Reply 20 of 23, by kolderman
Do a clean build with no extra crap, then start removing bits of hardware until it works.
Reply 22 of 23, by VioletGiraffe
There is no extra crap except for that PCI-e WLAN card. I'll try removing it to see if that's the culprit, but I somehow doubt. I didn't even install AC'97 driver so PC speaker is my only sound device.
Reply 23 of 23, by Cobra42898
Tore wrote:
Cobra42898 wrote:
Command and conquer Red Alert won't install on 2000pro/XP. It checks windows versions before it even begins copying.
Installs just fine on XP if you run the installer in Win95 compatibility mode.
Maybe my disc is an older version? i tried every compatibility mode /OS and got nowhere with it.
Searching for Epson Actiontower 3000 486 PC.
