Does PCI-E 4x have enough bandwidth?
Reply 20 of 27, by weldum
yeah, i've noticed that. So I won't be upgrading that machine, i've put the Radeon 6450. The 9600GSO is in another machine.
I have another question through, my main rig has some problems with newer PCI-Express cards, very strange problem indeed.
The slot is 2.0 x16, but in newer videocards like HD7950, R7 370 and RX 560, the mobo just works at 8x.
The board is SLI and CROSSFIRE compatible, but i've never used for that.
All the 3 boards (HD7950, R7 370 and RX 560) works well but had that strange problem. Also, the fps varies a lot with these 3 boards.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 21 of 27, by cyclone3d
weldum wrote:
yeah, i've noticed that. So I won't be upgrading that machine, i've put the Radeon 6450. The 9600GSO is in another machine. […]
What motherboard?
Do you have the latest BIOS for it?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 22 of 27, by weldum
Is a GIGABYTE GA-990XA-UD3
It has the latest bios
Reply 23 of 27, by Matth79
Are you using the top x16 slot for graphics, and the next x16 slot (@x8) must be unused
Reply 24 of 27, by mrau
where do You check that?
Reply 25 of 27, by weldum
yeah, the only card is the GPU and is at the top x16 slot
It works excellent, but in my brother's computer (A10 7770K-8GB DDR3) it performs better, for example I can play GTA V with all max at 900p (the monitor resolution) with almost no frame drops, but in my pc (FX6100 OC to 4GHz-8GB DDR3) it has a lot of frame drops.
Maybe the PCI Express version makes a difference since mine is 2.0 but the other is 3.0.
What?
Reply 26 of 27, by lordmogul
Are both systems running similar memory configs? (clock speed, latencies, dual channel)
Are both holding their clock? (overheating)
Same version of WIndows?
Same power settings?
Enough space on the system drive?
Same driver versions?
Same driver settings?
P3 933EB @1035 (7x148) | CUSL2-C | GF3Ti200 | 256M PC133cl3 @148cl3 | 98SE & XP Pro SP3
X5460 @4.1 (9x456) | P35-DS3R | GTX660Ti | 8G DDR2-800cl5 @912cl6 | XP Pro SP3 & 7 SP1
3570K @4.4 GHz | Z77-D3H | GTX1060 | 16G DDR3-1600cl9 @2133cl12 | 7 SP1
Reply 27 of 27, by weldum
lordmogul wrote:
Are both systems running similar memory configs? (clock speed, latencies, dual channel) Are both holding their clock? (overheati […]
Aside from the hardware differences, everything software was the same, but now can't test anymore, only have the rx560
