post on the SOUNDSHOCK Forums Voyetra Super Sapi OPL3 driver / Palette files with Video
You run initdrv.bat and then use the included midplay.exe to play a MIDI file.
Reply 29 of 69, by Kamerat
Thanks a lot Strech! 😀
YouTube channel
Reply 30 of 69, by Jade Falcon
Rank BANNED
BANNED
OK, I played around with my soundcard`s settings. I think I got it all fixed. Audigys are abit different then some cards
Even enabled reverb and all the other cool settings.
Reply 31 of 69, by Ampera
No reverb sounds best. The first one was like having a gunshot for drums, and the reverb one is just like having a gunshot for EVERY sound.
No reverb one sounds pretty good tho.
Reply 32 of 69, by Jade Falcon
Rank BANNED
BANNED
Yeah I have to play with the reverb. Audigy have alot of reverb settings if you funnel midi output thought EAX.
on my end the reverb copy sounds alot better, but my setup is not normal for most.
Reply 33 of 69, by Jade Falcon
Rank BANNED
BANNED
OK, Now I gone over kill with the sound settings for my Audigy.
I was trying to get rid of the punchy dums and whatnot and found some setting I did not know excited, yeah careful with these files if you have headphones. The passport overkill.mp3 can make you loopy.
EDIT:
These aren't mixed recording. its straight up midi play back form a Audigy, Although its ran though EAX.
Reply 34 of 69, by sprcorreia
Edirol SD-90 Studio Canvas recording.
Reply 35 of 69, by Ampera
That's a remix of Passport.mid? Doesn't follow the same notes. The drums sound a bit heavy on that one too.
Reply 36 of 69, by sprcorreia
No. It's just playing the file, default config.
Reply 37 of 69, by Ampera
Wrong file then. The chorus starts way too late, and some notes are missing/changed
Reply 38 of 69, by Jade Falcon
Rank BANNED
BANNED
Some sound cards instrument libs/sound fonts can do odd things to files. It does sound abit odd.
Reply 39 of 69, by oeuvre
One recording with the OPL3 chip on my Sound Galaxy and the other with the wave synthesizer it has.
