SVGA minimum RAM?
Reply 20 of 25, by ntalaec
I really don't know.
I though 800x600 was only possible with 16 colors (256 KB) but I also though that 640x480 256 (512 KB) was possible, so I am wrong in one of them (or both).
I have configured PCem with the card and installed Windows 3.1 with the drivers provided by tayyare: Re: Wanted Diskette Drivers for OTIVGA OTI067 card
They support weird resolutions (768x1024) but they don't support 640X400.
Reply 21 of 25, by Grzyb
ntalaec wrote on 2020-03-09, 21:30:
You may also be perfectly right.
I've seen at least one 512 KB card that can't do 800x600x256.
I'm not sure why - perhaps not enough video memory bandwidth?
Nie rzucim ziemi, skąd nasz root!
Reply 22 of 25, by rkurbatov
Did somebody manage to run PVGA1A-JK 640x480x256 with UniVBE?
I have a strange problem. My videoadapter is detected by UniVBE as 512K even though it has only 256K of RAM. Also, I don't have an option to use 640x480x256 mode, only low-resolution ones (the biggest is 320x480 if memory serves). And these modes are not available on my LCD display (frequency problems?)
Installation of additional RAM changes nothing (only lowest part of the scrollable image appears, for sure).
So the questions are:
- why UniVBE cannot detect proper amount of memory? Does it work at all with 256K cards?
- how can I enable 640x480x256 under DOS with this card?
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
Reply 23 of 25, by rkurbatov
Oh, that's really strange. When I run uvconfig with -m256 param forcing detection of 256KB of memory it said it wouldn't work at all as the card is not supported. While running it again without any params it said that there are 10 modes now supported instead of 6 and 640x400(480) appeared. Interesting.
Reply 24 of 25, by Jo22
Forget UniVBE, I think it's Vaporware, it won't work properly with many sophisticated applications.
At least not in combination with early ISA VGAs. Had little else than trouble with it.
UNIVBE 4.0 and old hardware
Instead, please try the old VBE utilities. They're very limited, but they do provide what they claim to support, at least.
And programs won't crash or do funny things when they're running.
Re: OAK OTI-037c - 800x600 mode ?
Reply 25 of 25, by rkurbatov
Jo22 wrote on 2022-09-11, 12:32:
It helped me a lot when I had PCI videocard (DSV6422), that was "upgraded" from VBE 1.2 to VBE 3.0. I liked additional modes and VBE/AF extensions. As for ISA cards, I suppose, they could not help much so did not even bother.
Thanks, I'll try searching for some native DOS drivers. I don't need much on my 386 build, probably 640x480 is more than enough.
