DOSBox debugger
Reply 20 of 176, by jefferl
You must create a short cut from desktop,
Then run this short-cut , else you will shutdown dosbox-debugger immediately.
You may run the dosbox.exe from MSYS terminal environment,
this will fail to run it.
Strange things: normal version dosbox can run under MSYS terminal.
Reply 21 of 176, by ripsaw8080
Rank DOSBox Author
DOSBox Author
My experience is that MSys must be able to find the curses files during the configuration with the debug parameter, you should see configure messages like:
checking curses.h usability... yes
checking curses.h presence... yes
checking for curses.h... yes
the necessary files are:
\include\curses.h
\include\panel.h
\lib\libpdcurses.a
\lib\libpanel.a
You can use the lib and include folders under \MinGW or \msys\1.0\local
I always do this with a first-time configure of the source to ensure all the make files are correctly generated for an enabled debugger.
Reply 22 of 176, by ih8registrations
The scenario where it silently fails, dosbox has compiled configured with the debugger. It fails when trying to launch dosbox.exe. You don't need a desktop link, but jefferl figured it out, it crashes from trying to run from msys.
Reply 23 of 176, by jefferl
When I using dosdebugger to single steps,
The User video screen lagged to update,
Even I have steps many instruction , The screen still not updated.
In DOS environment , It's the best feature compare to windows.
Have any direction to fixed this issue ?
Reply 24 of 176, by wd
Rank DOSBox Author
DOSBox Author
use a real debugger
Reply 25 of 176, by !(rugged|handsome)
With the help of this howto, I've successfully compiled Dosbox 0.72 under OpenSuse 11.1.
But when I run
./configure --enable-debug=heavy
it shows the following warning (even though the packages libncurses5, libncurses6 and ncurses-devel are installed):
checking for initscr in -lcurses... no
checking for initscr in -lpdcurses... no
configure: WARNING: Can't find curses, debug mode disabled
Apparently, the configure script looks for "curses" when it should be looking for "ncurses".
How can I change this?
Reply 26 of 176, by Qbix
Rank DOSBox Author
DOSBox Author
try using the cvs version of dosbox (dosbox.linuxsecured.net/dosboxcvs.tgz)
it should check for ncurses as well.
Water flows down the stream
Reply 27 of 176, by bttr
Where is DOSBox0.73-Debug-win32-installer.exe? 😀
Reply 28 of 176, by wd
Rank DOSBox Author
DOSBox Author
You can even compile it yourself 😀
Reply 29 of 176, by bttr
Not everybody knows how to compile such a large project successfully. 🙁
Reply 30 of 176, by wd
Rank DOSBox Author
DOSBox Author
I'm sure Qbix will set up such a build if he's bored (might take some time),
is there a special thing why you need a 0.73 debugger enabled build?
Reply 31 of 176, by MiniMax
Rank Moderator
Moderator
As with so much else in life. I don't know how to repair a car or build a house, so I pay other people to do it.
_________________
Reply 32 of 176, by Kippesoep
I'll gladly take your money 😀
Reply 33 of 176, by Qbix
Rank DOSBox Author
DOSBox Author
hehe. I'll compile one day. 😀 creating that installer is most of the work though 😀
Reply 34 of 176, by robertmo
I think a .zip would be enough for everyone 😉
Reply 36 of 176, by MiniMax
Rank Moderator
Moderator
Thanks Qbix.
_________________
Reply 37 of 176, by bttr
Thank you!
Reply 38 of 176, by k9wazere
I'm having problems with the Debugger 😒
There are two problems, which seem very much related.
Firstly, a lot of breakpoints are being "missed". As in, the code executes but DosBox does not catch this happening, and the BP fails to trigger. BPINT always seems to work, it's BP CS:EIP type breakpoints that fail.
Second, the output of LOG/LOGS/LOGL is missing a lot of commands. Ie it will show the command executed at, say 015A, then the next command will be at 0194, missing everything in between. There was no jump, this is a linear sequence of ops, just with many of them missing.
It almost seems like a threading issue... like DOSBox is monitoring one DOSBox thread, but failing to pick up instructions being executed in a different thread. Anyway, that's just a guess, and probably completely wrong...
Either way, I'd like to be able to catch all BPs and see all commands in the LOGCPU.TXT file, if possible.
Cheers!
Reply 39 of 176, by Qbix
Rank DOSBox Author
DOSBox Author
use core=normal when debugging
