Reply 20 of 20, by 486lover
486lover
Offline
Gbatchee wrote on 2026-01-24, 18:45:Hello, you can update your GC to max 2x256MB ram, but you MUST use 16-chip/low density modules, other ones will likely be not re […]
Tgnastiker wrote on 2023-12-02, 08:24:Hello! I have an OmniBook XE3-GC with 2x64mb of RAM. I would like to put 2x256mb, is it possible? I tried to install some that I had, but the screen didn't turn on. What RAM do you have? what model? thank you
Hello,
you can update your GC to max 2x256MB ram, but you MUST use 16-chip/low density modules, other ones will likely be not recognized at all.
I have a lot of GC and GF models as well, but nowadays, the MB in most GCs is subject to fail. A working GC in 2026 is truly a rare thing...
Here is a functional and active one.
