Reply 21 of 129, by dreamblaster
Wow Scali, thanks this is really great !
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 22 of 129, by appiah4
Wouldn't it in theory be possible to use wavetable daughterboards and/or MPU-401 devices in a similar fashion?
Reply 23 of 129, by Scali
Not as-is. The Dream chip used on this device has a parallel MIDI interface. Wavetable is serial (basically standard MIDI, with a different connector). So you'd need to add a UART between the LPT and the MIDI device, to clock out the incoming bytes at the correct speed for MIDI (and with the correct start and stop bits).
Reply 24 of 129, by dreamblaster
Yeah that could be done, but does it make sense ?
Reply 25 of 129, by Scali
I guess you'd basically end up with MPU401-over-LPT.
Which is more or less what the DreamBlaster S2P does, except in this case you would need to add the synth yourself.
Not sure what the target would be exactly. Systems that have parallel ports, but no (free) ISA slots or USB for a regular MIDI interface?
In fact, I'm not sure if USB MIDI can be used from DOS at all?
Reply 26 of 129, by appiah4
Yeah, basically MIDI for MS-DOS laptops.
Reply 27 of 129, by keropi
can't you already have that with softMPU's serial function and a module that has serial port like the SC55-mk2 or MU-80 for example?
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 28 of 129, by Scali
Yes, but the 'serial port' bit is rather limiting. A standard MIDI output and/or wavetable header would allow you to use any MIDI device.
Even a Yamaha FB-01, for IBM Music Feature Card compatibility! 😀
Reply 29 of 129, by appiah4
Also, the serial port competes with many other peripherals that could be useful for gaming whereas the LPT is basically redundant and always available.
Reply 30 of 129, by Scali
Also, I previously described a way to connect up to 256 ports to a single LPT.
If you put two 8-bit latches on there, you can use one for address and one for data. A single line on the LPT selects between the two latches you write to.
You now effectively have an 8-bit address bus. With some address decoding logic, you can select between a number of chips/ports on the same device.
This should easily allow to combine an OPL3, CMS, Tandy and MPU401 on the same board.
Reply 31 of 129, by bjt
This is really cool, nice one 😎
Unfortunately, many/most GM-supporting games run in protected mode via DOS4GW or similar, and the port-trapping technique used by SoftMPU won't work with those.
SoftMPU was originally aimed at intelligent-mode MT-32 games which are all real mode.
Virtualising ports transparently in PM is possible, though. More info here: http://www.os2museum.com/wp/any-soundscape-vivo-fans-here/
Plenty there for someone with lots of spare time to get their teeth into!!
Reply 32 of 129, by jaZz_KCS
This is really cool. It can be used to give old laptops midi capabilities (and good sounding ones!). The sounds can be played through the speaker with the "Wave speaker driver" whereas this device would handle the midi music. Not necessary to have both CVX4 and S2P attached at the same time 😀 Looking forward to using this to play for example SimCity on W3.11 with music 😜
Reply 33 of 129, by Scali
bjt wrote:
Unfortunately, many/most GM-supporting games run in protected mode via DOS4GW or similar, and the port-trapping technique used b […]
Now that you mention it... I believe that the GUS software also does this. I always used to play DOOM with Sound Canvas via MegaEm, so that implies that MegaEm works under DOS Extenders. I'm pretty sure that SBOS does as well.
So it might be worthwhile to check how they handled things. I don't think the GUS has any special hardware for redirecting port writes (it has a MPU-401 UART), and MegaEm requires EMM386 to be loaded if I recall correctly.
In which case, they are probably just doing a way of port virtualizing that works in both real and 386 mode.
Reply 34 of 129, by dreamblaster
you prefer this on lpt port or serial port ?
Reply 35 of 129, by chartreuse
The LPT port has the advantage that it can work with games running with serial multiplayer since many laptops only have one serial port on them.
Reply 36 of 129, by dreamblaster
well ok, then how about a MIDILPT project ? this sounds fun to do.
I suppose this should be midi out only,
how do you see it, only 1x MIDI out DIN connector
or 1x MIDI out DIN connector + Waveblaster header
or 2x MIDI out DIN connector ?
Reply 37 of 129, by appiah4
dreamblaster wrote:
well ok, then how about a MIDILPT project ? this sounds fun to do. I suppose this should be midi out only, how do you see it, […]
1x midi anda 1x waveblaster iş beste imo
Reply 38 of 129, by dreamblaster
ok
will see what I can make
Reply 39 of 129, by jaZz_KCS
How's the S2P prototype doing / performing so far? This would be a marvelous addition.
