Reply 20 of 32, by Joseph_Joestar
Dochartaigh wrote on 2020-01-25, 21:24:
I think one of the problems is the process after I add the VxD drivers. After those drivers are installed, and it's supposed to add the hardware for the first time (which has an exclamation point) how exactly does it add the hardware there
The first SB16 Emulation device (with the yellow exclamation mark) should be added automatically, after all the required reboots are done.
Then how exactly do I add it a second time?
Start > Settings > Control Panel > Add New Hardware > Next > Next > No, the device isn't in the list > No, I want to select the hardware from a list > Sound, video and game controllers > Creative Technology, Ltd > Creative SB16 Emulation > Next > Finish.
You don't point the install wizard to any new drivers during this process, it just loads what was installed the first time and adds it as a second, working device.
And lastly, can you please tell me if my premise in trying to do all this is correct: for Midi music, I was going into the Multimedia Properties, Midi tab, and selecting ESS FM Synthesizer which gave me sound like I remembered from back in the day when I had crappy computers with built-in sound. THEN I discovered I can choose the Audigy for Midi, by choosing the "SB Audigy 2 ZS Sw Synth" (and there looks to be an A and B version of this too), and it sounds WAY better (see my short video above for a comparison). I believe that's because the Audigy is using Soundfonts, right? (and it was mentioned they're pretty close to the gold standard Roland SC-55?)
Its simple, OPL3 FM synthesis usually sounds inferior to soundfont-based General Midi, unless the music in the game was specifically composed with OPL2 or OPL3 in mind. Here's a site where you can listen to DOS game music as it plays on various sound cards including SB16, Roland SC-55 and even a Dreamblaster.
so if I even like the sound of the default/stock soundfonts, am I going to be able to use this Audigy in pure DOS mode, and STILL get it to use the soundfonts and sound like I can get it to sound through Windows?
The Audigy's default .sf2 soundfont which it loads in Win98 sounds different from the .ecw sound module that it loads while running in pure DOS. It's not the same thing.
Reply 21 of 32, by Dochartaigh
Thank you once again for the directions!
Joseph_Joestar wrote on 2020-01-25, 22:16:
Is it decently close to the Roland though? (I'm so new to this I'm not that picky)
If I buy a Dreamblaster to use on my ESS, paired with the right soundfonts, will that get close to the Roland-esque sound I've been hearing through the Audigy when I'm playing DOS games through Windows 98?
On a related note, when I've rebooted into DOS I can't get my ESS ES1869F to play any Midi sounds. My go-to test is always the setup utility for Duke Nukem 3d. In Windows I believe it was set for Sound Canvas on port 330 and I got Midi sound from the Audigy (or I could do General Midi and get it from the ESS). In DOS proper the only ones which give me music is the non-Midi ones (like Sound Blaster or Adlib).
Autoexec.com is setup correctly (I tried it with and without "P330" on the end of setblaster as well):
C:\DRIVERS\ESS\ESSCFG.EXE /A:220 /I:5 /D:1 /B:330 /J:E
SET BLASTER=A220 I5 D1 T4
I've re-run the ESSCFG and the 330 port is setup correctly (I tried 300 as well). There are NO Audigy DOS drivers installed FYI.
And similar to the above, before I could get Quake to work in DOS proper, WITH the audio/music playing from the CD. Now....nothing (just sound fx). Official disc and all. I was having an error about mscdex on launch, but that went away after a fix. I can go to D: in dos and browse around - the CD definitely works.
Reply 22 of 32, by jmarsh
Dochartaigh wrote on 2020-01-26, 00:22:
You need a cable connecting the analog audio port on the CD drive to the ESS sound card. Windows would be using digital extraction to play the audio tracks so it doesn't need the analog audio connected.
Reply 23 of 32, by gdjacobs
If so, that would be awesome. If not, I think I need to do research on that Dreamblaster (which there seems to be like 8 different versions of 🤣) everybody keeps talking about (which I think can also use soundfonts, and I think can plug in directly to my ESS EF1869F card too!).
The Dreamblaster S* series are designed to support GM instruments with a single sound bank. They're more compact and economical. The Dreamblaster X* series supports more complex loadable sound banks and more polyphony. I suspect it could support GS or GM2 sound banks in the later versions, although I'm not sure if that's implemented.
Reply 24 of 32, by Joseph_Joestar
I don't own a Dreamblaster, but from what little I've heard of it, it sounds pretty nice to my ears. Not exactly like a SC-55 but still very pleasant. Go here to listen for yourself:
https://www.wavetable.nl/doom/
Like I said before, that website has recordings of DOS game music played through a bunch of sound cards. It's a really nice resource to compare things.
