Reply 20 of 22, by Thermalwrong
flecom wrote on 2026-06-05, 20:18:exs1s wrote on 2022-01-10, 23:32:wulp wrote on 2021-10-11, 19:50:It's working!
Now searching to install a cf-card (hdd is dead..)Do not even try and use a CF card IDE adapter. It will fry your HDD controller chip. Trust me on this. As I said in a post above, only ever use a HDD listed in the BIOS with a LTE Lite.
CF to IDE cards do work, however, with the Elite and 5000 series which both have a different HDD controller.
any more info on this? I don't understand why a CF card would fry the IDE controller but not a regular hard drive, anyone tried a 44pin SD to IDE adapter if anything? that would have active electronics vs passive CF adapters
could use a 256MB or 512MB card if it has a bios LBA limit (I ended up doing that on my PS/1)
Yeah I think I can explain. The LTE Lite uses a 50-pin connector which covers the 44-pin IDE pins and two master/slave jumpers. If that's installed misaligned it could put VCC into the wrong pin on the CF card, potentially damaging that and potentially damage the IDE controller (less likely).
The IDE controller and HDD connector are also often damaged by the leaked standby battery, perhaps that weakened some traces and voltage on the wrong pins finished it off.
The only hard drives that will work on the LTE Lite are ones in the HDD table, so there's no chance to use a CF card unless perhaps the BIOS's hard drive table is edited (which I've done successfully with an old award bios) or you can get it to use an option ROM somehow.
Personally I was able to find one drive that matched up with the BIOS HDD table, with my last LTE Lite that had a dead drive.
