Reply 20 of 33, by tony359
- Oldbie
Sorry for resuming this very interesting thread!
I've replaced the RAM on my CT4520 (existing one was shorted) but the board now refuses to be detected. I've checked and re-checked everything. No shorts and each pin is going to either the EMU, the main chip or it's N/C-VCC-GND.
The chips I am using are SIEMENS HYB5118165BSJ-60 and they seem to be pin to pin compatible with the one used by @thermalwrong in the first post (which should be NEC 4218165-60 if I see that right).
And yes, I did move the 0-ohm resistors accordingly. I am familiar with soldering etc, I have a microscope and used a proper hot air station to remove the chip from the memory modules and to move the SMD resistor - I then solder the chip manually to limit the thermal stress to that old board.
Any ideas? The only three scenarios I can think of are
1. I made a mistake somewhere
2. The chip broke while removing/installing (I did test the memory modules before starting and they were passing a long memory test)
3. The chip is somehow not compatible with the board
Any ideas appreciated! 😀
Thanks
Tony
My Youtube channel: https://www.youtube.com/@tony359