Reply 25 of 32, by Dochartaigh
Here's my notes for the ~15th? time 🤣 I'm installing the DOS drivers for the Audigy 2 ZS. It finally worked! - you don't have to read the massive wall of text below, but just in case my notes help somebody else:
Super long notes to install Audigy 2 ZS DOS Drivers in Windows 98 SE
--Formatted new 120gb SSD drive--Pulled the ESS ES1869F ISA sound card to eliminate any conflicts--Reinstalled windows--Installed minimum drivers (so I could function) for: Unofficial nusb36e USB Driver, GeForce 4 Video Drivers, 7Zip, Daemon for ISO mounting
--Followed Joseph's directions:
Joseph_Joestar wrote on 2020-01-25, 07:10:
1) Install Audigy WDM drivers normally from the CD 2) Run the Driver Utility Program and let it install VxD drivers 3) Make the […]
3) Make the EnableSB16Emulation=1 registry change as mentioned here
4) Install the DOS compatibility pack once
5) Go to Control Panel > Add New Hardware and manually add a second SB16 Emulation device as instructed in the linked thread
Installed Audigy 2 ZS WDM Drivers:
--ONLY choose those 4x programs you said (and I added Midi samples as well)
--During install asked me for Win98 CD
--Install told me 'ksproxy.ax: WDM Streaming ActiveMovieProxy was newer that the file I already have', do I want to keep the existing file? I choose YES.
--Then pop-up for new hardware found (during install of WDM drivers) - 'Windows is installing the software for your new hardware'...
--asked me again about a bunch of newer files which I choose keep newer....FYI, I've installed these WDM drivers a HALF DOZEN times before and it NEVER asked me this prior...using same exact Audigy CD...same exact Win98SE CD...
'Installation Complete, Yes I want to restart my computer now'
--black screen before Windows boots up with 'please wait while setup updated your files'
--ReadReg Application, completing install of your audio card (window under it with "Windows 98 setup, then building driver info database, win 98 setup then boot to Windows
--cancelled Audigy registration screen pop-up
Audigy 2 Driver Utility Program > install VxD Driver--update of Creative audio hardware drivers is in progress), reboot
--I don't know if I was supposed to make the registry edit before it rebooted or what...but I rebooted without doing that
--black screen with 'please wait white setup updates', then in Windows 'building driver info database, new hardware found, add new hardware wizard, PCI Input Controller'....this is also where I could have screwed up, do I choose automatic search for a better driver? Specify the location of the driver????
--I choose 'Automatic' for this first time, since you laid out the more detailed instructions of the manual process for the 2nd time...so I assume the first time I should do automatic.
--Another problem here is which CD should be in the drive? When you choose 'automatic' it automatically scans the CD for drivers...choices are Win98se CD, the Audigy CD, or no CD...since the Audigy CD couldn't find anything because that .CAB wasn't unzipped (like I talked about before), I just kept the Win CD in there.
--and it seems to be stuck on scanning D:\ADD-ONS\TSCLIENT\MSTSC\WIN16...at about minute 5 or 6 now...10 minutes later after ctrl+alt+del doesn't work I hard reset...
--Boots right back up to the add new hardware for PCI Input Controller, choose auto again, but this time had Audigy CD in drive...where it then asks me for the Win98 CD again 🤣...add new hardware Creative Game Port, windows has finished installing new hardware device
--Rebooted into pre-teal-screen = windows and creative driver update utility pops-up, updating of creative audio hardware drivers in progress, driver info database, new hardware found, flashing through 3x of them too fast to read/remember...back to Creative Driver Update Utility which tok about 6 minutes (thought it froze). Msg: 'In order for changes to take effect you should reboot' (assuming NO registry edit quite yet?), black screen please wait while setup updates...back to ReadReg Application, completing install of your audio card (is this a boot loop? 🤣), OK, NOW Windows is back up finally...
(and reminder, ALL of the above is just to get the VxD drivers installed...)
Edited the Registry....maybe/kinda...
--last time I double-clicked on the "EnableSB16Emulation" and manually changed 0 'dword' value to 1. This time I made a text .reg file in Notepad (and checked it in DOS 'edit' just to make sure no extra characters were added - it was good). Double clicked on it...and nothing was added to the registry... One thing to note, that post you linked to says "CreativeTech" with no space. Mine has a space "Creative Tech".  Just in case I tried it without no space too, and rebooted....STILL doesn't add any registry value(s), and the directions from that linked post says "add the entry to the registry. Once this is done and you reboot, the system will try to install SB16 emulation from the SB16.inf." ...I'm NOT getting the system to add anything automatically.... (and this is before the directions say to manually  go to Add new Hardware)....so I go back to double clicking on the registry value and changed it to "1" (actually "00000001")
-- When I reboot, I FINALLY get the teal screen, something flashed up quickly then it says "System Settings Change, to finish setting up your new hardware you must restart", restarted.
