Via 686B and YMF744 Dos Mixer Settings
Reply 20 of 25, by johnnycontrario
Prez wrote on 2020-04-22, 19:21:
b[14:13] ......SBVER: SB Version Select These bits set the version of the SB Pro DSP. The value set in these bits is returned by […]
These bits set the version of the SB Pro DSP. The value set in these bits is returned by sending the E1h
DSP command.
“0”: ver 3.01 (default)
“1”: ver 2.01
“2”: ver 1.0
maybe ?
Philippe, this is interesting, but this seems to be a setting internal to the YMF chip. The YMF7xx utility shows my card is set to 3.01. I'm not sure this refers to Sound Blaster compatibility, but I'm willing to try it. I don't know where to begin, though. In your post about enabling SB Pro on VT8231, your batch file was using PCISET. Would I use this tool to set those bits?
Reply 21 of 25, by cyclone3d
Ok, I'm going to have to do some testing. Been a while since I actually messed with one of these cards.
FM will work regardless of anything else as it uses neither IRQ or DMA.
What is the exact system / motherboard you are using this in? Also, have you checked for BIOS updates for the motherboard?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 22 of 25, by johnnycontrario
cyclone3d wrote on 2020-04-24, 16:22:
Sadly, there are no updates that I could find. The board is marked DTV-2370. It's a SFF computer made by a point-of-sale equipment company called Datavan. Their current website has no info on their older products. I managed to find the downloads page for their 2006 site on Internet Archive, but the downloads page requires a login.
The machine's BIOS is AwardBIOS v6.00PG, 03/22/2002-8604-686B-6A6LLDAAC-00. I've attached the output of PCI.EXE and HWiNFO if it helps. This was taken after I did all my testing, so all IRQs & DMAs are set to PNP and all devices are enabled. The dual card configuration described in my original post works with this configuration.
PCI.EXE Output
Craig Hart's PCI+AGP bus sniffer, version 0.48vk, freeware made in 1996-2003.
PCI BIOS Version 2.10 found!
Number of PCI Busses : 2
PCI Characteristics : Config Mechanism 1 Special Cycle Mechanism 1
Searching for PCI Devices using the System BIOS
Bus 0 (PCI), Device Number 0, Device Function 0
Vendor 1106h VIA Technologies Inc
Device 0605h VT8605 ProSavage PM133 System Controller
Command 0006h (Memory Access, BusMaster)
Status 2210h (Has Capabilities List, Received Master Abort, Medium Timing)
Revision 01h, Header Type 00h, Bus Latency 00h
Self test 00h (Self test not supported)
PCI Class Bridge, type PCI to HOST
Subsystem ID 06051106h Unknown (Generic ID)
Subsystem Vendor 1106h VIA Technologies Inc
Address 0 is a Memory Address (anywhere in 0-4Gb, Prefetchable) : E8000000h
New Capabilities List Present:
AGP Capability, Version 2.0 (AGP 4x and below support)
AGP Speed(s) Supported : 1x 2x 4x
FW Transfers Supported : No
>4Gb Address Space Supported : No
Sideband Addressing Supported : Yes
Maximum Command Queue Length : 32 bytes
AGP Speed Selected : None Selected
FW Transfers Enabled : No
>4Gb Address Space Enabled : No
AGP Enabled : No
Sideband Addressing Enabled : No
Current Command Queue Length : 1 byte
Power Management Capability
Supports power state D1
Current Power State : D0 (Device operational, no power saving)
Bus 0 (PCI), Device Number 1, Device Function 0
Device 8605h VT8605 ProSavage PM133 CPU to AGP Bridge
Command 0007h (I/O Access, Memory Access, BusMaster)
Status A230h (Has Capabilities List, Supports 66MHz, Received Master Abort, Detected Parity Error, Medium Timing)
Revision 00h, Header Type 01h, Bus Latency 00h
PCI Class Bridge, type PCI to PCI
PCI Bridge Information:
Primary Bus Number 0, Secondary Bus Number 1, Subordinate bus number 1
Secondary Bus Command 000Ch (ISA mapping, VGA mapping)
Secondary Bus Status 0000h
Secondary Bus Latency 00h
I/O Port Range Passed to Secondary Bus : None
Memory Range Passed to Secondary Bus : EC000000h to EDFFFFFFh
Prefectchable Memory Range Passed to Secondary Bus : E0000000h to E7FFFFFFh
Bus 0 (PCI), Device Number 7, Device Function 0
Device 0686h VT82C686B PCI to ISA Bridge
Command 0087h (I/O Access, Memory Access, BusMaster, Wait Cycles)
Status 0210h (Has Capabilities List, Medium Timing)
Revision 40h, Header Type 80h, Bus Latency 00h
PCI Class Bridge, type PCI to ISA
Subsystem ID 00001106h VT82C686/A PCI to ISA Bridge
Bus 0 (PCI), Device Number 7, Device Function 1
Device 0571h VT82xxxx EIDE Controller (All VIA Chipsets)
Status 0290h (Has Capabilities List, Supports Back-To-Back Trans., Medium Timing)
Revision 06h, Header Type 00h, Bus Latency 20h
PCI Class Storage, type IDE
PCI EIDE Controller Features :
BusMaster EIDE is supported
Primary Channel is at I/O Port 01F0h and IRQ 14
Secondary Channel is at I/O Port 0170h and IRQ 15
Subsystem ID 05711106h VT82Cxxxx EIDE Controller (All VIA Chipsets) (Generic ID)
Address 4 is an I/O Port : 0000C000h
Bus 0 (PCI), Device Number 7, Device Function 2
Device 3038h VT82C686B USB Controller
Revision 1Ah, Header Type 00h, Bus Latency 20h
Cache line size 32 Bytes (8 DWords)
PCI Class Serial, type USB (UHCI)
Subsystem ID 12340925h VIA USB Controller
Subsystem Vendor 0925h Known Bad Subsystem ID - no Vendor ID Available
Address 4 is an I/O Port : 0000C400h
System IRQ 10, INT# D
Bus 0 (PCI), Device Number 7, Device Function 3
Address 4 is an I/O Port : 0000C800h
Bus 0 (PCI), Device Number 7, Device Function 4
Device 3057h VT82C686B ACPI Power Management Controller
Command 0000h (Bus Access Disabled!!)
Revision 40h, Header Type 00h, Bus Latency 00h
PCI Class Bridge, type PCI to Other
Subsystem ID 30571106h VT82C686/A/B ACPI Power Management Controller (Generic ID)
Bus 0 (PCI), Device Number 7, Device Function 5
Device 3058h VT82C686B AC'97 Audio Codec
Command 0001h (I/O Access)
Revision 50h, Header Type 00h, Bus Latency 00h
PCI Class Multimedia, type Audio
Subsystem ID 30581106h Onboard AC'97 Audio Codec (Generic ID)
Address 0 is an I/O Port : 0000CC00h
Address 1 is an I/O Port : 0000D000h
Address 2 is an I/O Port : 0000D400h
System IRQ 9, INT# C
Bus 0 (PCI), Device Number 8, Device Function 0
Vendor 10ECh Realtek Semiconductor
Device 8139h RT8139 (A/B/C/8130) Fast Ethernet Adapter
Revision 10h, Header Type 00h, Bus Latency 20h
PCI Class Network, type Ethernet
Subsystem ID 813910ECh RT8139 (A/B/C/8130) Fast Ethernet Adapter (Generic ID)
Subsystem Vendor 10ECh Realtek Semiconductor
Address 0 is an I/O Port : 0000D800h
Address 1 is a Memory Address (anywhere in 0-4Gb) : EE008000h
System IRQ 11, INT# A
Current Power State : D1 (Device idle, minimum power saving)
Bus 0 (PCI), Device Number 11, Device Function 0
Vendor 1073h YAMAHA Corp
Device 0010h YMF744B DS-1S Audio
Revision 02h, Header Type 00h, Bus Latency 20h
Subsystem ID 00101073h DS-XG PCI Audio CODEC (Generic ID)
Subsystem Vendor 1073h YAMAHA Corp
Address 0 is a Memory Address (anywhere in 0-4Gb) : EE000000h
Address 1 is an I/O Port : 0000DC00h
Address 2 is an I/O Port : 0000E000h
System IRQ 10, INT# A
Bus 1 (AGP), Device Number 0, Device Function 0
Vendor 5333h S3 Inc
Device 8A25h Savage4 ProSavage PM133
Status 0230h (Has Capabilities List, Supports 66MHz, Medium Timing)
Revision 02h, Header Type 00h, Bus Latency F8h
PCI Class Display, type VGA
Address 0 is a Memory Address (anywhere in 0-4Gb) : ED000000h
Address 1 is a Memory Address (anywhere in 0-4Gb, Prefetchable) : E0000000h
Expansion ROM of 64Kb decoded by this card
Sideband Addressing Supported : No
AGP Speed Selected : 4x
AGP Enabled : No
PCI slot IRQ mapping information
PCI slot mapping information read successfully
PCI slot IRQ availability listing
PCI Bus 0, Device 8, Slot 01
INTA# can be connected to IRQs 3,4,5,7,9,10,11,12,14,15
INTB# can be connected to IRQs 3,4,5,7,9,10,11,12,14,15
INTC# can be connected to IRQs 3,4,5,7,9,10,11,12,14,15
INTD# can be connected to IRQs 3,4,5,7,9,10,11,12,14,15
PCI Bus 0, Device 10, Slot 02
PCI Bus 0, Device 11, Slot 03
PCI Bus 0, Device 1, Slot 00
PCI Bus 0, Device 7, Slot 00
PCI slot INTx to IRQ-router mappings
SLOT BUS DEV INTA INTB INTC INTD
01 0 8 01 02 03 05 RT8139 (A/B/C/8130) Fast Ethernet Adapter
02 0 10 03 05 01 02 No Device Detected
03 0 11 05 01 02 03 YMF744B DS-1S Audio
00 0 1 01 02 03 05 VT8605 ProSavage PM133 CPU to AGP Bridge
00 0 7 00 00 03 05 VT82C686B PCI to ISA Bridge
IRQ's dedicated to PCI : 9,10,11
ROM PCI IRQ routing table Windows 9x Compatibility Tests....
