Reply 20 of 24, by rasz_pl
socket_42 wrote on 2026-05-09, 11:34:It did this both with a closed and open turbo jumper.
weird
socket_42 wrote on 2026-05-09, 11:34:Is it possible, that I bricked the CMOS? (i assumed, that CMOS settings were volatile without a battery)
Not possible. The only explanation I have right now is board was marginal to begin with.
socket_42 wrote on 2026-05-09, 11:34:Could it possibly be fixed with re-flashing the CMOS chips?
most likely no
socket_42 wrote on 2026-05-09, 11:34:If so, could one of you with the same board maybe offer me a copy of their BIOS file, if you can read it? I have board rev. 2.3 .
You might be the only one at the moment with this board 🙁 but good news is Im pretty sure your bios is ok. Would be great if you dumped it 😀
socket_42 wrote on 2026-05-09, 11:34:Is there another way to reset the BIOS, like attaching an external battery and closing a CLRCMOS jumper? (there is no obvious one on the board)
nothing to reset without the battery keeping it saved, cmos contents simply evaporate
Do you have an oscilloscope by any chance? slow running and dying on clock source conveniently points at clock problems, specifically 14MHz crystal in the middle of the board. Try smacking it a little (not to hard) or just soldering new crystal, also try new main clock gen (66MHz Can)
