Reply 20 of 28, by red-ray
bloodem wrote on 2020-09-19, 16:05:
for some reason (maybe the missing cache?)
Maybe it depends on the OS, with NT/2K/XP and later assuming you have enough RAM Windows will cache things (at the moment on this system there is 43.28GB in the system file cache!), but I don't know how well W9x caches things.
Reply 21 of 28, by Doornkaat
I usually go with either 80 GB PATA HDDs or with an 120 GB SSD with SATA TO PATA/IDE adapter. I think SD card adapters are OK for tests, however for actual usage I saw a big performance penalty - even though they have very good read/write speeds, for some reason (maybe the missing cache?) there's a very noticeable intermittent stuttering during gameplay (at least with the adapters that I tried).
Have you tried turning off write-behind caching? The feature bundles disk writes into small write bursts that can cause those stutters on cacheless drives.
Reply 22 of 28, by bloodem
Yeah, I actually tried it, but it didn't make a difference.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 23 of 28, by Doornkaat
bloodem wrote on 2020-09-20, 10:04:
I should have assumed you already did. 👍More evidence SD cards just aren't meant to be used as system drives.
Reply 24 of 28, by bloodem
Well, they're quite good for 386 / 486 DOS builds, I'm using an SD card adapter with a Biostar MB8433UUD & an Intel 486 DX2-66. Needless to say that it's probably one or two orders of magnitude faster than any drive from that era 😀
However, for Windows 95 or newer builds I always go with semi-period correct HDDs or far-from-period-correct SSDs 😀
Reply 25 of 28, by PD2JK
First owner 7IXE reporting. I always had a fight with the AMD driver pack and ended up with a non-functional Windows 98SE installation.
I believe it was the GART or IDE driver... not sure anymore.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 26 of 28, by red-ray
PD2JK wrote on 2020-09-21, 05:54:
My 7IXE is now dual boot with 98SE and 2003 Enterprise Server. I find 2003 is faster and far more stable, thus far I have had no issues with 2003, but 98SE is at best temperamental. For example I don't have a floppy installed, it's disabled in the BIOS, but 98SE reports A: and as soon as I access A: the system locks up 🙁. On 98SE I can't get the Matrox G400 to run at 1600 x 1200 @ 60Hz even after installing the drivers 🙁, it works on 2003 even without installing the Matrox drivers 😀.
Given this I suspect I will almost exclusively use 2003
Reply 27 of 28, by jm764
red-ray wrote on 2020-09-19, 08:41:
I have BIOS F7 02/29/2000, a 750MHz AMD Athlon M2 (Pluto) + 640MB of memory.
I also have the "Slot-A" version of this board, but with the F3 02/29/2000 bios, so I was wondering if you could upload your bios version as the official GA site download for F7 seems to be the "Socket A", and force flashing that version bricks the bios, though it can be recovered as I've done using the AMI BIOS Recovery method (CTL+HOME) here: https://techjourney.net/recover-or-undo-corru … s-flash-update/
Reply 28 of 28, by red-ray
jm764 wrote on 2020-10-16, 13:09:
Here you go, as I recall I had for force the update
I suspect you need to look at https://www.gigabyte.com/Motherboard/GA-7IXE-rev-11/support rather than https://www.gigabyte.com/Motherboard/GA-7IXE4-rev-10/support