ROM IRQ routing table found at F000h:DF20h
Table Version 1.0 - OK
Table size 112 bytes - OK
Table Checksum 6Eh - OK
The ROM PCI IRQ routing table appears to be OK.
IRQ Summary: IRQs 9,10,11,14,15 are used by PCI devices
Shared IRQs: IRQ 10 is shared by 3 PCI Devices
HWiNFO Output
HWiNFO v6.0.4
█████████████████████████████System Information█████████████████████████████
║ Main Processor: VIA C3, 798.0 MHz ║
║ Bus Type: PCI (V2.10) + AGP 0X (V2.0) + ISA ║
║ Mainboard Model: Unknown ║
║ Mainboard Chipset: VIA VT8604/5/6 ProSavage PL133/PM133/PN133 ║
║ First Level Cache: Instruction: 64 KBytes, Data: 64 KBytes ║
║ Second Level Cache: Integrated: 64 KBytes ║
║ System Memory Size: 640 KBytes ┐ ║
║ Extended Memory Size: 121,856 KBytes ├ Total: 120 MBytes ║
║ Shadow+Special RAM Size: 384 KBytes ┘ ║
║ Machine Type: IBM PC AT ║
║ Computer Name: Unknown ║
║ BIOS Manufacturer: Phoenix - AwardBIOS v6.00PG [03/22/02] ║
HWiNFO v6.0.4
████████████████████████████More CPU Information████████████████████████████
║ CPU ID: 0000067A (CPUID) ∙ 0000067A (Ext. CPUID) ║
║ CPU Stepping: Ezra (C5C) ║
║ CPU Vendor Name: VIA Ezra ║
║ CPU Current: 798.0 MHz = 6.00 x 133.0 MHz ║
║ Number of CPU Cores: 1 ║
║ Number of Logical CPUs: 1 ║
║ Instruction TLB: 8-way set associative, 128 entries ║
║ Data TLB: 8-way set associative, 128 entries ║
║ CPU Update Revision: N/A ║
║ Multi-Processor System: Not Present ║
║ P.I. ROM: Not Present ║
HWiNFO v6.0.4
████████████████████████████████CPU Features████████████████████████████████
║ √ FPU on Chip ║
║ x Enhanced Virtual-86 Mode ║
║ √ I/O Breakpoints ║
║ x Page Size Extensions ║
║ √ Time Stamp Counter ║
║ √ Pentium-style Model Specific Registers ║
║ x Physical Address Extension ║
║ x Machine Check Exception ║
║ x CMPXCHG8B Instruction ║
║ x APIC On Chip / PGE (AMD) ║
║ x Fast System Call ║
║ √ Memory Type Range Registers ║
║ √ Page Global Feature ║
║ x Machine Check Architecture ║
║ x CMOV Instruction ║
║ x Page Attribute Table ║
║ x 36-bit Page Size Extensions ║
║ x Processor Number ║
║ x CLFLUSH Instruction ║
║ x Debug Trace and EMON Store ║
║ x Internal ACPI Support ║
║ √ MMX~ Technology ║
║ x Fast FP Save/Restore (IA MMX-2) ║
║ x Streaming SIMD Extensions ║
║ x Streaming SIMD Extensions 2 ║
║ x Self-Snoop ║
║ x Multi-Threading Capable ║
║ x Automatic Clock Control ║
║ x IA-64 Processor ║
║ x Signal Break on FERR ║
║ x Streaming SIMD Extensions 3 ║
║ x Carryless Multiplication (PCLMULQDQ) ║
║ x MONITOR/MWAIT Support ║
║ x Supplemental Streaming SIMD Extensions 3 ║
║ x FMA Extension ║
║ x CMPXCHG16B Support ║
║ x Streaming SIMD Extensions 4.1 ║
║ x Streaming SIMD Extensions 4.2 ║
║ x x2APIC ║
║ x POPCNT Instruction ║
║ x AES Cryptography Support ║
║ x XSAVE/XRSTOR/XSETBV/XGETBV Instructions ║
║ x XGETBV/XSETBV OS Enabled ║
║ x AVX Support ║
║ x Half-Precision Convert (CVT16) ║
║ √ FPU on Chip ║
║ √ IDT-style Model Specific Registers ║
║ x SYSCALL and SYSRET Instructions ║
║ x FCMOV Instruction ║
║ √ 3DNow!~ Technology ║
HWiNFO v6.0.4
██████████████████████████████████Bus info██████████████████████████████████
║ Bus Type Bus Number ║
║ PCI 0 ║
║ AGP 1 ║
║ ISA - ║
HWiNFO v6.0.4
██████████████████████████PCI Devices Information███████████████████████████
║ Bus Dev Fun Device ║
║ 0 0 0 VIA VT8604/5/6 ProSavage PL133/PM133/PN133 Chipset - System║
║ 0 1 0 VIA VT8605 ProSavage PM133 Chipset - A.G.P. Controller ║
║ 0 7 0 VIA VT82C686B PCI-to-ISA Bridge ║
║ 0 7 1 VIA VT82C571 Integrated IDE Controller ║
║ 0 7 2 VIA VT82C686B USB Universal Host Controller ║
║ 0 7 3 VIA VT82C686B USB Universal Host Controller ║
║ 0 7 4 VIA VT82C686B Power Management Controller ║
║ 0 7 5 VIA AC'97 Audio Controller ║
║ 0 8 0 RealTek Semiconductor RTL8139 PCI Fast Ethernet NIC [A/B/C]║
║ 0 11 0 YAMAHA DS-XG PCI Audio CODEC ║
HWiNFO v6.0.4
█████████████████████████████PCI Device Details█████████████████████████████
║ Device Revision: 01 ║
║ Device Class: Host-to-PCI Bridge ║
║ Memory base address 0: E8000000 - EC000007 ║
║ ROM base address: N/A ║
║ Interrupt line: N/A ║
║ Interrupt pin: N/A ║
║ I/O space access: Disabled ║
║ Memory space access: Enabled ║
║ Bus-mastering: Enabled ║
║ Running at 66 MHz: Not Capable ║
║ Fast Back-to-Back: Not Capable ║
║ [ Request Phase Control ] ║
║ CPU Hardwired IOQ Size: 4-Level ║
║ Read-Around-Write: Enabled ║
║ Defer Retry When HCLOCK Active: Enabled ║
║ CPU Read DRAM Timing: DRAM access before snoop ║
║ [ Response Phase Control ] ║
║ CPU Read DRAM 0WS for Back-to-Back: Enabled ║
║ CPU Write DRAM 0WS for Back-to-Back: Enabled ║
║ Fast Response: Enabled ║
║ Non-Posted IOW: Enabled ║
║ CPU Read DRAM Prefetch Buffer Depth: 1-Level ║
║ CPU-to-DRAM Post-Write Buffer Depth: 4-Level ║
║ Concurrent PCI Master/Host Operation: Enabled ║
║ [ Dynamic Defer Time ] ║
║ GTL I/O Buffer Pullup: Enabled ║
║ RAW Write Retire After 2 Writes: Enabled ║
║ Quick Start Select: Disabled ║
║ Snoop Stall Count: 8 ║
║ [ Miscellaneous ] ║
║ HREQ Function: Enabled ║
║ DRAM Frequency Higher Than CPU FSB: Disabled ║
║ AGP/PCI-to-CPU Master / CPU-to-PCI Slave ConEnabledy: ║
║ HPRI Function: Enabled ║
║ P6Lock Function: Enabled ║
║ Line Write / Write Back Without Implicit WriEnabled Data: ║
║ PCI Master Pipeline Access: Enabled ║
║ Initialization of Fast Write Address SelectiTail ║
║ [ Miscellaneous 2 ] ║
║ Zero Length Write: Enabled ║
║ Invalidate CPU Internal Cache on PCI Master Disabled ║
║ 1-1-1-1 PMRDY for PCI Master Access: Head ║
║ [ Shadow RAM Control Register 1 ] ║
║ CC00h-CFFFh Shadow RAM Control: R/W Disabled ║
║ C800h-CBFFh Shadow RAM Control: R/W Disabled ║
║ C400h-C7FFh Shadow RAM Control: Read Enabled ║
║ C000h-C3FFh Shadow RAM Control: Read Enabled ║
║ [ Shadow RAM Control Register 2 ] ║
║ DC00h-DFFFh Shadow RAM Control: R/W Disabled ║
║ D800h-DBFFh Shadow RAM Control: R/W Disabled ║
║ D400h-D7FFh Shadow RAM Control: R/W Disabled ║
║ D000h-D3FFh Shadow RAM Control: R/W Disabled ║
║ [ Shadow RAM Control Register 3 ] ║
║ E000h-EFFFh Shadow RAM Control: R/W Disabled ║
║ F000h-FFFFh Shadow RAM Control: R/W Disabled ║
║ ISA Memory Hole: None ║
║ SMI Redirection to A0000-BFFFF: Disabled ║
║ Video RAM Access Redirect to DRAM: Disabled ║
║ [ DRAM Timing for Banks 0,1 ] ║
║ Precharge Command to Active Command Period: Trp = 3T ║
║ Active Command to Precharge Command Period: Tras = 5T ║
║ CAS Latency: 3T ║
║ DIMM Type: Standard ║
║ ACTIVE to CMD: 3T ║
║ Bank Interleave: None ║
║ [ DRAM Timing for Banks 2,3 ] ║
║ Active Command to Precharge Command Period: Tras = 6T ║
