Reply 20 of 62, by AvalonH
- Member
wrote:can you give an example link? how would you even send 3 bytes of information in 1 byte? PS2 mouse communication is standardized, afaik there is no 1 byte mode. https://www.win.tue.nl/~aeb/linux/kbd/scancodes-13.html
I just noticed this issue has been mentioned on the recent Dosbox commits
https://sourceforge.net/p/dosbox/code-0/commit_browser
under Dosbox commit r4191 it says:
Only standard 3-byte mouse data packets are supported, so return an error for other packet sizes. MS Mouse driver versions 9.X and later use 1-byte packets for some obscure reason, and now they won't load instead of messing up
The author was ripsaw8080 who posts in these forums, maybe he can clear up how MS mouse ver 9 and newer fixes this high CPU utilization on these motherboards.
