Athlon 64 X2 6000+ still fast?
Reply 20 of 23, by xjas
If you really want to max out an AM2 board, Phenom IIs can be had dirt cheap, especially if you're not after the X6 parts. I got an X3 720 Black Edition for literally under $10 USD shipped. It's also an 89W part (assuming you don't unlock the 4th core) and should be a pretty solid direct-swap upgrade for the 64x2 4800+ I'm replacing. (Caveat: I haven't actually swapped it in yet.)
But yeah, I agree a 6000+ is still a nice chip, and should be absolutely fine for a "light office" Linux machine. You might want to bump it up to 8GB RAM for surfing.
Reply 21 of 23, by Standard Def Steve
386SX wrote:
P4 3,4: CPU Blowfish test: 10,5 seconds 6000+: 6.5 seconds (lower better) […]
P4 3,4: FPU Raytracing test: 55 seconds
6000+ 7 seconds (lower better) 😲
No surprises there. It’s using both cores of the x2, plus K8 has a much faster FPU than Netburst. That’s what made it so dang good for games back in the day. 😀
"A little sign-in here, a touch of WiFi there..."
Reply 22 of 23, by The Serpent Rider
Not every board can work with Phenom.
Reply 23 of 23, by 386SX
I wasn't expecting such difference. But still the P4 3,4 with SSE3 for a socket 478 cpu, is incredible in the real world os usage. I always preferred the XP 3200+ back in the past but it's all another world really.