║ CAS Latency: 2T ║
║ Bank Interleave: 2-way ║
║ [ DRAM Timing for Banks 4,5 ] ║
║ CAS Latency: 2T ║
║ [ DRAM Control 1 ] ║
║ SDRAM Open Page Control: Always Precharge ║
║ Bank Page Control: Enabled ║
║ Burst Refresh: Disabled ║
║ System Frequency Divider: ║
║ [ DRAM Control 2 ] ║
║ CPU Operating Frequency Faster Than DRAM: Same As or Equal ║
║ DRAM Operating Frequency Faster Than CPU: Same As or Equal ║
║ 256 Mbit DRAM Support: Enabled ║
║ DRAM Controller Command Register Output: Enabled ║
║ Fast DRAM Precharge for Different Bank: Enabled ║
║ DRAM 4K Pages: Enabled ║
║ DIMM Type: Unbuffered ║
║ CPU / DRAM 66/133 MHz Support: Disabled ║
║ [ Refresh Counter ] ║
║ Refresh Counter: 2144 CPUCLKs ║
║ [ DRAM Arbitration Control ] ║
║ Arbitration Parking Policy: Park at last bus owner ║
║ Fast Read to Write turn-around: Enabled ║
║ Memory Module Configuration: Normal Operation ║
║ MD Bus Second Level Strength Control: More slew rate control ║
║ CAS Bus Second Level Strength Control: More slew rate control ║
║ AGP Pad Slew Rate Control: Disabled ║
║ Multi-Page Open: Enabled ║
║ [ SDRAM Control ] ║
║ CKE Configuration: Disabled ║
║ Fast AGP TLB Lookup: Enabled ║
║ [ DRAM Drive Strength ] ║
║ ESDRAM Memory Type: Disabled ║
║ DRAM Read Latch Delay: 0.5 ns ║
║ MD Drive: 6 mA ║
║ SDRAM Command Drive Strength: 16 mA ║
║ MA[2:13]/WE# Drive Strength: 16 mA ║
║ CAS# Drive Strength: 8 mA ║
║ RAS# Drive Strength: 24 mA ║
║ [ PCI Buffer Control ] ║
║ CPU-to-PCI Posted Writes: Enabled ║
║ PCI Master to DRAM Post-Writes: Enabled ║
║ PCI Master to DRAM Prefetch: Disabled ║
║ Enhance CPU-to-PCI Write: Normal ║
║ PCI Master Read Caching: Enabled ║
║ Delay Transaction: Disabled ║
║ Slave Device Stopped Idle Cycle: Normal ║
║ [ CPU-to-PCI Flow Control 1 ] ║
║ Dynamic Burst: Enabled ║
║ Byte Merge: Disabled ║
║ Posted PCI I/O Cycle Writes: Disabled ║
║ PCI Burst: Enabled ║
║ Fast Back-to-Back PCI Write: Disabled ║
║ Quick Frame Generation: Disabled ║
║ 1-Wait-State PCI Cycles: Disabled ║
║ [ CPU-to-PCI Flow Control 2 ] ║
║ Retry Timeout Action: Flush buffer ║
║ Retry Limit: 2x ║
║ Clear Failed Data and Continue Retry: Pop failed data ║
║ Backoff CPU If Retry Fails: Enabled ║
║ Reduce 1T for FRAME# Generation: Disabled ║
║ Reduce 1T for CPU read PCI slave: Disabled ║
║ [ PCI Master Control 1 ] ║
║ PCI Master 1 WS Write: 0 WS TRDY# Resp. ║
║ PCI Master 1 WS Read: 0 WS TRDY# Resp. ║
║ Assert STOP# After PCI Write Timeout: Enabled ║
║ Assert STOP# After PCI Read Timeout: Enabled ║
║ LOCK# Function: Disabled ║
║ PCI Master Broken Timer: Disabled ║
║ [ PCI Master Control 2 ] ║
║ PCI Master Read Prefetch Enhance: Always Prefetch ║
║ Dummy Request Handling: Disabled ║
║ PCI Delay Transaction Timeout: Enabled ║
║ Backoff CPU Immediately on CPU-to-AGP: Enabled ║
║ CPU/PCI Master Latency Timer Control: Raising resets, falling reloa║
║ [ PCI Arbitration Control 1 ] ║
║ Arbitration Mechanism: Fair ║
║ Arbitration Mode: REQ#-based ║
║ Latency Timer: 2 ║
║ PCI Master Bus Timeout: 32 PCICLKs ║
║ [ PCI Arbitration Control 2 ] ║
║ CPU-to-PCI Post-Write Retry Failed: Go to arbitration ║
║ CPU Latency Timer Bit-0: No time slot ║
║ Master Priority Rotation Control: After 1 PCI master grant ║
║ Select REQn to RQ4 Mapping: REQ4# ║
║ CPU QW or High DW Read Accesses to PCI SlaveEnabledd To Be Backed Off: ║
║ RQ4 as High Priority Master: Disabled ║
║ [ PMU Control 1 ] ║
║ I/O Port 22h Access: Forwarded to PCI ║
║ Suspend Refresh Type: CBR Refresh ║
║ Dynamic Clock: Enabled ║
║ GSTOP# Assertion: Disabled ║
║ Memory Clock Function: CKE Enabled ║
║ [ PMU Control 2 ] ║
║ CPU Interface Controller Clock Dynamic Stop:Enabled ║
║ DRAM Controller Clock Dynamic Stop: Disabled ║
║ AGP Controller Clock Dynamic Stop: Enabled ║
║ PCI Controller Clock Dynamic Stop: Enabled ║
║ Pseudo Power Good: Disabled ║
║ Indicate SIO Request to DRAM Controller: Enabled ║
║ [ Miscellaneous Control 1 ] ║
║ No Time-Out Arbitration for Consecutive FramEnabledses: ║
║ Invalidate PCI / AGP Buffered (Cached) Read Enabledr CPU to PCI / AGP Acc║
║ Background PCI-to-PCI Write Cycle Mode: Disabled ║
║ South Bridge PCI Master Force Timeout When PEnableder Occupancy Timer Is ║
║ [ Miscellaneous Control 2 ] ║
║ PCI Master Access PMRDY Select: Tail ║
║ PCI Bus Operating Freq: 33 MHz ║
║ [ GART/TLB Control ] ║
║ PCI Master Address Translation for GA AccessEnabled ║
║ AGP Master Address Translation for GA AccessEnabled ║
║ CPU Address Translation for GA Access: Enabled ║
║ AGP Address Translation for GA Access: Enabled ║
║ [ Graphics Aperture Size ] ║
║ Graphics Aperture Size: 64M ║
║ [ GA Translation Table Base ] ║
║ GA Translation Table Base: 0 ║
║ PCI Master Directly Accesses DRAM if in GARTDisabled ║
║ Graphics Aperture Status: Enabled ║
║ [ AGP Status Register ] ║
║ Max. AGP Request Queue Depth: 31 ║
║ AGP Side Band Addressing: Supported ║
║ Supported AGP Data Transfer: 1x, 2x and 4x ║
║ [ AGP Command Register ] ║
║ AGP Request Queue Depth: 0 ║
║ AGP Sideband Addressing: Disabled ║
║ AGP Status: Disabled ║
║ Current AGP Transfer Rate: None ║
║ [ AGP Control ] ║
║ AGP Read Synchronization: Disabled ║
║ AGP Read Snoop DRAM Post-Write Buffer: Enabled ║
║ AGP Master Request has Higher Priority if AGDisabledller is Parking at AG║
║ 2X Rate Support: Supported ║
║ LPR In-Order Access: Enabled ║
║ AGP Arbitration Parking: Enabled ║
║ AGP to PCI Master or CPU to PCI Turnaround C1Tle: ║
║ [ AGP Latency Timer ] ║
║ Choose First or Last Ready of DRAM: First ready chosen ║
║ AGP Data Phase Latency Timer: 2 ║
║ [ AGP Miscellaneous Control ] ║
║ >4G Support: Not supported ║
║ Fast Write: Not supported ║
║ 4x Rate Support: Not supported ║
║ [ AGP Pad Control ] ║
║ AGP 4x Strobe VREF Control: STB VREF <=> STB# ║
║ AGP 4x Strobe & GD Pad Drive Strength: Controlled by strenght reg ║
║ AGP Compensation Circuit N Control Output: 7 ║
║ AGP Compensation Circuit P Control Output: 7 ║
║ [ AGP Drive Strength ] ║
║ AGP Output Buffer Drive Strength N Control: 15 ║
║ AGP Output Buffer Drive Strength P Control: 15 ║
║ [ AGP Pad Drive / Delay Control ] ║
║ GD/GBE/GDS, SBA/SBS Control: SBA/SBS cap (3.3V), else no c║
║ GD[31-16] Staggered Delay: 1 ns ║
║ GDS Output Delay: None ║
║ [ DRAM Arbitration Timer 1 ] ║
║ AGP Timer: 12 DCLKs ║
║ Host CPU Timer: 8 DCLKs ║
║ [ DRAM Arbitration Timer 2 ] ║
║ VGA High Priority Timer: 64 DCLKs ║
║ VGA Timer: 32 DCLKs ║
║ [ CPU Direct Access FB Base ] ║
║ Internal VGA: Enabled ║
║ Frame Buffer Size: 8 MB ║
