Reply 20 of 25, by treeman
its 2 ways of getting the job done, those are quiet big smd capacitors/resistors and lots of access I think it can be done with a soldering iron with a small tip fine, but hot air is a alternative solution
On this picture yours would be number 1 or 2 from the sizes when you are dough number 5 and access is restricted by bga chips or other caps then its just too hard to use a iron tip
