Reply 20 of 22, by CoffeeOne
eeJay wrote on 2020-03-08, 13:05:Well, the 7-segment display showing the wrong value could be easily remedied by changing System Boot Up CPU Speed to Low. And th […]
Well, the 7-segment display showing the wrong value could be easily remedied by changing System Boot Up CPU Speed to Low. And then pressing the turbo button would bring it to 40, so an inverse turbo of some kind.
As for the hard drives, I have the following information:
One is a Maxtor, no set-up data on the label (probably the boot drive). The other one is a WD; set-up data is on the label (shouldn't be a problem to set up, but probably isn't the boot drive).Any ideas on what values to use in CMOS for that Maxtor drive?
Thanks and br
https://stason.org/TULARC/pc/hard-drives-hdd/ … -SL-IDE-AT.html
J13/J14  PCBA   38  Power-up Configuration
        J14     J13      Cyl   Hds   Sec   MB
 7120A  CLOSED  CLOSED   936   16    17    130.3 (default)
It took me approx. 10 seconds to find that via google.