║ CPU Direct Access Frame Buffer: Disabled ║
║ Frame Buffer Base Address [31:21]: 0 ║
║ [ Back Door Control 1 ] ║
║ Back-Door Max # of AGP Requests: 32 ║
║ Back-Door Device ID: Disabled ║
║ [ Back Door Control 2 ] ║
║ Max # of AGP Requests: 1 ║
║ [ Back-Door Device ID ] ║
║ Back-Door Device ID: 0 ║
HWiNFO v6.0.4
║ Device Revision: 00 ║
║ Device Class: PCI-to-PCI Bridge ║
║ I/O space access: Enabled ║
║ Running at 66 MHz: Capable ║
HWiNFO v6.0.4
║ Device Revision: 40 ║
║ Device Class: PCI-to-ISA Bridge ║
║ [ ISA Bus Control ] ║
║ ISA Command Delay: Normal ║
║ Extended ISA Bus Ready: Disabled ║
║ ISA Slave Wait States: 4 WS ║
║ Chipset I/O Wait States: 2 WS ║
║ I/O Recovery Time: Enabled ║
║ Extended ALE: Disabled ║
║ ROM Wait States: 1 WS ║
║ ROM Writes: Disabled ║
║ [ ISA Test Mode ] ║
║ Bus Refresh Arbitration: Disabled ║
║ XRDY Test Mode: Disabled ║
║ Fast Reset Via PORT 92h: Disabled ║
║ A20G Emulation: Disabled ║
║ Double DMA Clock: 1/2 ISA clock ║
║ SHOLD Lock During INTA: Disabled ║
║ Refresh Request Test Mode: Disabled ║
║ ISA Refresh: Enabled ║
║ [ ISA Clock Control ] ║
║ Latch IO16#: Enabled ║
║ MS16# Output: Enabled ║
║ Master Request Test Mode: Disabled ║
║ ISA Bus Clock Select: Disabled (=PCLK/4) ║
║ ISA Bus Clock: PCICLK/3 ║
║ [ ROM Decode Control ] ║
║ 64K ROM At FFFE00000h-FFFEFFFFh: Disabled ║
║ 384K ROM At FFF80000h-FFFDFFFFh: Disabled ║
║ 32K ROM At E8000h-EFFFFh: Disabled ║
║ 32K ROM At E0000h-E7FFFh: Disabled ║
║ 32K ROM At D8000h-D8FFFh: Disabled ║
║ 32K ROM At D0000h-D7FFFh: Disabled ║
║ 32K ROM At C8000h-CFFFFh: Disabled ║
║ 32K ROM At C0000h-C7FFFh: Disabled ║
║ [ Keyboard Controller Control ] ║
║ KBC Timeout Test: Disabled ║
║ Mouse Lock: Disabled ║
║ [ Type F DMA Control ] ║
║ ISA Master/DMA To PCI Line Buffer: Enabled ║
║ Type F Timing On DMA Channel 7: Disabled ║
║ Type F Timing On DMA Channel 6: Disabled ║
║ Type F Timing On DMA Channel 5: Disabled ║
║ Type F Timing On DMA Channel 3: Disabled ║
║ Type F Timing On DMA Channel 2: Disabled ║
║ Type F Timing On DMA Channel 1: Disabled ║
║ Type F Timing On DMA Channel 0: Disabled ║
║ PCI Master Write Wait States: 0 WS ║
║ Gate INTRQ: Enabled ║
║ Flush Line Buffer for Int or DMA IOR Cycle: Enabled ║
║ Config Command Register Test Mode: Disabled ║
║ Interruptions Of PCI Burst Reads: Allowed ║
║ Posted Memory Writes: Disabled ║
║ CPU Reset Signal: INIT ║
║ PCI Transaction Delay: Disabled ║
║ EISA Port 4D0h/4D1h: Enabled ║
║ Interrupt Controller Shadow Register: Disabled ║
║ Write Delay Transaction Time-out Timer: Disabled ║
║ Read Delay Transaction Time-out Timer: Disabled ║
║ [ Miscellaneous Control 3 ] ║
║ Extra RTC Port 74h/75h: Disabled ║
║ Integrated USB Controller: Enabled ║
║ Integrated IDE Controller: Enabled ║
║ 512K PCI Memory Decode: Enabled ║
║ [ IDE Interrupt Routing ] ║
║ Wait For PGNT Before Grant to ISA Master/DMAYes ║
║ Port 0-FFh Bus Select: Access via SD bus ║
║ Secondary IDE Channel IRQ: IRQ15 ║
║ Primary IDE Channel IRQ: IRQ14 ║
║ [ ISA DMA/Master Memory Access Control 1 ] ║
║ PCI Memory Hole Bottom: 0 ║
║ [ ISA DMA/Master Memory Access Control 2 ] ║
║ PCI Memory Hole Top: 0 ║
║ [ ISA DMA/Master Memory Access Control 3 ] ║
║ Top Of PCI Memory For ISA DMA/Master Access:16 MBytes ║
║ Access To E0000h-EFFFFh Forwarded To PCI: Disabled ║
║ Access To A0000h-BFFFFh Forwarded To PCI: Disabled ║
║ Access To 80000h-9FFFFh Forwarded To PCI: Enabled ║
║ Access To 00000h-7FFFFh Forwarded To PCI: Enabled ║
║ Access To DC000h-DFFFFh Forwarded To PCI: Disabled ║
║ Access To D8000h-DBFFFh Forwarded To PCI: Disabled ║
║ Access To D4000h-D7FFFh Forwarded To PCI: Disabled ║
║ Access To D0000h-D3FFFh Forwarded To PCI: Disabled ║
║ Access To CC000h-CFFFFh Forwarded To PCI: Disabled ║
║ Access To C8000h-CBFFFh Forwarded To PCI: Disabled ║
║ Access To C4000h-C7FFFh Forwarded To PCI: Disabled ║
║ Access To C0000h-C3FFFh Forwarded To PCI: Disabled ║
║ [ PNP DMA Request Control ] ║
║ PnP Routing for Parallel Port: DRQ0 ║
║ PnP Routing for Floppy: DRQ2 ║
║ [ PNP IRQ Routing 1 ] ║
║ PnP Routing for Parallel Port: IRQ7 ║
║ PnP Routing for Floppy: IRQ6 ║
║ [ PCI IRQ Polarity ] ║
║ PIRQA#: Level-sensitive ║
║ PIRQB#: Level-sensitive ║
║ PIRQC#: Level-sensitive ║
║ PIRQD#: Level-sensitive ║
║ [ PnP IRQ Routing 4 ] ║
║ PIRQA# Routing: IRQ11 ║
║ [ PnP IRQ Routing 5 ] ║
║ PIRQC# Routing: IRQ9 ║
║ PIRQB# Routing: Disabled ║
║ [ PnP IRQ Routing 6 ] ║
║ PIRQD# Routing: IRQ10 ║
║ [ PCS0# Control ] ║
║ PCS0# Pin Function: PCS0# ║
║ [ KBC / RTC Power-On Strap Options ] ║
║ Keyboard RP16: Enabled ║
║ Keyboard RP15: Enabled ║
║ Keyboard RP14: Enabled ║
║ Keyboard RP13: Enabled ║
║ Audio Function: Enabled ║
║ Internal RTC: Enabled ║
║ Internal PS/2 Mouse: Enabled ║
║ Internal Keyboard Controller: Enabled ║
║ [ Internal RTC Test Mode ] ║
║ RTC Map Rx32 to Rx3F: Enabled ║
║ RTC Reset: Disabled ║
║ RTC SRAM Access: Disabled ║
║ RTC Test Mode: Disabled ║
║ [ DMA Control ] ║
║ PCS0# & PCS1# 16-Bit I/O: Disabled ║
║ Passive Release: Disabled ║
║ Internal Passive Release: Disabled ║
║ Dummy PREQ: Disabled ║
║ External APIC Configuration: External APIC on 🤣 Bus ║
║ DMA Line Buffer: Enabled ║
║ [ Distributed DMA, Channel 0 Base/Enable ] ║
║ Base Address: 0 ║
║ DMA Channel: Disabled ║
║ [ Distributed DMA, Channel 1 Base/Enable ] ║
║ Base Address: 0 ║
║ [ Distributed DMA, Channel 2 Base/Enable ] ║
║ Base Address: 0 ║
║ [ Distributed DMA, Channel 3 Base/Enable ] ║
║ Base Address: 0 ║
║ [ Distributed DMA, Channel 5 Base/Enable ] ║
║ Base Address: 0 ║
║ [ Distributed DMA, Channel 6 Base/Enable ] ║
║ Base Address: 0 ║
║ [ Distributed DMA, Channel 7 Base/Enable ] ║
║ Base Address: 0 ║
║ [ GPIO Control 1 ] ║
║ APIC Enable: Disabled ║
║ SERIRQ Pin: SERIRQ input from DRQ2 ║
║ GPIOD Direction: Input ║
║ GPIOC Direction: Input ║
║ GPIOB Direction: Input ║
║ GPIOA Direction: Input ║
║ THRM: GPI5 ║
║ GPI0/IOCHCK Select: IOCHCK# ║
║ [ GPIO Control 2 ] ║
║ GPO7 Enable: SLP# ║
║ GPO5 Enable: GPO5 ║
║ GPO4 Enable: GPO4 ║
║ FDC External IRQ / DRQ Via DACK2# / DRQ2: FDCIRQ, FDCDRQ ║
║ GPO25 Enable: DACK2# ║
║ GPO24 Enable: DRQ2/SERIRQ ║
║ Decode: Subtractive ║
║ [ GPIO Control 3 ] ║
║ Over-Current (OC) Input: Disabled ║
║ OC[3:0] From SD[3:0] By Scan: Disabled ║
║ GPO14 / GPO15 Enable: IRTX and IRRX ║
║ PCS0# Enable: Disabled ║
║ MCCS# Enable: GPIOD/GPI11/GPO11 ║
║ CHAS Enable: GPIOC ║
║ GPO12 Enable: XDIR ║
║ GPOWE# (GPO[23-16]) Enable: GPIOA ║
║ [ GPIO Control 4 ] ║
║ DRQ / DACK# Pins are GPI / GPO: Disabled ║
