Voodoo 2 Quake 2 performance question
Reply 20 of 22, by F2bnp
There's nothing unsafe about overclocking these. You are not really adjusting the Vcore, are you? If not, you're safe 😀.
I don't think you're that lucky, it's just MMX clock high, I have never seen a 166 model unable to run at 200 for example! If you want to see if it is 100% stable, try crusher1.dm2 on a loop. If it crashes, you're not 100% stable 🤣 .
Reply 21 of 22, by appiah4
What console command loops timedemos? 😁
Reply 22 of 22, by F2bnp
I don't know to be honest, you could do it yourself after each successful run. They should take plenty of time on the MMX and honestly, if it passes 2-3 of them, you should be good to go.
