Reply 20 of 28, by Burrito78
- Member
wrote:wrote:Even a "noisy" card like the CT1740 with amplifier disabled is night and day when compared to its 8 bit predecessors, so I just end up using SB16 most of the time despite my good memories of the Sound Blaster Pro.
Like James-F already wrote some time ago, and in my own experience, it is the OPL3 channel that raises the noise floor of the SB Pro. Lower the FM slider and the noise floor disappears. Not much of a solution I know. But interesting to note that the digital sample part of the SB Pro is actually reasonably clean.
Do you mean this video demonstration?
https://www.youtube.com/watch?v=GdcVedXM88s
There is no FM slider afaik, it should be called MIDI and means FM synthesis + Wavetable header.