║ Game Port XY Pins are GPI / GPO: Disabled ║
║ SERIRQ SMI Slot: Disabled ║
║ RTC Rx32 Write Protect: Disabled ║
║ RTC Rx0D Write Protect: Enabled ║
║ GPO13 Enable: SOE# ║
║ [ PCI DMA Channel Enable ] ║
║ PCI DMA Pair A: Disabled ║
║ PCI DMA Channel 7 Enable: Disabled ║
║ PCI DMA Channel 6 Enable: Disabled ║
║ PCI DMA Channel 5 Enable: Disabled ║
║ PCI DMA Channel 3 Enable: Disabled ║
║ PCI DMA Channel 2 Enable: Disabled ║
║ PCI DMA Channel 1 Enable: Disabled ║
║ PCI DMA Channel 0 Enable: Disabled ║
║ [ 32-Bit DMA Control ] ║
║ 32-Bit DMA High Page IOBase: 0 ║
║ 32-Bit DMA: Disabled ║
║ [ ISA Positive Decoding Control 1 ] ║
║ On-Board I/O Port Positive Decoding: Disabled ║
║ MSS I/O Port Positive Decoding: Disabled ║
║ MSS I/O Decode Range: 0530h-0537h ║
║ APIC Positive Decoding: Disabled ║
║ BIOS ROM Positive Decoding: Disabled ║
║ PCS0 Positive Decoding: Disabled ║
║ [ ISA Positive Decoding Control 2 ] ║
║ FDC Positive Decoding: Disabled ║
║ LPT Positive Decoding: Disabled ║
║ LPT Decode Range: 3BCh-3BFh, 7BCh-7BEh ║
║ Game Port Positive Decoding: Disabled ║
║ MIDI Positive Decoding: Disabled ║
║ MIDI Decode Range: 300h-303h ║
║ [ ISA Positive Decoding Control 3 ] ║
║ COM Port B Positive Decoding: Disabled ║
║ COM Port B Decode Range: 3F8h-3FFh ║
║ COM Port A Positive Decoding: Disabled ║
║ COM Port A Decode Range: 3F8h-3FFh ║
║ [ ISA Positive Decoding Control 4 ] ║
║ FDC Decoding Range: Primary ║
║ Sound Blaster Positive Decoding: Disabled ║
║ Sound Blaster Decode Range: 220h-22Fh, 230h-233h ║
║ [ Extended Function Enable ] ║
║ Function 3 USB Ports 2-3: Disabled ║
║ Function 6 Modem / Audio: Enabled ║
║ Function 5 Audio: Disabled ║
║ Super-I/O Configuration: Disabled ║
║ Super-I/O: Enabled ║
║ [ PCS Control ] ║
║ PCS3# For Internal I/O: Disabled ║
║ PCS2# For Internal I/O: Disabled ║
║ PCS1# For Internal I/O: Disabled ║
║ PCS0# For Internal I/O: Disabled ║
║ PCS3#: Disabled ║
║ PCS2#: Disabled ║
║ PCS1#: Disabled ║
║ PCS0#: Disabled ║
║ PCS2# I/O Port Address: 0 ║
║ PCS3# I/O Port Address: 0 ║
HWiNFO v6.0.4
║ Device Revision: 06 ║
║ Device Class: IDE Controller ║
║ Memory base address 4: I/O 0000C000 - 0000C00E ║
║ Fast Back-to-Back: Capable ║
║ [ Chip Enable ] ║
║ Primary IDE Channel: Enabled ║
║ Secondary IDE Channel: Enabled ║
║ [ IDE Configuration I ] ║
║ Primary IDE Read Prefetch Buffer: Enabled ║
║ Primary IDE Post Write Buffer: Enabled ║
║ Secondary IDE Read Prefetch Buffer: Enabled ║
║ Secondary IDE Post Write Buffer: Disabled ║
║ [ IDE Configuration II ] ║
║ PIO Operating Mode - Primary Channel: Compatibility Mode ║
║ PIO Operating Mode - Secondary Channel: Compatibility Mode ║
║ [ FIFO Configuration ] ║
║ FIFO Configuration: PRI = 8, SEC = 8 ║
║ Primary Channel FIFO Threshold: 1/2 ║
║ Secondary Channel FIFO Threshold: 1/2 ║
║ Master Read Cycle IRDY# Wait State: 0 WS ║
║ Master Write Cycle IRDY# Wait State: 0 WS ║
║ FIFO Output Data 1/2 Clock Advance/PIO Read Enabledch Byte Counter: ║
║ Bus-Master IDE Status Register Read Retry: Enabled ║
║ Packet Command Prefetching: Enabled ║
║ UltraDMA Host Must Wait for First Transfer BEnabledermination: ║
║ Interrupt Steering Swap Between Channels: Disabled ║
║ Rx3C Write Protect: Enabled ║
║ Memory-Read-Multiple Command: Enabled ║
║ Memory-Write-and-Invalidate Command: Enabled ║
║ Read DMA FIFO Flush (PRI): Enabled ║
║ Read DMA FIFO Flush (SEC): Enabled ║
║ End-of-Sector FIFO Flush (PRI): Disabled ║
║ End-of-Sector FIFO Flush (SEC): Disabled ║
║ Maximum DRDY# Pulse Width: Unlimited ║
║ [ Drive Timing Control ] ║
║ Primary Drive 0 Active Pulse Width: 3 clocks ║
║ Primary Drive 0 Recovery Time: 2 PCICLKs ║
║ Primary Drive 1 Active Pulse Width: 11 PCICLKs ║
║ Primary Drive 1 Recovery Time: 9 clocks ║
║ Secondary Drive 0 Active Pulse Width: 3 clocks ║
║ Secondary Drive 0 Recovery Time: 2 PCICLKs ║
║ Secondary Drive 1 Active Pulse Width: 11 PCICLKs ║
║ Secondary Drive 1 Recovery Time: 9 clocks ║
║ [ Address Setup Time ] ║
║ Primary Drive 0 Address Setup Time: 4T ║
║ Primary Drive 1 Address Setup Time: 4T ║
║ Secondary Drive 0 Address Setup Time: 4T ║
║ Secondary Drive 1 Address Setup Time: 4T ║
║ [ Secondary Non-01F0h Port Access Timing ] ║
║ DIOR#/DIOW# Active Pulse Width: 16 PCICLKs ║
║ DIOR#/DIOW# Recovery Time: 16 PCICLKs ║
║ [ Primary Non-01F0h Port Access Timing ] ║
║ [ Ultra-DMA Extended Timing Control (SEC DRV 1) ] ║
║ Ultra-DMA Mode Enable Method: Using Set Feature Cmd. ║
║ Ultra-DMA Mode: Disabled ║
║ Transfer Mode: DMA or PIO ║
║ Cable Type Reporting: 40-pin ║
║ Drive Cycle Time: 5T ║
║ [ Ultra-DMA Extended Timing Control (SEC DRV 0) ] ║
║ Ultra-DMA Mode Enable Method: Using this reg. ║
║ Ultra-DMA Mode: Enabled ║
║ Transfer Mode: Ultra-DMA ║
║ Cable Type Reporting: 80-pin ║
║ Drive Cycle Time: 6T ║
║ [ Ultra-DMA Extended Timing Control (PRI DRV 1) ] ║
║ [ Ultra-DMA Extended Timing Control (PRI DRV 0) ] ║
║ [ Ultra-DMA FIFO Control ] ║
║ Lower ISA Request Priority When Write DeviceDisabledCommand is Issued: ║
║ Clear Native Mode Interrupt on Falling Edge Enabledd Interrupt: ║
║ Improve PIO Prefetch and Post-Write PerformaDisabled ║
║ Memory Prefetch Size: 1 line ║
║ Change Drive Clears All FIFO & Internal StatEnabled ║
║ Complete DMA Cycle with Transfer Size Less TEnabledO Size: ║
║ [ IDE Clock Gating ] ║
║ Dynamic 100/133 MHz Clock Gating: Enabled ║
║ Dynamic 66 MHz Clock Gating: Enabled ║
║ [ Primary Sector Size ] ║
║ Sector Size: 512 Bytes/Sector ║
║ [ Secondary Sector Size ] ║
HWiNFO v6.0.4
║ Device Revision: 1A ║
║ Device Class: Universal Serial Bus (USB) ║
║ Memory base address 4: I/O 0000C400 - 0000C41E ║
║ Interrupt line: IRQ10 ║
║ Interrupt pin: INTD# ║
║ PCI Memory Commands Support: MRL, MRM, and MWAI ║
║ Babbled Port of EOF: Enabled ║
║ PCI Parity Checking: Disabled PERR# ║
║ Frame Interval Select: 1 msec ║
║ USB Data Length Limit: 1280 bytes ║
║ USB Power Management/Improved FIFO Latency: Disabled ║
║ DMA Limited To: 16-DW Burst ║
║ PCI Wait States: 0 WS ║
║ USB 1.1 Improvement for EOP: Disabled (USB 1.0) ║
║ Trap Status Bits Override: Disabled ║
║ A20GATE Pass Through Option: Pass ║
║ [ Miscellaneous Control 4 ] ║
║ Continue Transmission of Erroneous Data on FEnablederrun: ║
║ Issue CRC Error Instead of Stuffing Error onEnablednderrun: ║
║ [ Miscellaneous Control 5 ] ║
║ Issue Bad CRC5 in SOF After FIFO Underrun: Enabled ║
║ Lengthen PreSOF Time: Enabled ║
║ Issue Nonzero Bad CRC Code on FIFO Underrun:Non zero CRC ║
║ [ Miscellaneous Control 6 ] ║