--NOW, I FINALLY have the one single "Creative SB16 Emulation" with a yellow exclamation point in my System Properties!
Installed the Dos compatibility pack (#4 on your list) from the audigy2-dospack\driver\setup, prompted to reboot, so I did
--black screen saying updating
--teal screen w/ quick flash-up of another driver loading? prompt, then back into windows
--did the above then prompted to restart
Looks like there's an error in Autoexec or config - will have to take a pic on next reboot--went away next reboot
IT WORKS!!!!!!    (THANK YOU Joseph!)
Both in Windows, AND in DOS (as long as you run the Audigy patch ever time).
I'm going to research how to load those larger/better SoundFonts for the Audigy 2 ZS, but now that I think about it that might have become a moot point...
I did some testing and only about 6 out of ~30 or so DOS games had proper Sound FX and Midi sound when played through windows (Doom 1 & 2, Duke3d, Hexen/Heretic and Quake all worked in Windows). The others (when played inside Windows) usually have Sound FX but NO Midi sound, so to get those working correctly I have to 'reboot to DOS' mode, and in DOS mode I loose the ability to use those more advanced SoundFonts on the Audigy 2 ZS (i.e. to get closer to sounding like a Roland SC-55) -- since those SoundFonts ONLY work in Windows... so that's making me rethink everything...
OR, do you think I'm doing something wrong here? Is it normal for the VAST majority of DOS games NOT play nice inside Windows 98 SE? ...and this is probably why everybody is using actual Roland SC-55's, Dreamblasters, or other devices/solutions to get that type of superior sound to work in DOS proper?
Besides the above, I'll continue to test out the Audigy 2 ZS some more. I can now use proper SoundBlaster 16-bit sound, right? (where on the ESS it was only 8-bit unless the game happened to have an actual ESS mode - which I haven't found one which does yet)
What Midi/Music modes do I want to test the most? My go-to was 'Generic Midi' before (but ONLY in Windows, where I could use the Audigy/WDM Windows drivers to get Midi sound), but if I take Duke Nukem 3d for example it has options for: Ultrasound, SB, Sound Man 16, Pro Audio Spectrum, AWE 32, SoundScape, Wave Blaster, General Midi, Sound Canvas, Adlib. In Windows through Multimetia Properties > Midi tab, I can choose SB Audigy Midi port, Sw Synth, Synth A, Synth B - which to use? (or will this change once I load those larger SoundFonts?)
Oh, one random thing, some games, when choosing Sound FX, weren't giving me IRQ/DMA options which the Audigy had available. I have A220 I5 DMA1/5 (I'll have to take better notes next time I see this). Do I choose this for BOTH 8-bit and 16-bit option? (and in Duke Nukem 3D I don't think "5" was an option for 16-bit - they were higher so I couldn't coose one.....so I don't know how I can use 16-bit on the Audigy on games like this - again, I'll try this when I'm back home and take better notes).
Reply 26 of 32, by Joseph_Joestar
Dochartaigh wrote on 2020-01-27, 16:06:
Cheers, glad you managed to get everything working. Creative's Audigy drivers are a nightmare to set up, but the end result is well worth it. Enjoy your soundfont-enabled and SB16 compatible Audigy 2 ZS on Win98!
For me personally, Patch93's SC-55 soundfont sounds the closest to the real thing. But unfortunately, it is in the .sfpack format initially which the Audigy can't load. You need to convert it to the .sf2 format using SF Pack. To do that, run SF Pack > Add Files > Files of type: SFPack FIles > SC-55.sfpack > Open. After that, click File > Go. It should then work for a few seconds and tell you something like "inflated by 200%". If everything worked ok, you should now have a Sc-55.sf2 file in that folder which the Audigy can load just fine.
To load this soundfont and use it in games you need to do the following:
1) Start > Programs > Creative > Sound Blaster Audigy2 ZS > SoundFont Bank Manager
2) Click on "Midi Devices" and use the slider to set Sound Font Cache to a bit more than 50 MB then click Ok
3) Click on "Bank" then click on the default soundfont (should be something like CT4MGM.SF2) then click Replace and then point to SC-55.sf2
4) Finally, click Ok and your SC-55 sound fount should be loaded
5) Fire up any game that supports General Midi under the Win98 DOS prompt and enjoy!
6) If you ever want to go back to the original Audigy soundfont, you can find it in C:\Windows\System\CT4MGM.SF2
Hmm, you should get at least some form of music in every game. If you select "Sound Blaster 16" for music instead of "General Midi" you can even get the Audigy to play its CQM FM synth, which is Creative's clone of OPL3. That doesn't sound quite as nice as the real thing, but can be used in a pinch.
