Reply 20 of 23, by appiah4
- l33t++
wrote:1. Corruption does not happen in BIOS, so far. I think I haven´t tried real DOS Mode, will try and report back. 2. That´s a very […]
wrote:Some questions: […]
Some questions:
1. Are there corruptions in BIOS or in real DOS mode, ie. without loading any Windows drivers?
2. Have you tried booting something like a live linux distro such as Puppy Linux 4.1.2 Retro to see if that works fine?
3. Is this a clean Windows install or was there a different graphics card in there before?1. Corruption does not happen in BIOS, so far. I think I haven´t tried real DOS Mode, will try and report back.
2. That´s a very good idea!
3. The latter, other cards have been tested in the system (Ati Rage 128, for instance). Point 2 test will tell us if it is a driver issue or not.Thank you!
Definitely try #2 and if that works fine then do a clean install of the OS.