║ EHCI Supports PME Assertion in D3 Cold StateNot Supported ║
║ UHCI Supports PME Assertion in D3 Cold StateNot Supported ║
║ [ Miscellaneous Control 7 ] ║
║ Use External 60 MHz Clock: Disabled ║
║ [ USB Release Number ] ║
║ USB Release Number: 1.0 ║
║ [ USB Legacy Support ] ║
║ UHCI v1.1 Compliant: 2000 ║
HWiNFO v6.0.4
║ Memory base address 4: I/O 0000C800 - 0000C81E ║
HWiNFO v6.0.4
║ Device Class: Unknown Bridge ║
║ Memory space access: Disabled ║
║ Bus-mastering: Disabled ║
HWiNFO v6.0.4
║ Device Revision: 50 ║
║ Device Class: Multimedia Audio Adapter ║
║ Memory base address 0: I/O 0000CC00 - 0000CCFE ║
║ Memory base address 1: I/O 0000D000 - 0000D002 ║
║ Memory base address 2: I/O 0000D400 - 0000D402 ║
║ Interrupt line: IRQ9 ║
║ Interrupt pin: INTC# ║
HWiNFO v6.0.4
║ Device Revision: 10 ║
║ Device Class: Ethernet Adapter ║
║ Memory base address 0: I/O 0000D800 - 0000D8FE ║
║ Memory base address 1: EE008000 - EE0080FF ║
║ Interrupt line: IRQ11 ║
║ Interrupt pin: INTA# ║
HWiNFO v6.0.4
║ Device Revision: 02 ║
║ Memory base address 0: EE000000 - EE007FFF ║
║ Memory base address 1: I/O 0000DC00 - 0000DC3E ║
║ Memory base address 2: I/O 0000E000 - 0000E002 ║
HWiNFO v6.0.4
██████████████████████████AGP Devices Information███████████████████████████
║ 1 0 0 S3 ProSavage PM133 (86C370) Video Adapter ║
HWiNFO v6.0.4
║ Device Class: VGA Compatible Adapter ║
║ Memory base address 0: ED000000 - ED07FFFF ║
║ Memory base address 1: E0000000 - E8000007 ║
HWiNFO v6.0.4
███████████████████████████ISA and other devices████████████████████████████
║ No devices/cards found ║
HWiNFO v6.0.4
█████████████████████████████Memory Information█████████████████████████████
║ Row Size Type ECC Speed Module Manufacturer and Type ║
║ 0 128 MB SDRAM None 133 MHz Unknown ║
HWiNFO v6.0.4
█████████████████████████Memory Module Information██████████████████████████
║ Bank Number: 0 ║
║ Module Size: 128 MB ║
║ Memory Type: SDRAM ║
║ Error Check/Correction: None ║
║ Memory Speed: 133 MHz ║
║ Module Manufacturer: Unknown ║
║ Module Type: ║
║ Serial Number: N/A ║
║ Date Of Manufacture: N/A ║
║ Data Width: 64-bit ║
║ Voltage: LVTTL ║
║ SPD Version: 1.2 ║
║ Number Of Rows: 1 ║
║ Row Address Bits: 13 ║
║ Column Address Bits: 9 ║
║ Refresh Rate: Reduced 0.5x (7.8 us) + Self Refresh ║
║ Min. Back-to-Back Clock Delay: 1 clock(s) ║
║ Supported Burst Lengths: 1, 2, 4, 8 ║
║ Number Of Banks: 4 ║
║ Supported CAS Latency: 3 (7.50 ns/133.3 MHz), 2 (10.00 ns/100.║
║ Supported CS Latency: 0 ║
║ Supported WE Latency: 0 ║
║ Early RAS# Precharge: Not supported ║
║ Auto Precharge: Supported ║
║ Precharge All: Supported ║
║ Write1/Read Burst: Supported ║
║ Buffered Addr/Control Inputs: Not supported ║
║ Registered Addr/Control Inputs: Not supported ║
║ On-card PLL For Clock: Not supported ║
║ Buffered DQMB Inputs: Not supported ║
║ Registered DQMB Inputs: Not supported ║
║ Differential Clock Input: Not supported ║
║ Redundant Row Address: Not supported ║
║ Min. Row Precharge Time: 20.00 ns ║
║ Min. Row-activate Delay: 15.00 ns ║
║ Min. RAS-to-CAS Delay: 20.00 ns ║
║ Min. RAS Pulse Width: 45 ns ║
║ Intel Concurrent Auto Precharge: Supported ║
║ CAS Latency 2: Not supported ║
║ CAS Latency 3: Supported ║
║ Max. Junction Temperature: 90 °C ║
HWiNFO v6.0.4
██████████████████████████████BIOS Information██████████████████████████████
║ Segment Size BIOS Extensions ║
║ C000h 48K S3 ProSavage PM133 (86C370) Video Adapter ║
║ Flash BIOS: <Skipped> ║
║ BIOS32 services: Present ║
║ Plug-and-Play support: Present (V1.0) ║
║ APM support: Present (V1.2) ║
║ ACPI support: Not Present ║
HWiNFO v6.0.4
█████████████████████████████Plug-and-Play Info█████████████████████████████
║ PnP Capable Devices: None ║
║ PnP System Devices: 15 Nodes ║
║ PnP ESCD Support: Present (V2.1) ║
║ PnP DMI Support: Not Present ║
HWiNFO v6.0.4
█████████████████████████Plug-and-Play Device Nodes█████████████████████████
║ Node 0: PNP0000 - Programmable Interrupt Controller ║
║ Node 1: PNP0200 - DMA Controller ║
║ Node 2: PNP0100 - System Timer ║
║ Node 3: PNP0B00 - RealTime Clock ║
║ Node 4: PNP0303 - 101/102-Key or MS Natural Keyboard ║
║ Node 5: PNP0800 - PC Speaker ║
║ Node 6: PNP0C04 - Numeric Data Processor ║
║ Node 7: PNP0C01 - System Board Extension ║
║ Node 8: PNP0C02 - Motherboard Resources ║
║ Node 9: PNP0A03 - PCI Bus ║
║ Node 10: PNP0F13 - Logitech PS/2 Port Mouse ║
║ Node 12: PNP0700 - Floppy Controller ║
║ Node 13: PNP0501 - 16550A-compatible UART Serial Port ║
║ Node 14: PNP0501 - 16550A-compatible UART Serial Port ║
║ Node 15: PNP0400 - Parallel Port ║
HWiNFO v6.0.4
█████████████████████Plug-and-Play Device Node Details██████████████████████
║ Device ID: PNP0000 (Programmable Interrupt Controller) ║
║ Device Type Code: 080000 ║
║ Device Features: [x Disableable] [x Configurable] [x Removable] ║
║ Device Capabilities: [x IPL] [x Input] [x Output] [x Docking] ║
║ Supported IRQ(s): 2 ║
║ I/O Port(s): 0020 ║
║ I/O Port(s): 00A0 ║
HWiNFO v6.0.4
║ Device ID: PNP0200 (DMA Controller) ║
║ Device Type Code: 080100 ║
║ Supported DMA(s): 4 ║
║ I/O Port(s): 0000 ║
║ I/O Port(s): 0081 ║
║ I/O Port(s): 0087 ║
║ I/O Port(s): 0089 ║
║ I/O Port(s): 008F ║
║ I/O Port(s): 00C0 ║
HWiNFO v6.0.4
║ Device ID: PNP0100 (System Timer) ║
║ Device Type Code: 080201 ║
║ Supported IRQ(s): 0 ║
║ I/O Port(s): 0040 ║
HWiNFO v6.0.4
║ Device ID: PNP0B00 (RealTime Clock) ║
║ Device Type Code: 080300 ║
║ Supported IRQ(s): 8 ║
║ I/O Port(s): 0070 ║
HWiNFO v6.0.4
║ Device ID: PNP0303 (101/102-Key or MS Natural Keyboard) ║
║ Device Type Code: 090000 ║
║ Device Capabilities: [x IPL] [√ Input] [x Output] [x Docking] ║
║ Supported IRQ(s): 1 ║
║ I/O Port(s): 0060 ║
║ I/O Port(s): 0064 ║
HWiNFO v6.0.4
║ Device ID: PNP0800 (PC Speaker) ║
║ Device Type Code: 088000 ║
║ I/O Port(s): 0061 ║
HWiNFO v6.0.4
║ Device ID: PNP0C04 (Numeric Data Processor) ║
║ Device Type Code: 0B0100 ║
║ Supported IRQ(s): 13 ║
║ I/O Port(s): 00F0 ║
HWiNFO v6.0.4
║ Device ID: PNP0C01 (System Board Extension) ║
║ Device Type Code: 050000 ║
║ Memory Location (fixed): 00000000-0009FFFF (RAM) ║
║ Memory Location (fixed): FFFE0000-FFFFFFFF (ROM) ║
║ Memory Location (fixed): FEE00000-FEE0FFFF (ROM) ║
║ Memory Location (fixed): 00100000-00FFFFFF (RAM) ║
HWiNFO v6.0.4
║ Device ID: PNP0C02 (Motherboard Resources) ║
║ Memory Location (fixed): 000F0000-000F3FFF (ROM) ║
║ Memory Location (fixed): 000F4000-000F7FFF (ROM) ║
║ Memory Location (fixed): 000F8000-000FBFFF (ROM) ║
