MFM ST-251-1 HDD: drive not ready error
Reply 20 of 24, by krivulak
Did you disable the BIOS HDD settings and then tried booting? As it was said, MFM cards has its own BIOS so the PC's BIOS can do mess.
Reply 21 of 24, by keropi
yes, BIOS HDD not installed , makes no differece - still drive not ready
Reply 22 of 24, by krivulak
When was the drive last used?
Reply 24 of 24, by krivulak
Yeah, it looks like Low Level Format has degraded greatly. Looks like the partition is no longer existing, so I am afraid you will not be able to read data again. If you want to use the drive, you must LLF it.
Also, in debug try
g=c800:0
If it hangs the machine, it does mean that it cannot access the memory of the MFM card. Can be wrong, but can be right since some controllers does not have the tool built in.
