Reply 20 of 51, by Ozzuneoj
- l33t
Good news! I got it to play music! I copied all of the .pat files and other contents of the midi folder from the gus complete pack (ult\midi) to the ultrasnd\midi folder and now it works! Thanks for the tip Rawit. 😀
I'm still only getting sound from the left channel though. I'm also having trouble getting it to consistently make any sound at all. Touching the audio jack cable (line out or spk out) while the system is running makes the audio cut in and out a bit and eventually it will stop completely. Once it stops completely, shutting the system down and turning it back on will bring the audio back, but it isn't real consistent. I'm hoping it just needs a recap. It seems like something is very sensitive to changes in the physical connections. I also had a slight pop from the speakers (both, even the right channel that gets no output) when I connected a midi cable to the gameport. It had nothing connected on the other end so it must have been static related.
It was in pretty sorry shape when I got it so it could be any number of things, but I'm really happy to hear it play music. I must say, the "midi256" demo tracks that come with the gus complete pack sound fantastic, even with just one channel and a flaky output. I found a way to get some (tested!) memory for this thing super cheap, so I ordered some. I'll keep tinkering with it.
I have to keep reminding myself I'm also using a 20Mhz crystal rather than the 19.7568 one that is expected, so there is a slight possibility that that is causing the issues, but at this point I'm thinking it is a bad cap\chip, broken solder joint or something else electrically wrong, rather than a timing or clock issue. I have no knowledge of these things though, so if someone else any more input, it is welcome.
All in all, this is proving to be a fun restoration. I do wish I had a way to refinish the red PCB coating in areas where it has flaked a bit from improper storage, but I don't want to mess it up further.
Another thing I'm noticing is that I can faintly hear music coming from the motherboard when music is playing. Sort of like the sound of coil-whine from a high powered graphics card when running at high frame rates. I used a high tech precision listening device (a bic pen tube with a tiny funnel on the end) and narrowed it down to the tiny crystal oscillator on my Wintac W6BXA 440BX motherboard. Why this would be resonating to the frequency of the music, I have no idea. Maybe its a side effect of the crystal on the board not being exactly correct, or it could be related to the odd electrical issue I've been having with the card. Anyone ever hear their computer play high pitched mini-midi music from a crystal before? 😵
