Reply 20 of 22, by dan86
cyclone3d wrote:
Mine is a v1.1 according to the sticker. […]
dan86 wrote:
I was reading that the kt7 and kt7a only supports the XP with latter revisions. You would not happen to know witch all revisions support the XP?
1.3 being the only one that officially supports the XP would make sense why most of the CPUs I have will not POST in it.
I am using a Barton Mobile 2800+ in mine which is a lower power CPU so that may be part of the reason it works just fine.
That being said, take a look at this old archived page. Looks like versions older than 1.3 were more of a YMMV type of thing.
http://web.archive.org/web/20020205141221/htt … /kt7/kt7faq.htm
It could also be that the older versions had suckier voltage regulation and a newer good quality ATX power supply takes care of a lot of that.
Thanks for the info.
Reply 21 of 22, by kaputnik
Got a Chaintech 7AJA2 running an XP Thoroughbred 2600+ (AXDA2600DKV3C) in my Athlon rig. It's a KT133A board with one ISA port.
At least theoretically it should be able handle the 266 MT/s Barton XP-M CPUs. If it does, the 3000+ is the fastest possible CPU. Looked for one to try with for a couple of years now without success though, they seem to be quite rare.
Reply 22 of 22, by Repo Man11
I had a KT7A 1.1 that worked with an XP 1600+. As I recall, it wasn't guaranteed that they would work with the earlier revisions - they might POST with one, they might not. I also set up a KT7E with 2200+ (or something similar, it's been some time ago) similar to the way you can with the KT7A. I still had that board up until Nov. 8 of 2018, when I lost it along with all of the rest. Based on the information in this thread: https://www.overclockers.com/forums/showthrea … 3GHz-now!?pp=30
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