It varies from game to game, but there are a few games which absolutely need to run in pure DOS and won't even start under Win98. Still, for me the situation is that most games tend to work fine under Win98. Which games are you having trouble with?
Yes, but remember that the Audigy's SB16 emulation isn't perfect, so some games (especially older ones) might not work with it. This is exactly why I keep my Opti ISA card for pure DOS gaming. As for the ESS native mode, I know that WarCraft 2 supports it in setup and I've also seen it in some other games, but I don't remember which off hand.
I always use Synth A since that was assigned by default. I never changed it and it always worked fine with any soundfont that I loaded.
This is a bit tricky. If a game offers you to choose both Low DMA and High DMA then assign them as Low DMA = 1 and High DMA = 5. Otherwise, if it just has a single choice, your best bet is to go with DMA = 1.
Reply 27 of 32, by Dochartaigh
Thanks, I'll look into the other things you wrote when I get home.
Joseph_Joestar wrote on 2020-01-27, 17:05:
Yes, SoundBlaster (always?) works, but the entire point of this is to get that beautiful midi running! Here's a quick list - I don't guarantee all of these games even have the option for midi in their setups (some don't even have setup programs), but these some of the ones I was trying last night I couldn't get sound to work in Windows which had to use 'reboot in DOS' which worked fine.
Another World
Blake Stone: Aliens of Gold
Commander Keen 4
Commander Keen 5
Commander Keen 6
Dark Forces
EOB (Eye of Beholder) 1
EOB2
EOB3
Flashback
Lost Vikings
Monkey Island 2
Reply 28 of 32, by Joseph_Joestar
Dochartaigh wrote on 2020-01-27, 18:31:
Remember, if the game is so old that it doesn't support General Midi or at least a Roland MT-32, then you won't be getting any soundfont-based wave table synthesis out of it. Some older DOS games simply topped out at Adlib aka OPL2 and you can't force them to use General Midi instead.
Dark Forces
Run IMUSE.EXE choose C for Custom Setup then select Advanced Menu. There, choose General Midi at port 330 for music and SB16 at port 220 IRQ 5 and DMA 1 for digital sound. This works fine for me under Win98.
Monkey Island 2
You need to run it with the Roland switch in order to get General Midi to kick in. So, open an DOS prompt and start the game with:
monkey2.exe v mo r
That said, the music in Monkey Island 1 & 2 was made with a Roland MT-32 in mind, not the SC-55. Same goes for some older Sierra games. If you want to learn more, here's an article which explains DOS game music in a bit more detail.
Reply 29 of 32, by Dochartaigh
Joseph_Joestar wrote on 2020-01-27, 19:17:
You need to run it with the Roland switch in order to get General Midi to kick in. So, open an DOS prompt and start the game wit […]
monkey2.exe v mo r
Thanks, but I tried that before - missing some sounds when run inside of Windows. Like the very first copy protection screen, when the monkeys come on - music starts normal after that but I don't know what else it'll be missing as I play the game.
I'll test some more when I get a chance - probably this weekend.
Has anybody ever gotten this error - only found two instances of it on the entire internet, and they're from this site. One seems to be specifically because of the Audigy per this post, and the other is about a SoundBlaster here. Upon shutting down Windows 98 SE, a black screen shows up and says "error: Could not configure PCI Port. Press any key to continue...".
It showed up for the first time last night - and just to remind this is a clean install of Windows I just did on Sunday. Loaded the WDM then VxD drivers, 7Zip and Daemon, and really nothing else whatsoever...
Reply 30 of 32, by Joseph_Joestar
Dochartaigh wrote on 2020-01-28, 15:08:
There might be some minor mapping differences between the .ecw sets that the Audigy uses under pure DOS and the way it maps the .sf2 soundfonts under Win98.
Even so, game music that was made for a Roland MT-32 often doesn't sound right when played back on a General Midi device. You're usually better off selecting Adlib or Sound Blaster for old games like that.
Reply 31 of 32, by Dochartaigh
Joseph_Joestar wrote on 2020-01-24, 08:04:
With the DOS driver pack installed, you'll get full SB16 support in the Windows 98 DOS prompt as well as in pure DOS that you enter via "Restart in MS-DOS mode". And yes, you will need to initialize the card using "audigy12.exe" every time you boot into pure DOS (but not under Win98).
Think I just found a limitation of these Audigy DOS drivers - you can't get them to load without a memory manager like EMM386 (i.e. Expanded memory), so when I play games like Turrican II which will ONLY run with Extended memory, there's no way to get sound then, correct?
Reply 32 of 32, by Joseph_Joestar
Yes, you need a memory manager to load the Audigy DOS drivers.
This is one of the reasons why I keep my Opti ISA card for pure DOS gaming and only use the Audigy under Win98.
