Fixing GMB-486UNP
Reply 20 of 35, by Eep386
Apologies if updating this thread ruffles any feathers, but here's a hacked version of that BIOS, which re-enables some hidden features that would otherwise help performance, such as HDD Block Mode, Cache Burst Control and a few others.
I've tested this on my repaired GMB-486UNP v2.2 board, and it seems to work like a charm. After tweaking the formerly-hidden options, the performance is right back to where it was with the AMI BIOS prior to the upgrade. Except now I get early LBA support among a few other niceties. 😁
Reply 21 of 35, by evasive
In this case it doesn't because your post is not of the : me too! can you help me with <totally unrelated issue>?
You actually added useful info. May I ask how you patched/hacked that bios? Did you use rom.by BP patcher or something else?
Reply 22 of 35, by Stiletto
Eep386 wrote on 2020-08-19, 23:29:
Eh, can't speak for everyone but my personal (in)tolerance is something like 3-4 years since last reply. A 2019 thread? You're good, dude.
do the Fandango!" - Queen
Stiletto
Reply 23 of 35, by Deksor
Come on it's not quite dead yet 🤣
I still have to figure out what causes the turbo button to be stuck on slow constantly, but I don't have much time, so it's "on hold" for me. If you have any idea, please share 😉
Reply 24 of 35, by Eep386
evasive wrote on 2020-10-29, 08:20:
Hello!
I used AWDHACK with some other tools (MODBIN I think it was). Just re-enabled the hidden options.
Reply 25 of 35, by Eep386
Deksor wrote on 2020-10-31, 18:46:
Not sure what might cause that - something's shorted somewhere.
It may be possible to mod the BIOS so that it ignores the Turbo switch and runs in a fixed speed instead, but I couldn't tell you if that would work or not.
Reply 26 of 35, by NewtoM
Cool! It would be nice to have an Y2K patch for this BIOS, too. 😁
Reply 27 of 35, by NewtoM
And I just wanted to throw in that I also have one these mainboards (v2.3, though). So if any further measurement is required, just let me know.
Reply 28 of 35, by Deksor
Well if you can find out where the turbo button connects to on the chipset, that would help me a lot ^^
Now it may not be a direct connection, but there's no way I can figure that out myself with a broken circuit.
Reply 29 of 35, by NewtoM
Hey Deksor,
I measured around a bit and I did indeed find a direct connection. Please see attached pictures.
I hope it helps!
NewtoM
Deksor wrote on 2020-11-13, 10:05:
Reply 31 of 35, by NewtoM
Deksor wrote on 2020-11-20, 08:33:
Ah thanks a lot ! I'll check that chip 😀
You're welcome! Please let me know if it works on your revision of the board.
Reply 32 of 35, by steepf
Hi everyone, i have same motherboard. but on my board absent two items, marked as Q5 and CU35, who already has this board may be you could help me and tell me what it is the element?
Reply 33 of 35, by jg77
Hi everyone, I have this exact same motherboard, version 2.2, and the exact same issue. So no post, nothing on screen, nothing comes out the beep speaker. I also checked voltages, and every things seems to be where you expect it. Also the turbo switch pins are connected. There was minimal to no damage from the battery (which is removed). The bios chip is on the board (Award bios), but I read a current on almost every pin, and with my current knowledge I don't know if that is supposed to be like that. The current I read is varying between 2,7 and 5 volts, depending on the pin (ground has no current).
There was 1 give away why this board wasn't working, a trace on the backside of the board, half under the cpu socket, was blown out the board. I fixed that with a wire and all traces have continuity where you expect it.
When I run power through the board the cpu gets warm (currently using an intel DX2 66mhz)
Anyone here still investigating this board and its issues like Deksor described?
Gray haired collector.
Few items from my collection; IBM 5150, 5160, 5170, Model 30 286, 5151, 5153, Compaq Portable III, SLT/286, Olivetti M24, M240, M290s.
Reply 34 of 35, by Cvndani
I have the same Mobo, but it don't test the ram, power up, shows cpu model and it don't test ram and still in the same status. Any idea? I try a lot of ram modules, same result.
Reply 35 of 35, by jg77
I just bought a simple ISA POST-check card on Amazon. It pointed me to a keyboard error 05.. I replaced the keyboard bios with a known working one and presto, I now have another working VLB board!
