Reply 20 of 21, by Joseph_Joestar
- l33t++
Joseph_Joestar wrote on 2021-05-26, 14:26:A somewhat unorthodox idea came to me, but I'm not sure if it's feasible so I'd like to run it by you guys. What if I get some male to female jumper cables (i.e. such as these) and simply use them to hook up the connector to the corresponding pins on the motherboard (male end goes into the connector, female end to the motherboard pins).
Update: I have successfully used the aforementioned jumper cables to connect a generic PS2 mouse header to my M571 motherboard.
As long as you have the pinout for your motherboard's PS2 connector and a multimeter for continuity testing of your PS2 bracket, this can easily be accomplished with jumper cables. No need to rewire the plug with this approach.
