Reply 20 of 24, by synrgy87
Nothing special just the settings i have configured with "setupsa" I'm not using SETYMF but I'd like to try that out.
IRQ5 DMA1 MPU330
IRQ5 DMA1 MPU330
I personally prefer SETYMF and consider that SETUPSA is an abomination from a UI/usability standpoint . If you are looking to test for a specific issue, you can also test with INIT3DXG (meant for Audiotrix 3D/XG, but works with other YMF cards) . It is not as well layed out as SETYMF and has fewer options, but is worth a try .
Bit of testing, x-wing doesn't have the problem but seems to use an older imuse version, "SETMUSE" which detects and tests midi just fine, Dark Forces and Tie Fighter both lock up when trying to test with General Midi and also when trying to launch the game without testing, I was incorrect before when i stated i didn't have the problem, I had the sound set to 4-OP FM from testing a different card previously(ALS007)
My guess here is that the classic version (non collectors) will work as the classic version of Tie Fighter also uses the older "SETMUSE"
Edit: Also same behaviour with my ALS007 card;
Development: on a slower system(K6-2 400, Gigabyte GA-5AA) it's working. (original test system was an Abit KT7 with an AthlonXP CPU)
Strange that the newer versions would be speed sensitive and the older versions work. Guessing it's a speed issue.
synrgy87 wrote on 2020-05-17, 23:45:Bit of testing, x-wing doesn't have the problem but seems to use an older imuse version, "SETMUSE" which detects and tests midi […]
Yeah, as it turns out putting my P II 350 back in was the solution.
Excellent, so not just me, I wonder what the cut off is in terms of CPU speed, Might try later on my PIII 500.
Was a bit concerned with this as I've got a little upgrade on the way for my DOS system, ATX SS7 board with onboard YMF715 or 719 audio .