║ Memory Location (fixed): 000FC000-000FFFFF (ROM) ║
HWiNFO v6.0.4
║ Device ID: PNP0A03 (PCI Bus) ║
║ Device Type Code: 060400 ║
║ I/O Port(s): 04D0 ║
║ I/O Port(s): 0CF8 ║
║ I/O Port(s): 4000 ║
║ I/O Port(s): 4080 ║
║ I/O Port(s): 5000 ║
║ I/O Port(s): 6000 ║
HWiNFO v6.0.4
║ Device ID: PNP0F13 (Logitech PS/2 Port Mouse) ║
║ Device Type Code: 090200 ║
║ Device Features: [√ Disableable] [√ Configurable] [x Removable] ║
║ Supported IRQ(s): 12 ║
HWiNFO v6.0.4
║ Device ID: PNP0700 (Floppy Controller) ║
║ Device Type Code: 010200 ║
║ Supported DMA(s): 2 ║
║ I/O Port(s): 03F0 ║
║ I/O Port(s): 03F7 ║
║ Supported IRQ(s): 6 ║
HWiNFO v6.0.4
║ Device ID: PNP0501 (16550A-compatible UART Serial Port) ║
║ Device Type Code: 070002 ║
║ Supported IRQ(s): 4 ║
║ I/O Port(s): 03F8 ║
HWiNFO v6.0.4
║ Supported IRQ(s): 3 ║
║ I/O Port(s): 02F8 ║
HWiNFO v6.0.4
║ Device ID: PNP0400 (Parallel Port) ║
║ Device Type Code: 070100 ║
║ Supported IRQ(s): 7 ║
║ I/O Port(s): 03BC ║
HWiNFO v6.0.4
██████████████████Extended System Configuration Data Info███████████████████
║ Board 0: Motherboard ║
║ Board 1: PCI Slot ║
║ Board 2: PCI Slot ║
║ Board 3: PCI Slot ║
║ Board 4: PCI Slot ║
║ Board 5: PCI Slot ║
║ Board 6: PCI Slot ║
HWiNFO v6.0.4
███████████████████████████ESCD Motherboard Info████████████████████████████
║ Slot Number: 00h ║
║ Slot Type: Expansion Slot ║
║ IRQ: 2, Edge triggered ║
║ I/O Port: 0020-0021 ║
║ I/O Port: 00A0-00A1 ║
║ DMA: 4 ║
║ I/O Port: 0000-000F ║
║ I/O Port: 0081-0083 ║
║ I/O Port: 0087-0087 ║
║ I/O Port: 0089-008B ║
║ I/O Port: 008F-0091 ║
║ I/O Port: 00C0-00CF ║
║ IRQ: 0, Edge triggered ║
║ I/O Port: 0040-0043 ║
║ IRQ: 8, Edge triggered ║
║ I/O Port: 0070-0071 ║
║ IRQ: 1, Edge triggered ║
║ I/O Port: 0060-0060 ║
║ I/O Port: 0064-0064 ║
║ I/O Port: 0061-0061 ║
║ IRQ: 13, Edge triggered ║
║ I/O Port: 00F0-00FF ║
║ Expansion Memory: 00000000-0009FFFF ║
║ Expansion Memory: FFFE0000-FFFFFFFF ║
║ Expansion Memory: FEE00000-FEE0FFFF ║
║ Expansion Memory: 00100000-00FFFFFF ║
║ Expansion Memory: 000F0000-000F3FFF ║
║ Expansion Memory: 000F4000-000F7FFF ║
║ Expansion Memory: 000F8000-000FBFFF ║
║ Expansion Memory: 000FC000-000FFFFF ║
║ I/O Port: 04D0-04D1 ║
║ I/O Port: 0CF8-0CFF ║
║ I/O Port: 4000-400F ║
║ I/O Port: 4020-402F ║
║ I/O Port: 4040-404F ║
║ I/O Port: 4060-406F ║
║ I/O Port: 4080-408F ║
║ I/O Port: 40A0-40AF ║
║ I/O Port: 40C0-40CF ║
║ I/O Port: 40E0-40EF ║
║ I/O Port: 5000-500F ║
║ I/O Port: 6000-600F ║
║ I/O Port: 6020-602F ║
║ I/O Port: 6040-604F ║
║ I/O Port: 6060-606F ║
║ IRQ: 12, Edge triggered ║
║ IRQ: 6, Edge triggered ║
║ DMA: 2 ║
║ I/O Port: 03F0-03F5 ║
║ I/O Port: 03F7-03F7 ║
║ IRQ: 4, Edge triggered ║
║ I/O Port: 03F8-03FF ║
║ IRQ: 3, Edge triggered ║
║ I/O Port: 02F8-02FF ║
║ IRQ: 7, Edge triggered ║
║ I/O Port: 03BC-03BF ║
HWiNFO v6.0.4
████████████████████████████ESCD PCI Device Info████████████████████████████
║ Slot Number: 10h ║
║ Slot Type: Virtual Slot ║
║ Board Type: PCI ║
║ PCI Device Number: Bus: 0, Device: 0, Function: 0 ║
║ Device Name: VIA VT8604/5/6 ProSavage PL133/PM133/PN133 Chip║
HWiNFO v6.0.4
║ Slot Number: 11h ║
║ Board Type: PCI ║
║ PCI Device Number: Bus: 0, Device: 1, Function: 0 ║
║ Device Name: VIA VT8605 ProSavage PM133 Chipset - A.G.P. Con║
HWiNFO v6.0.4
║ Slot Number: 12h ║
║ IRQ: 14, Edge triggered ║
║ IRQ: 15, Edge triggered ║
║ I/O Port: 01F0-01FF ║
║ I/O Port: 03F6-03F6 ║
║ I/O Port: 0170-017F ║
║ I/O Port: 0376-0376 ║
║ Board Type: PCI ║
║ PCI Device Number: Bus: 0, Device: 7, Function: 0 ║
║ Device Name: VIA VT82C586 Apollo Chipset - PCI-to-ISA Bridge║
HWiNFO v6.0.4
║ Slot Number: 14h ║
║ Expansion Memory: 000A0000-000BFFFF ║
║ Expansion Memory: 000C0000-000CBFFF ║
║ Expansion Memory: ED000000-ED000FFF ║
║ Expansion Memory: E0000000-E0000FFF ║
║ I/O Port: 03B0-03BB ║
║ I/O Port: 03C0-03CF ║
║ Board Type: PCI ║
║ PCI Device Number: Bus: 1, Device: 0, Function: 0 ║
║ Device Name: S3 ProSavage PM133 (86C370) Video Adapter ║
HWiNFO v6.0.4
║ Slot Number: 15h ║
║ Expansion Memory: EE008000-EE008FFF ║
║ IRQ: 11, Level triggered ║
║ I/O Port: D800-D803 ║
║ Board Type: PCI ║
║ PCI Device Number: Bus: 0, Device: 8, Function: 0 ║
║ Device Name: RealTek Semiconductor RTL8139/8110 PCI Fast Eth║
HWiNFO v6.0.4
║ Slot Number: 16h ║
║ Expansion Memory: EE000000-EE000FFF ║
║ IRQ: 10, Level triggered ║
║ I/O Port: DC00-DC03 ║
║ I/O Port: E000-E003 ║
║ Board Type: PCI ║
║ PCI Device Number: Bus: 0, Device: 11, Function: 0 ║
║ Device Name: Yamaha DS-XG PCI Audio CODEC ║
HWiNFO v6.0.4
███████████████████Advanced Power Management Information████████████████████
║ AC Line Status: ON-LINE ║
║ Battery Status: No battery ║
HWiNFO v6.0.4
█████████████████████████████Video Information██████████████████████████████
║ DDC Monitor Name: Unknown (TBD3120) ║
║ Video Chipset: S3 ProSavage PM133 ║
║ Video Chipset Codename: 86C370 ║
║ Video Card: Unknown ║
║ Video Memory Size: 8,192 KBytes of SDRAM ║
║ Video Card Bus: ISA ║
║ Video RAMDAC: Integrated ║
║ Video BIOS Manufacturer: S3 Inc. ║
║ Video BIOS Version: 3.3C.27-CT.00 ║
║ VESA Support: Present (VBE 3.0) ║
HWiNFO v6.0.4
██████████████████████████DDC Monitor Information███████████████████████████
║ Monitor Name: Unknown (TBD3120) ║
║ Serial Number: 0001 ║
║ Date of Manufacture: 36. week of year 2016 ║
║ Max. horizontal size: 34 cm ║
║ Max. vertical size: 19 cm ║
║ Horizontal freq: 30 - 61 kHz ║
║ Vertical freq: 56 - 75 Hz ║
║ Display type: RGB color ║
║ Analog Input: 0.700 V / 0.300 V (1.000 V p-p) ║
║ Sync Inputs: Separate, On-green ║
║ Gamma: 2.20 ║
║ DPMS Support: Stand-by, Suspend, OFF ║
HWiNFO v6.0.4
██████████████████████████████VESA information██████████████████████████████
║ VESA Manufacturer: S3 Incorporated. Savage4 ║
║ Power Management: Present (VBE/PM 1.0) ║
║ Display Data Channel: Present (DDC1/DDC2B) ║
║ Accelerator Functions: Not Present ║
║ VBE2 Vendor: S3 Incorporated. ║
║ VBE2 Product: Savage4 ║
║ VBE2 Revision: Rev B ║
HWiNFO v6.0.4
█████████████████████████████Drive Information██████████████████████████████
║ Controller Device Connected ║
║ IDE ──┬─ Primary ─────┬─ Master SATA 3GB/s Device ║
║ │ └─ Slave <Empty> ║
║ ├─ Secondary ───┬─ Master <Empty> ║
║ ├─ Tertiary ────┬─ Master <Empty> ║
║ └─ Quaternary ──┬─ Master <Empty> ║
║ └─ Slave <Empty> ║
HWiNFO v6.0.4
███████████████████████IDE Drive Physical Information███████████████████████
║ Fixed Disk Controller: Serial ATA-II ║
║ VIA VT82C571 Integrated IDE Controller ║
║ Fixed Disk Capacity: 30,533 MBytes (32,015,965,696) Bytes ║
