Gotek like Optical Driver Emulator - Is it possible?
Reply 21 of 561, by chinny22
Yeh one of the main selling points of the Gotek is price, even over the Hxc drives.
It's a good start though, it's proof of concept.
IDE drives are still cheap enough to be throw away, but don't think that'll last much longer at which point something like this will go mainstream and costs will drop. (hopefully)
Reply 22 of 561, by root42
At the moment it’s probably one guy making them for a niche market (arcade). The gotek has a big market due to organs and synths using them instead of floppy drives. Plus the retro community, which is probably smaller. I would suspect that price might go down by 50% with more volume, but it‘ll still be niche.
YouTube and Bonus
Reply 23 of 561, by flecom
mothergoose729 wrote:
I feel like 75$ is more my comfort zone.
pretty sure that Z-IDE will cost more than $75 just guessing by the components on the board and development time required to create such a device, it's developer would have to comment further (curious why the last name was scratched off the board)... if it is <$75 and worked in arcade systems I am sure we would buy a dozen!
anyway, the op asked in the title if it was possible, not it if was possible inexpensively
could not have said it better myself... really for retro computing I don't see the point, any cd emulator is going to cost way more than a gotek, both in terms of hardware and hardware/firmware development, and is going to have a significantly smaller market which will also drive the price up... just buy an optical drive for $10 and 100 blanks for another $16
Reply 24 of 561, by Rawit
@flecom Do you have any idea if the device allows hot-swapping? The wiki makes it sound you need to either reboot the device or send commands through the USB host with terminal software. If that's the case it would be a hassle to use in a retro computer.
YouTube
Reply 25 of 561, by flecom
honestly not sure, we've never tried... we only use them in arcade machines so we have no need to change the image... try reaching out to the guy that made it, he's been super helpful
Reply 26 of 561, by matze79
only useful if it can also extract audio data from images and give me analog signal output.
So i can hear CD Audio Tracks of emulated games.
If not, you just can also use shsucdhd and emulate with images on harddrive.
Reply 27 of 561, by doshea
If you're willing to emulate a SCSI CD-ROM drive instead of an IDE/ATAPI one, and can live without audio, you can get another PC running FreeBSD to emulate the CD drive from an .ISO file as discussed in this thread (which I should update with new results!).
Investigating other options for SCSI target "emulation" (it's still a real target, just not the type of device it's pretending to be), I ran across this forum post which seems to be from the developer of some called VirtualSCSI and VirDIS. If I recall correctly, you get a custom SCSI adapter from them which you plug into a Windows PC and you get a GUI to control what the virtual SCSI CD drive or HDD presents to the "initiator". Funnily enough this seems to be something that people with music gear want/need too, just like floppy emulators. I assume it still doesn't do audio though, that'd just not be something you'd have gotten from an external SCSI drive except via a jack on the drive itself.
I suppose there is some chance that FreeBSD could be updated to support .BIN/.CUE or something, and upon receipt of the SCSI commands that tell the drive to start playing audio, route the audio to the FreeBSD machine's sound card, so in place of hooking headphones or speakers up to the headphone jack on an external SCSI CD-ROM drive, you hook them up to the FreeBSD machine.
Reply 28 of 561, by SpectreVR
Zorix wrote:
I'm actually working on one. It will be a while before it's done though. […]
What are you going to name it? Z-IDE? Good work so far, that looks awesome!
Reply 29 of 561, by RichPimp
You're doing the lord's work.
Reply 30 of 561, by gdjacobs
Bless you, my son!
Any rough estimates on the off-the-shelf price?
Reply 31 of 561, by DNSDies
James-F wrote:
https://shop.tattiebogle.net/product/prod_EkTnv3Tk2Trxhf
This is a very much needed device.
But 200$ is crazy talk.
$200 is chump change in the Arcade scene.
Anything that can one of hundreds of $500+ Arcade devices for only $200? that's a damn deal.
Reply 32 of 561, by Jo22
That thing is impressive! 😀 The fact that it supports *.ISO or *.CUE/*.BIN combo only, but no *.NRG is slightly lame, though.
Reply 33 of 561, by electric_monk
I mean, I'm open to suggestions 😉 I haven't heard of that format before though. It doesn't look very well documented (at least, based on the weirdly technical Wikipedia article about it).
Reply 34 of 561, by gdjacobs
No need for the feature creep. Users can convert format with CDemu/ISOBuster first.
Reply 35 of 561, by Zeddicus
Who uses .nrg nowadays anyway. 😀
Reply 36 of 561, by appiah4
Nobody uses NRG these days but a lot of the images from the day are archived by Nero.
Reply 37 of 561, by gdjacobs
And we can convert the format.
Reply 38 of 561, by Jo22
Multi-session and hybrid images, too ? 😉
Reply 39 of 561, by gdjacobs
If CDEmu can load em, yes. Then you rip the virtual device to bin/cue.