║ Fixed Disk Geometry: Bytes/Sector: N/A, Bytes/Track: N/A ║
║ - Logical: Cylinders: 16,383, Heads: 16, Sectors/Track: 63║
║ - Current: Cylinders: 16,383, Heads: 16, Sectors/Track: 63║
║ Cache Buffer Size: 32,767 KBytes ║
║ Sectors per Interrupt: Total: 1, Active: 1 ║
║ Controller type: Not Specified ║
║ Disk Model: OCZ-VERTEX ║
║ Firmware Revision: 1.5 ║
║ Serial Number: 7XX8E2S564J639480JP2 ║
║ Native Command Queuing: Not Present ║
║ Disk Type: [√ Fixed] [x Removable] [√ Magnetical] ║
║ Disk Features Present: [√ DMA] [√ LBA] [√ IORDY] [√ IORDY disableable]║
║ Max. PIO Transfer Mode: PIO: 4 ║
║ DMA Transfer Modes: SW: - (-), MW: 2 (2), Ultra: 6 (6) ║
║ Transfer Rates [MB/s]: DMA: 16.7, PIO+IORDY: 16.7, PIO-IORDY: 16.7 ║
║ S.M.A.R.T. Feature: Present, Status: Enabled ║
║ Security Mode: Present, Status: Disabled ║
║ Removable Media: Not Present ║
║ Power Management: Present, Status: Enabled ║
║ Advanced Power Management:Not Present ║
║ PACKET Interface: Not Present ║
║ Write Cache: Present, Status: Enabled ║
║ Look-ahead: Present, Status: Enabled ║
║ Host Protected Area: Present, Status: Enabled ║
HWiNFO v6.0.4
██████████████████████████Peripherals Information███████████████████████████
║ Floppy Drive(s): 1.44 MB 3½" ║
║ PCMCIA Adapter: Not Present ║
║ Sound Card: VIA AC'97 Audio Controller ║
║ Serial Port (COM1) UART: 16550A/AF/AFN/C/CF with FIFO ║
║ Serial Port (COM2) UART: 16550A/AF/AFN/C/CF with FIFO ║
║ Serial Port (COM3) N/A ║
║ Serial Port (COM4) N/A ║
║ Parallel Port (LPT1): 4-bit port ║
║ Parallel Port (LPT2): N/A ║
║ Parallel Port (LPT3): N/A ║
║ Super IO Chip: Winbond W83877TF ║
║ Keyboard Controller: N/A ║
HWiNFO v6.0.4
██████████████████████████Serial Port Information███████████████████████████
║ Modem: Not Present ║
║ PnP Device: Not Present ║
HWiNFO v6.0.4
HWiNFO v6.0.4
███████████████████████████Parallel Port Devices████████████████████████████
║ Hardware Key: No Hardware Keys Found ║
HWiNFO v6.0.4
██████████████████████████████Test CPU Errata███████████████████████████████
║ 32-bit Multiply: √ OK (80386) ║
║ POPAD Bug: √ OK (80386) ║
║ INSB Bug: √ OK (80386) ║
║ STOSB Bug: √ OK (80386) ║
║ MOVSB Bug: √ OK (80386) ║
║ BSWAP √ OK (80486) ║
║ FDIV Bug: √ OK (Pentium) ║
║ FIST Bug (Dan-0411): √ OK (Pentium Pro) ║
║ AMD-K6 (DRx) Bug: <Skipped> (AMD-K6) ║
HWiNFO v6.0.4
███████████████████████████████IRQ Assignment███████████████████████████████
║ IRQ Source Status Device ║
║ 0 PnP/Node USED System Timer ║
║ 1 PnP/Node USED 101/102-Key or MS Natural Keyboard ║
║ 2 PnP/Node USED Programmable Interrupt Controller ║
║ 3 PnP/Node USED 16550A-compatible UART Serial Port ║
║ 4 PnP/Node USED 16550A-compatible UART Serial Port ║
║ 5 FREE LPT2 ║
║ 6 PnP/Node USED Floppy Controller ║
║ 7 USED LPT1 ║
║ 8 PnP/Node USED RealTime Clock ║
║ 9 PCI USED VIA AC'97 Audio Controller ║
║ 10 PCI USED VIA VT82C686B USB Universal Host Controller ║
║ 11 FREE <seems to be free> ║
║ 12 PnP/Node USED Logitech PS/2 Port Mouse ║
║ 13 PnP/Node USED Numeric Data Processor ║
║ 14 USED Primary IDE Channel ║
║ 15 FREE Secondary IDE Channel ║
HWiNFO v6.0.4
███████████████████████████████DMA Assignment███████████████████████████████
║ DMA Source Status Device ║
║ 0 FREE <seems to be free> ║
║ 1 FREE <seems to be free> ║
║ 2 PnP/Node USED Floppy Controller ║
║ 3 FREE <seems to be free> ║
║ 4 PnP/Node USED DMA Controller ║
║ 5 FREE <seems to be free> ║
║ 6 FREE <seems to be free> ║
║ 7 FREE <seems to be free> ║
Reply 23 of 25, by cyclone3d
Huh.. looks like it is setting the slot the Yamaha card is in at IRQ10. But that is expected as you have it set to PNP and there is no setting to assign specific IRQs to specific slots.
There are a couple options to see if you can get the ability to assign specific IRQs to specific PCI slots.
1. Manually edit the BIOS to unlock hidden features
2. Use BIOS Patcher which should automatically fix problems and also unlock hidden features. You backup the BIOS to a file, then run the patcher on it and then flash the fixed BIOS file.
http://www.rom.by/articles/BP/index_english.htm
My google drive link to all the Bios Patcher stuff I was able to find - version 6a15 is the newest:
https://drive.google.com/open?id=1qLVXepDgz_z … tifPEYtanIr2mEB
I have used both methods in the past but of course there is some risk involved and I probably would not do either unless:
1. You have an EEPROM programmer.
2. You have a another motherboard that uses the same type of EEPROM that you can use for Hot Flashing if something goes wrong (remove the BIOS chip almost all the way from the second board, boot up second board, remove the BIOS chip while the system is running, insert the bricked BIOS, and then force flash the unmodified BIOS to the bricked chip).
Safest way is to use an EEPROM programmer to program a second chip so you can just swap out with the original chip.
YMF7x4 Guide
Reply 24 of 25, by johnnycontrario
cyclone3d wrote on 2020-04-26, 07:56:
Huh.. looks like it is setting the slot the Yamaha card is in at IRQ10. But that is expected as you have it set to PNP and there […]
This thread gave me the idea to try leaving the INTA# IRQ at 10 in SETUPDS and manually configuring DOOM's DEFAULT.CFG file to use IRQ 10 (BIOS was configured so the YMF was the only device using IRQ10). Again, all audio tests worked within SETUPDS, but I got no PCM audio in DOOM. It feels like a board/BIOS compatibility problem, but I don't know enough about DDMA to know what my next troubleshooting step should be.
Thanks for the BIOS links. I think I'll order a couple of compatible EEPROM chips on my next Mouser order. If I can create a working spare BIOS chip using the hot swap method, I'll play with the BIOS patcher.
Reply 25 of 25, by DIM89
Hello, I'm a newbie in the world of retro hardware. I've been trying to get a YMF724F-V working on an ASUS TUV4X (VIA chipset), PIII-S Tualatin 1.4, 512mb sdram VCM, ATI9800Pro 128mb and Windows98SE for a while now.
But in DOS games (Golden Axe, Pang, even Prince of Persia) I have problems with the FM sound, the one generated in OPL, I think, and I can't hear the music or effects. Games like Tomb Raider II work without any problem. In fact, I wanted to play Age Of Empires 1, in OPL, but it uses the more modern MIDI format. I think the problem is not being able to activate "DDMA" and I would need the files mentioned in the first post. I accept and appreciate any suggestions and corrections you may consider. Thanks.
